I have a total of 6 hosts which i want to monitor with ILO.
5 of them are working correctly and one isn’t working correctly.
They have the same community setting. They are in the same subnet with the same firewall rule.
They are all the same model HP server with the same ILO version and firmware version.
When i add the host in my CheckMK server it is able to discover all the services correctly. After this the Check_MK Discovery and Check_MK service just show: (Service Check Timed Out)
With a mib browser i am able to read SNMP data.
From the CHECKMK server i am able to read out SNMP data with the following command:
time snmpwalk -v1 c slimstock -m “” -M “” -Cc -OQ -OU -On -Ot [IP address] .1.3.6.1.2.1.2.2.1.16
I see SNMP data and the time it takes is about 3.6 seconds.
I’ve deleted and added the host multiple times. I’ve tried snmp v1 & snmp v2 with the same result.
I’m not sure what else i can try, any help is appreciated
Checkmk version 2.1.0
Trying to acquire lock on /omd/sites/monitoring/var/check_mk/license_usage/next_run
Got lock on /omd/sites/monitoring/var/check_mk/license_usage/next_run
Trying to acquire lock on /omd/sites/monitoring/var/check_mk/license_usage/history.json
Got lock on /omd/sites/monitoring/var/check_mk/license_usage/history.json
Releasing lock on /omd/sites/monitoring/var/check_mk/license_usage/history.json
Released lock on /omd/sites/monitoring/var/check_mk/license_usage/history.json
Releasing lock on /omd/sites/monitoring/var/check_mk/license_usage/next_run
Released lock on /omd/sites/monitoring/var/check_mk/license_usage/next_run
+ FETCHING DATA
[cpu_tracking] Start [7f070b4dea30]
[SNMPFetcher] Fetch with cache settings: SNMPFileCache(ILO-BACKUP01, base_path=/omd/sites/monitoring/tmp/check_mk/data_source_cache/snmp, max_age=MaxAge(checking=0, discovery=120, inventory=120), disabled=False, use_outdated=False, simulation=False)
Not using cache (Too old. Age is 94618 sec, allowed is 0 sec)
SNMP scan:
Getting OID .1.3.6.1.2.1.1.1.0: Running 'snmpget -v1 -c slimstock -m "" -M "" -t 60.00 -r 5 -On -OQ -Oe -Ot 10.131.99.25 .1.3.6.1.2.1.1.1.0'
SNMP answer: ==> ["Integrated Lights-Out 5 2.65 Feb 23 2022"]
b'Integrated Lights-Out 5 2.65 Feb 23 2022'
Getting OID .1.3.6.1.2.1.1.2.0: Running 'snmpget -v1 -c slimstock -m "" -M "" -t 60.00 -r 5 -On -OQ -Oe -Ot 10.131.99.25 .1.3.6.1.2.1.1.2.0'
SNMP answer: ==> [.1.3.6.1.4.1.232.9.4.11]
b'.1.3.6.1.4.1.232.9.4.11'
Using cached OID .1.3.6.1.2.1.1.2.0: '.1.3.6.1.4.1.232.9.4.11'
Using cached OID .1.3.6.1.2.1.1.1.0: 'Integrated Lights-Out 5 2.65 Feb 23 2022'
Getting OID .1.3.6.1.2.1.2.2.1.*: Running 'snmpgetnext -Cf -v1 -c slimstock -m "" -M "" -t 60.00 -r 5 -On -OQ -Oe -Ot 10.131.99.25 .1.3.6.1.2.1.2.2.1'
SNMP answer: ==> [1]
b'1'
SNMP scan found if snmp_uptime
Trying to acquire lock on /omd/sites/monitoring/tmp/check_mk/snmp_scan_cache/ILO-BACKUP01.10.131.99.25
Got lock on /omd/sites/monitoring/tmp/check_mk/snmp_scan_cache/ILO-BACKUP01.10.131.99.25
Releasing lock on /omd/sites/monitoring/tmp/check_mk/snmp_scan_cache/ILO-BACKUP01.10.131.99.25
Released lock on /omd/sites/monitoring/tmp/check_mk/snmp_scan_cache/ILO-BACKUP01.10.131.99.25
hp_proliant_cpu: Fetching data (SNMP walk cache is enabled: Use any locally cached information)
