I’m trying to add MIBS and monitor the Sandvine platform.
REF:
I’m new so please share a lot of details to help navigate to the solution …
I’ve recently setup the following events. However the MIBS are not translated as expected.
Issue (Example):
APPLICATION:
SNMPv2-SMI::enterprises.11610.1.7.1.4.1.2.0.4(The authoritative identification of the notification currently being sent. This variable occurs as the second varbind in every SNMPv2-Trap-PDU and InformRequest-PDU.)
We would expect:
“SANDVINE-PCMMSNMP-MIB::svDegradedSNMPRouteDiscoveryClearNotification”
We would expect this as the MIB contains this information:
"snmpwalk -v 2c 127.0.0.1 1.3.6.1.4.1.11610.1.7.1.4.1.2.0.4"
In all cases, I see the OID, and not the expected name = value?
snmpwalk -v 2c 127.0.0.1 1.3.6.1.4.1.11610.1.7.1.2.1.1.1.0
SANDVINE-PCMMSNMP-MIB::svPcmmSnmpPeerDisconnectedCounter.0 = INTEGER: 0
Mibs copied here:
[root@services mibs]# pwd
/usr/share/snmp/mibs
[root@services mibs]# ls -l
total 3368
-rw-r--r-- 1 root root 17455 Dec 1 08:14 AGENTX-MIB.txt
-rw-r--r-- 1 root root 41009 Jan 16 13:02 ALARM-MIB.txt
-rw-r--r-- 1 root root 50948 Dec 1 08:14 BRIDGE-MIB.txt
-rw-r--r-- 1 root root 68104 Dec 1 08:14 DISMAN-EVENT-MIB.txt
-rw-r--r-- 1 root root 42665 Jan 16 13:02 DISMAN-EXPRESSION-MIB.txt
-rw-r--r-- 1 root root 24613 Dec 1 08:14 DISMAN-SCHEDULE-MIB.txt
-rw-r--r-- 1 root root 64311 Dec 1 08:14 DISMAN-SCRIPT-MIB.txt
-rw-r--r-- 1 root root 52632 Jan 16 13:02 ENTITY-MIB.txt
-rw-r--r-- 1 root root 16149 Jan 16 13:02 ENTITY-SENSOR-MIB.txt
-rw-r--r-- 1 root root 84492 Dec 1 08:14 EtherLike-MIB.txt
-rw-r--r--. 1 root root 803 Aug 6 19:03 FREERADIUS-MGMT-MIB.mib
-rw-r--r--. 1 root root 5537 Aug 6 19:03 FREERADIUS-NOTIFICATION-MIB.mib
-rw-r--r--. 1 root root 1937 Aug 6 19:03 FREERADIUS-PRODUCT-RADIUSD-MIB.mib
-rw-r--r--. 1 root root 1169 Aug 6 19:03 FREERADIUS-SMI.mib
-rw-r--r-- 1 root root 4660 Dec 1 08:14 HCNUM-TC.txt
-rw-r--r-- 1 root root 52544 Jan 16 13:02 HOST-RESOURCES-MIB.txt
-rw-r--r-- 1 root root 10583 Jan 16 13:02 HOST-RESOURCES-TYPES.txt
-rw-r--r-- 1 root root 6713 Dec 1 08:14 IANA-ADDRESS-FAMILY-NUMBERS-MIB.txt
-rw-r--r-- 1 root root 35384 Dec 1 08:14 IANAifType-MIB.txt
-rw-r--r-- 1 root root 4387 Dec 1 08:14 IANA-LANGUAGE-MIB.txt
-rw-r--r-- 1 root root 4098 Dec 1 08:14 IANA-RTPROTO-MIB.txt
-rw-r--r-- 1 root root 5066 Dec 1 08:14 IF-INVERTED-STACK-MIB.txt
-rw-r--r-- 1 root root 71691 Dec 1 08:14 IF-MIB.txt
-rw-r--r-- 1 root root 16782 Dec 1 08:14 INET-ADDRESS-MIB.txt
-rw-r--r-- 1 root root 46286 Dec 1 08:14 IP-FORWARD-MIB.txt
-rw-r--r-- 1 root root 185667 Dec 1 08:14 IP-MIB.txt
-rw-r--r-- 1 root root 2028 Dec 1 08:14 IPV6-FLOW-LABEL-MIB.txt
-rw-r--r-- 1 root root 21057 Dec 1 08:14 IPV6-ICMP-MIB.txt
-rw-r--r-- 1 root root 56463 Dec 1 08:14 IPV6-MIB.txt
-rw-r--r-- 1 root root 8858 Dec 1 08:14 IPV6-TCP-MIB.txt