Running 'snmpwalk -v1 -c slimstock -m "" -M "" -t 60.00 -r 5 -Cc -OQ -OU -On -Ot 10.131.99.25 .1.3.6.1.4.1.232.1.2.2.1.1.1'
Running 'snmpwalk -v1 -c slimstock -m "" -M "" -t 60.00 -r 5 -Cc -OQ -OU -On -Ot 10.131.99.25 .1.3.6.1.4.1.232.1.2.2.1.1.2'
Running 'snmpwalk -v1 -c slimstock -m "" -M "" -t 60.00 -r 5 -Cc -OQ -OU -On -Ot 10.131.99.25 .1.3.6.1.4.1.232.1.2.2.1.1.3'
Running 'snmpwalk -v1 -c slimstock -m "" -M "" -t 60.00 -r 5 -Cc -OQ -OU -On -Ot 10.131.99.25 .1.3.6.1.4.1.232.1.2.2.1.1.6'
hp_proliant_da_cntlr: Fetching data (SNMP walk cache is enabled: Use any locally cached information)
Running 'snmpwalk -v1 -c slimstock -m "" -M "" -t 60.00 -r 5 -Cc -OQ -OU -On -Ot 10.131.99.25 .1.3.6.1.4.1.232.3.2.2.1.1.1'
Running 'snmpwalk -v1 -c slimstock -m "" -M "" -t 60.00 -r 5 -Cc -OQ -OU -On -Ot 10.131.99.25 .1.3.6.1.4.1.232.3.2.2.1.1.2'
Running 'snmpwalk -v1 -c slimstock -m "" -M "" -t 60.00 -r 5 -Cc -OQ -OU -On -Ot 10.131.99.25 .1.3.6.1.4.1.232.3.2.2.1.1.5'
Running 'snmpwalk -v1 -c slimstock -m "" -M "" -t 60.00 -r 5 -Cc -OQ -OU -On -Ot 10.131.99.25 .1.3.6.1.4.1.232.3.2.2.1.1.6'
Running 'snmpwalk -v1 -c slimstock -m "" -M "" -t 60.00 -r 5 -Cc -OQ -OU -On -Ot 10.131.99.25 .1.3.6.1.4.1.232.3.2.2.1.1.9'
Running 'snmpwalk -v1 -c slimstock -m "" -M "" -t 60.00 -r 5 -Cc -OQ -OU -On -Ot 10.131.99.25 .1.3.6.1.4.1.232.3.2.2.1.1.10'
Running 'snmpwalk -v1 -c slimstock -m "" -M "" -t 60.00 -r 5 -Cc -OQ -OU -On -Ot 10.131.99.25 .1.3.6.1.4.1.232.3.2.2.1.1.12'
Running 'snmpwalk -v1 -c slimstock -m "" -M "" -t 60.00 -r 5 -Cc -OQ -OU -On -Ot 10.131.99.25 .1.3.6.1.4.1.232.3.2.2.1.1.15'
hp_proliant_da_phydrv: Fetching data (SNMP walk cache is enabled: Use any locally cached information)
Running 'snmpwalk -v1 -c slimstock -m "" -M "" -t 60.00 -r 5 -Cc -OQ -OU -On -Ot 10.131.99.25 .1.3.6.1.4.1.232.3.2.5.1.1.1'
Running 'snmpwalk -v1 -c slimstock -m "" -M "" -t 60.00 -r 5 -Cc -OQ -OU -On -Ot 10.131.99.25 .1.3.6.1.4.1.232.3.2.5.1.1.2'
Running 'snmpwalk -v1 -c slimstock -m "" -M "" -t 60.00 -r 5 -Cc -OQ -OU -On -Ot 10.131.99.25 .1.3.6.1.4.1.232.3.2.5.1.1.5'
Running 'snmpwalk -v1 -c slimstock -m "" -M "" -t 60.00 -r 5 -Cc -OQ -OU -On -Ot 10.131.99.25 .1.3.6.1.4.1.232.3.2.5.1.1.6'
Running 'snmpwalk -v1 -c slimstock -m "" -M "" -t 60.00 -r 5 -Cc -OQ -OU -On -Ot 10.131.99.25 .1.3.6.1.4.1.232.3.2.5.1.1.9'
Running 'snmpwalk -v1 -c slimstock -m "" -M "" -t 60.00 -r 5 -Cc -OQ -OU -On -Ot 10.131.99.25 .1.3.6.1.4.1.232.3.2.5.1.1.45'
Running 'snmpwalk -v1 -c slimstock -m "" -M "" -t 60.00 -r 5 -Cc -OQ -OU -On -Ot 10.131.99.25 .1.3.6.1.4.1.232.3.2.5.1.1.37'
Running 'snmpwalk -v1 -c slimstock -m "" -M "" -t 60.00 -r 5 -Cc -OQ -OU -On -Ot 10.131.99.25 .1.3.6.1.4.1.232.3.2.5.1.1.50'
Running 'snmpwalk -v1 -c slimstock -m "" -M "" -t 60.00 -r 5 -Cc -OQ -OU -On -Ot 10.131.99.25 .1.3.6.1.4.1.232.3.2.5.1.1.57'
Running 'snmpwalk -v1 -c slimstock -m "" -M "" -t 60.00 -r 5 -Cc -OQ -OU -On -Ot 10.131.99.25 .1.3.6.1.4.1.232.3.2.5.1.1.3'
Running 'snmpwalk -v1 -c slimstock -m "" -M "" -t 60.00 -r 5 -Cc -OQ -OU -On -Ot 10.131.99.25 .1.3.6.1.4.1.232.3.2.5.1.1.51'
Running 'snmpwalk -v1 -c slimstock -m "" -M "" -t 60.00 -r 5 -Cc -OQ -OU -On -Ot 10.131.99.25 .1.3.6.1.4.1.232.3.2.5.1.1.60'
Running 'snmpwalk -v1 -c slimstock -m "" -M "" -t 60.00 -r 5 -Cc -OQ -OU -On -Ot 10.131.99.25 .1.3.6.1.4.1.232.3.2.5.1.1.4'
hp_proliant_fans: Fetching data (SNMP walk cache is enabled: Use any locally cached information)
Running 'snmpwalk -v1 -c slimstock -m "" -M "" -t 60.00 -r 5 -Cc -OQ -OU -On -Ot 10.131.99.25 .1.3.6.1.4.1.232.6.2.6.7.1.2'
Running 'snmpwalk -v1 -c slimstock -m "" -M "" -t 60.00 -r 5 -Cc -OQ -OU -On -Ot 10.131.99.25 .1.3.6.1.4.1.232.6.2.6.7.1.3'
Running 'snmpwalk -v1 -c slimstock -m "" -M "" -t 60.00 -r 5 -Cc -OQ -OU -On -Ot 10.131.99.25 .1.3.6.1.4.1.232.6.2.6.7.1.4'
Running 'snmpwalk -v1 -c slimstock -m "" -M "" -t 60.00 -r 5 -Cc -OQ -OU -On -Ot 10.131.99.25 .1.3.6.1.4.1.232.6.2.6.7.1.6'
Running 'snmpwalk -v1 -c slimstock -m "" -M "" -t 60.00 -r 5 -Cc -OQ -OU -On -Ot 10.131.99.25 .1.3.6.1.4.1.232.6.2.6.7.1.9'
Running 'snmpwalk -v1 -c slimstock -m "" -M "" -t 60.00 -r 5 -Cc -OQ -OU -On -Ot 10.131.99.25 .1.3.6.1.4.1.232.6.2.6.7.1.12'
hp_proliant_mem: Fetching data (SNMP walk cache is enabled: Use any locally cached information)
Running 'snmpwalk -v1 -c slimstock -m "" -M "" -t 60.00 -r 5 -Cc -OQ -OU -On -Ot 10.131.99.25 .1.3.6.1.4.1.232.6.2.14.13.1.1'
Running 'snmpwalk -v1 -c slimstock -m "" -M "" -t 60.00 -r 5 -Cc -OQ -OU -On -Ot 10.131.99.25 .1.3.6.1.4.1.232.6.2.14.13.1.2'
Running 'snmpwalk -v1 -c slimstock -m "" -M "" -t 60.00 -r 5 -Cc -OQ -OU -On -Ot 10.131.99.25 .1.3.6.1.4.1.232.6.2.14.13.1.3'
Running 'snmpwalk -v1 -c slimstock -m "" -M "" -t 60.00 -r 5 -Cc -OQ -OU -On -Ot 10.131.99.25 .1.3.6.1.4.1.232.6.2.14.13.1.6'
Running 'snmpwalk -v1 -c slimstock -m "" -M "" -t 60.00 -r 5 -Cc -OQ -OU -On -Ot 10.131.99.25 .1.3.6.1.4.1.232.6.2.14.13.1.7'
Running 'snmpwalk -v1 -c slimstock -m "" -M "" -t 60.00 -r 5 -Cc -OQ -OU -On -Ot 10.131.99.25 .1.3.6.1.4.1.232.6.2.14.13.1.12'
Running 'snmpwalk -v1 -c slimstock -m "" -M "" -t 60.00 -r 5 -Cc -OQ -OU -On -Ot 10.131.99.25 .1.3.6.1.4.1.232.6.2.14.13.1.19'
Running 'snmpwalk -v1 -c slimstock -m "" -M "" -t 60.00 -r 5 -Cc -OQ -OU -On -Ot 10.131.99.25 .1.3.6.1.4.1.232.6.2.14.13.1.20'
hp_proliant_power: Fetching data (SNMP walk cache is enabled: Use any locally cached information)
Running 'snmpwalk -v1 -c slimstock -m "" -M "" -t 60.00 -r 5 -Cc -OQ -OU -On -Ot 10.131.99.25 .1.3.6.1.4.1.232.6.2.15.2'
Running 'snmpwalk -v1 -c slimstock -m "" -M "" -t 60.00 -r 5 -Cc -OQ -OU -On -Ot 10.131.99.25 .1.3.6.1.4.1.232.6.2.15.3'
hp_proliant_psu: Fetching data (SNMP walk cache is enabled: Use any locally cached information)
Running 'snmpwalk -v1 -c slimstock -m "" -M "" -t 60.00 -r 5 -Cc -OQ -OU -On -Ot 10.131.99.25 .1.3.6.1.4.1.232.6.2.9.3.1.1'
Running 'snmpwalk -v1 -c slimstock -m "" -M "" -t 60.00 -r 5 -Cc -OQ -OU -On -Ot 10.131.99.25 .1.3.6.1.4.1.232.6.2.9.3.1.2'
Running 'snmpwalk -v1 -c slimstock -m "" -M "" -t 60.00 -r 5 -Cc -OQ -OU -On -Ot 10.131.99.25 .1.3.6.1.4.1.232.6.2.9.3.1.3'
Running 'snmpwalk -v1 -c slimstock -m "" -M "" -t 60.00 -r 5 -Cc -OQ -OU -On -Ot 10.131.99.25 .1.3.6.1.4.1.232.6.2.9.3.1.4'
Running 'snmpwalk -v1 -c slimstock -m "" -M "" -t 60.00 -r 5 -Cc -OQ -OU -On -Ot 10.131.99.25 .1.3.6.1.4.1.232.6.2.9.3.1.7'
Running 'snmpwalk -v1 -c slimstock -m "" -M "" -t 60.00 -r 5 -Cc -OQ -OU -On -Ot 10.131.99.25 .1.3.6.1.4.1.232.6.2.9.3.1.8'
hp_proliant_raid: Fetching data (SNMP walk cache is enabled: Use any locally cached information)
Running 'snmpwalk -v1 -c slimstock -m "" -M "" -t 60.00 -r 5 -Cc -OQ -OU -On -Ot 10.131.99.25 .1.3.6.1.4.1.232.3.2.3.1.1.2'
Running 'snmpwalk -v1 -c slimstock -m "" -M "" -t 60.00 -r 5 -Cc -OQ -OU -On -Ot 10.131.99.25 .1.3.6.1.4.1.232.3.2.3.1.1.14'
Running 'snmpwalk -v1 -c slimstock -m "" -M "" -t 60.00 -r 5 -Cc -OQ -OU -On -Ot 10.131.99.25 .1.3.6.1.4.1.232.3.2.3.1.1.4'
Running 'snmpwalk -v1 -c slimstock -m "" -M "" -t 60.00 -r 5 -Cc -OQ -OU -On -Ot 10.131.99.25 .1.3.6.1.4.1.232.3.2.3.1.1.9'
Running 'snmpwalk -v1 -c slimstock -m "" -M "" -t 60.00 -r 5 -Cc -OQ -OU -On -Ot 10.131.99.25 .1.3.6.1.4.1.232.3.2.3.1.1.12'
hp_proliant_temp: Fetching data (SNMP walk cache is enabled: Use any locally cached information)
Running 'snmpwalk -v1 -c slimstock -m "" -M "" -t 60.00 -r 5 -Cc -OQ -OU -On -Ot 10.131.99.25 .1.3.6.1.4.1.232.6.2.6.8.1.2'
Running 'snmpwalk -v1 -c slimstock -m "" -M "" -t 60.00 -r 5 -Cc -OQ -OU -On -Ot 10.131.99.25 .1.3.6.1.4.1.232.6.2.6.8.1.3'
Running 'snmpwalk -v1 -c slimstock -m "" -M "" -t 60.00 -r 5 -Cc -OQ -OU -On -Ot 10.131.99.25 .1.3.6.1.4.1.232.6.2.6.8.1.4'
Running 'snmpwalk -v1 -c slimstock -m "" -M "" -t 60.00 -r 5 -Cc -OQ -OU -On -Ot 10.131.99.25 .1.3.6.1.4.1.232.6.2.6.8.1.5'
Running 'snmpwalk -v1 -c slimstock -m "" -M "" -t 60.00 -r 5 -Cc -OQ -OU -On -Ot 10.131.99.25 .1.3.6.1.4.1.232.6.2.6.8.1.6'
if: Fetching data (SNMP walk cache is enabled: Use any locally cached information)
Running 'snmpwalk -v1 -c slimstock -m "" -M "" -t 60.00 -r 5 -Cc -OQ -OU -On -Ot 10.131.99.25 .1.3.6.1.2.1.2.2.1.1'
Running 'snmpwalk -v1 -c slimstock -m "" -M "" -t 60.00 -r 5 -Cc -OQ -OU -On -Ot 10.131.99.25 .1.3.6.1.2.1.2.2.1.2'
Running 'snmpwalk -v1 -c slimstock -m "" -M "" -t 60.00 -r 5 -Cc -OQ -OU -On -Ot 10.131.99.25 .1.3.6.1.2.1.2.2.1.3'
^C[cpu_tracking] Stop [7f070b4dea30 - Snapshot(process=posix.times_result(user=0.050000000000000044, system=0.09000000000000001, children_user=0.08, children_system=0.09, elapsed=34.35999999940395))]
[cpu_tracking] Start [7f070b4defd0]
[PiggybackFetcher] Fetch with cache settings: NoCache(ILO-BACKUP01, base_path=/omd/sites/monitoring/tmp/check_mk/data_source_cache/piggyback, max_age=MaxAge(checking=0, discovery=120, inventory=120), disabled=True, use_outdated=False, simulation=False)
No piggyback files for 'ILO-BACKUP01'. Skip processing.
No piggyback files for '10.131.99.25'. Skip processing.
[cpu_tracking] Stop [7f070b4defd0 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.0))]
+ PARSE FETCHER RESULTS
-> Not adding sections: MKTerminate
No persisted sections
-> Add sections: []
Received no piggyback data
[cpu_tracking] Start [7f070b4de250]
value store: synchronizing
Trying to acquire lock on /omd/sites/monitoring/tmp/check_mk/counters/ILO-BACKUP01
Got lock on /omd/sites/monitoring/tmp/check_mk/counters/ILO-BACKUP01
Releasing lock on /omd/sites/monitoring/tmp/check_mk/counters/ILO-BACKUP01
Released lock on /omd/sites/monitoring/tmp/check_mk/counters/ILO-BACKUP01
HW CPU 0 PEND - Check plugin received no monitoring data
HW CPU 1 PEND - Check plugin received no monitoring data
HW Controller 0 PEND - Check plugin received no monitoring data
HW FAN1 (system) PEND - Check plugin received no monitoring data
HW FAN2 (system) PEND - Check plugin received no monitoring data
HW FAN3 (system) PEND - Check plugin received no monitoring data
HW FAN4 (system) PEND - Check plugin received no monitoring data
HW FAN5 (system) PEND - Check plugin received no monitoring data
HW FAN6 (system) PEND - Check plugin received no monitoring data
HW Mem 0 PEND - Check plugin received no monitoring data
HW Mem 11 PEND - Check plugin received no monitoring data
HW Mem 12 PEND - Check plugin received no monitoring data
HW Mem 14 PEND - Check plugin received no monitoring data
HW Mem 16 PEND - Check plugin received no monitoring data
HW Mem 19 PEND - Check plugin received no monitoring data
HW Mem 2 PEND - Check plugin received no monitoring data
HW Mem 21 PEND - Check plugin received no monitoring data
HW Mem 23 PEND - Check plugin received no monitoring data
HW Mem 4 PEND - Check plugin received no monitoring data
HW Mem 7 PEND - Check plugin received no monitoring data
HW Mem 9 PEND - Check plugin received no monitoring data
HW PSU 0/1 PEND - Check plugin received no monitoring data
HW PSU 0/2 PEND - Check plugin received no monitoring data
HW PSU Total PEND - Check plugin received no monitoring data
HW Phydrv 0/0 PEND - Check plugin received no monitoring data
HW Phydrv 0/1 PEND - Check plugin received no monitoring data
HW Phydrv 0/12 PEND - Check plugin received no monitoring data
HW Phydrv 0/14 PEND - Check plugin received no monitoring data
HW Phydrv 0/2 PEND - Check plugin received no monitoring data
HW Phydrv 0/3 PEND - Check plugin received no monitoring data
HW Phydrv 0/4 PEND - Check plugin received no monitoring data
HW Phydrv 0/5 PEND - Check plugin received no monitoring data
HW Phydrv 0/6 PEND - Check plugin received no monitoring data
HW Phydrv 0/7 PEND - Check plugin received no monitoring data
HW Power Meter PEND - Check plugin received no monitoring data
Interface 02 PEND - Check plugin received no monitoring data
Interface 04 PEND - Check plugin received no monitoring data
Interface 09 PEND - Check plugin received no monitoring data
Interface 12 PEND - Check plugin received no monitoring data
Interface 16 PEND - Check plugin received no monitoring data
Interface 18 PEND - Check plugin received no monitoring data
Interface 19 PEND - Check plugin received no monitoring data
Interface 20 PEND - Check plugin received no monitoring data
Interface 21 PEND - Check plugin received no monitoring data
Interface 37 PEND - Check plugin received no monitoring data
Interface 38 PEND - Check plugin received no monitoring data
Interface 39 PEND - Check plugin received no monitoring data
Interface 40 PEND - Check plugin received no monitoring data
Interface 41 PEND - Check plugin received no monitoring data
Interface 42 PEND - Check plugin received no monitoring data
Interface 43 PEND - Check plugin received no monitoring data
Interface 44 PEND - Check plugin received no monitoring data
Interface 45 PEND - Check plugin received no monitoring data
Interface 46 PEND - Check plugin received no monitoring data
Interface 47 PEND - Check plugin received no monitoring data
Interface 49 PEND - Check plugin received no monitoring data
Interface 50 PEND - Check plugin received no monitoring data
Interface 51 PEND - Check plugin received no monitoring data
Interface 52 PEND - Check plugin received no monitoring data
Interface 53 PEND - Check plugin received no monitoring data
Interface 54 PEND - Check plugin received no monitoring data
Interface 55 PEND - Check plugin received no monitoring data
Interface 56 PEND - Check plugin received no monitoring data
Interface 57 PEND - Check plugin received no monitoring data
Interface 58 PEND - Check plugin received no monitoring data
Logical Device PEND - Check plugin received no monitoring data
Logical Device 2 PEND - Check plugin received no monitoring data
SNMP Info PEND - Check plugin received no monitoring data
Temperature 1 (ambient) PEND - Check plugin received no monitoring data
Temperature 10 (memory) PEND - Check plugin received no monitoring data
Temperature 12 (system) PEND - Check plugin received no monitoring data
Temperature 14 (system) PEND - Check plugin received no monitoring data
Temperature 15 (ambient) PEND - Check plugin received no monitoring data
Temperature 16 (system) PEND - Check plugin received no monitoring data
Temperature 17 (system) PEND - Check plugin received no monitoring data
Temperature 18 (system) PEND - Check plugin received no monitoring data
Temperature 19 (system) PEND - Check plugin received no monitoring data
Temperature 2 (cpu) PEND - Check plugin received no monitoring data
Temperature 20 (system) PEND - Check plugin received no monitoring data
Temperature 21 (system) PEND - Check plugin received no monitoring data
Temperature 22 (system) PEND - Check plugin received no monitoring data
Temperature 23 (system) PEND - Check plugin received no monitoring data
Temperature 24 (system) PEND - Check plugin received no monitoring data
Temperature 25 (system) PEND - Check plugin received no monitoring data
Temperature 26 (system) PEND - Check plugin received no monitoring data
Temperature 27 (system) PEND - Check plugin received no monitoring data
Temperature 28 (ioBoard) PEND - Check plugin received no monitoring data
Temperature 29 (ioBoard) PEND - Check plugin received no monitoring data
Temperature 3 (cpu) PEND - Check plugin received no monitoring data
Temperature 30 (ioBoard) PEND - Check plugin received no monitoring data
Temperature 31 (ioBoard) PEND - Check plugin received no monitoring data
Temperature 33 (ioBoard) PEND - Check plugin received no monitoring data
Temperature 35 (ioBoard) PEND - Check plugin received no monitoring data
Temperature 37 (ioBoard) PEND - Check plugin received no monitoring data
Temperature 4 (memory) PEND - Check plugin received no monitoring data
Temperature 40 (system) PEND - Check plugin received no monitoring data
Temperature 43 (system) PEND - Check plugin received no monitoring data
Temperature 44 (powerSupply) PEND - Check plugin received no monitoring data
Temperature 45 (powerSupply) PEND - Check plugin received no monitoring data
Temperature 46 (powerSupply) PEND - Check plugin received no monitoring data
Temperature 47 (powerSupply) PEND - Check plugin received no monitoring data
Temperature 48 (powerSupply) PEND - Check plugin received no monitoring data
Temperature 49 (powerSupply) PEND - Check plugin received no monitoring data
Temperature 6 (memory) PEND - Check plugin received no monitoring data
Temperature 67 (cpu) PEND - Check plugin received no monitoring data
Temperature 68 (cpu) PEND - Check plugin received no monitoring data
Temperature 8 (memory) PEND - Check plugin received no monitoring data
Uptime PEND - Check plugin received no monitoring data
value store: already loaded
[cpu_tracking] Stop [7f070b4de250 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.009999997913837433))]
[snmp] MKTerminate(!!), Got no information from host(!!), execution time 34.4 sec | execution_time=34.370 user_time=0.050 system_time=0.090 children_user_time=0.080 children_system_time=0.090 cmk_time_snmp=34.050 cmk_time_agent=0.000
Oh and i forgot to mention, as an extra test i also created a SNMP rule specifically for this host with: Response timeout for a single query: 60 seconds with 5 retries, just to make sure it wasn’t a timeout issue.
No, not really. Something is definitely weird: Got no information from host(!!) in the last line and Check plugin received no monitoring data at all the Services. If it can find it at the other hosts, it should just work fine with this one (MIBs are right).
I did a restart/reset of my ILO without any success.
I’ve just created a Normal check interval for service checks rule with a 3 minutes check time specifically for this host. Let’s see if this works.
Does it find the Services if you do a “Remove all and find new” in the service configuration? Today I had problems with SNMP Host that were in stale and this fixed it.
@paulr282 I’ve just done a Remove all and find new. I’m not sure if it’s normal but finding the services on this ILO host also takes about 100 seconds. For other SNMP servers this time is only about 12 seconds. I think there might be some timeout issues.
Sadly after performing the Remove all and find new all the services still stay on the same state as the above picture. On the Services of host screen it did find all the services.
@paulr282 It is definately some kind of issue with the response time of the SNMP.
In the picture i have an output from a correctly working ILO SNMP readout at only 2.9 seconds compared to 64.9 seconds on the “broken” server.
I’ve noticed that specifically a few SNMP walks are extremely slow, as seen in the picture under Extremely slow on these SNMP walks:
@paulr282 I’ve just used the ManageEngine Mibbrowser to test this.
When i do a snmpwalk to 10.131.99.25 (the problem ILO host) with OID: .1.3.6.1.2.1.2.2.1.1 i get a response “1”
When i do a snmpwalk to 10.131.99.14 or other working ILO host i get response: Request Failed: Get Response PDU received from 10.131.99.14 Error Indication in response: There is no such variable name in this mib. Errindex: 1
Yes, when i compare the 2 ouputs from cmk --debug -vv it both snmpwalks the “problematic” OID’s.
But the ones on a working host go by instantly whereas the host that isn’t working correctly takes about 5-10 seconds per OID.
etc. etc.
So I guess it´s not the ILO itself either. Maybe something in your network? Maybe a problem with checkmk?
Sorry, I don’t really know how to troubleshoot this further.
Hi @paulr282 Thank you for all the help nonetheless, these steps will definitely help me in the future for any other troubleshooting.
I will try some more things with networking to see if i can get it working, thanks!