-rw-r--r-- 1 root root 3154 Dec 1 08:14 IPV6-TC.txt
-rw-r--r-- 1 root root 5698 Dec 1 08:14 IPV6-UDP-MIB.txt
-rw-r--r-- 1 root root 2837 Jan 16 13:02 ITU-ALARM-TC-MIB.txt
-rw-r--r-- 1 root root 5931 Dec 1 08:14 LM-SENSORS-MIB.txt
-rw-r--r-- 1 root root 42375 Dec 1 08:14 MTA-MIB.txt
-rw-r--r-- 1 root root 15901 Dec 1 08:14 NET-SNMP-AGENT-MIB.txt
-rw-r--r-- 1 root root 9160 Dec 1 08:14 NET-SNMP-EXAMPLES-MIB.txt
-rw-r--r-- 1 root root 9326 Dec 1 08:14 NET-SNMP-EXTEND-MIB.txt
-rw-r--r-- 1 root root 2036 Dec 1 08:14 NET-SNMP-MIB.txt
-rw-r--r-- 1 root root 3730 Dec 1 08:14 NET-SNMP-PASS-MIB.txt
-rw-r--r-- 1 root root 4814 Dec 1 08:14 NET-SNMP-TC.txt
-rw-r--r-- 1 root root 5039 Dec 1 08:14 NET-SNMP-VACM-MIB.txt
-rw-r--r-- 1 root root 21006 Dec 1 08:14 NETWORK-SERVICES-MIB.txt
-rw-r--r-- 1 root root 24694 Dec 1 08:14 NOTIFICATION-LOG-MIB.txt
-rw-r--r--. 1 root root 25998 Aug 6 19:03 RADIUS-ACC-CLIENT-MIB.mib
-rw-r--r--. 1 root root 13634 Aug 6 19:03 RADIUS-ACC-SERVER-MIB.mib
-rw-r--r--. 1 root root 28841 Aug 6 19:03 RADIUS-AUTH-CLIENT-MIB.mib
-rw-r--r--. 1 root root 14617 Aug 6 19:03 RADIUS-AUTH-SERVER-MIB.mib
-rw-r--r--. 1 root root 10969 Aug 6 19:03 RADIUS-STAT-MIB.mib
-rw-r--r-- 1 root root 3067 Dec 1 08:14 RFC1155-SMI.txt
-rw-r--r-- 1 root root 79667 Dec 1 08:14 RFC1213-MIB.txt
-rw-r--r-- 1 root root 1174 Dec 1 08:14 RFC-1215.txt
-rw-r--r-- 1 root root 147822 Dec 1 08:14 RMON-MIB.txt
-rw-r--r-- 1 root root 2532 Jan 16 13:02 SANDVINE-APPLICATION-MONITORING-MIB.txt
-rw-r--r-- 1 root root 38579 Jan 16 13:02 SANDVINE-DHCP-MIB.txt
-rw-r--r-- 1 root root 5397 Jan 16 13:02 SANDVINE-DIAMETER-IF-MIB.txt
-rw-r--r-- 1 root root 19229 Jan 16 13:02 SANDVINE-FAILOVER-CLUSTER-MIB.txt
-rw-r--r-- 1 root root 21451 Jan 16 13:02 SANDVINE-GTPC-MIB.txt
-rw-r--r-- 1 root root 19851 Jan 16 13:02 SANDVINE-GXSERVER-MIB.txt
-rw-r--r-- 1 root root 17445 Jan 16 13:02 SANDVINE-HTTP-CLIENT-MIB.txt
-rw-r--r-- 1 root root 3931 Jan 16 13:02 SANDVINE-HTTP-MIB.txt
-rw-r--r-- 1 root root 1634 Jan 16 13:02 SANDVINE-JMSD-MIB.txt
-rw-r--r-- 1 root root 12706 Jan 16 13:02 SANDVINE-LDAP-MIB.txt
-rw-r--r-- 1 root root 15573 Jan 16 13:02 SANDVINE-LOGGING-MIB.txt
-rw-r--r-- 1 root root 738550 Jan 16 13:02 SANDVINE-MIB.txt
-rw-r--r-- 1 root root 3774 Jan 16 13:02 SANDVINE-NBI-MIB.txt
-rw-r--r-- 1 root root 14091 Jan 16 13:02 SANDVINE-PCMMIPDR-MIB.txt
-rw-r--r-- 1 root root 25121 Jan 16 13:02 SANDVINE-PCMM-MIB.txt
-rw-r--r-- 1 root root 5628 Jan 16 13:02 SANDVINE-PCMMSNMP-MIB.txt
-rw-r--r-- 1 root root 16605 Jan 16 13:02 SANDVINE-PERSISTENCY-MIB.txt
-rw-r--r-- 1 root root 3668 Jan 16 13:02 SANDVINE-POLICYCONTROLLER-MIB.txt
-rw-r--r-- 1 root root 7562 Jan 16 13:02 SANDVINE-PROCESS-MONITOR-MIB.txt
-rw-r--r-- 1 root root 45456 Jan 16 13:02 SANDVINE-PROVISION-MIB.txt
-rw-r--r-- 1 root root 26256 Jan 16 13:02 SANDVINE-QUOTAMANAGER-MIB.txt
-rw-r--r-- 1 root root 35039 Jan 16 13:02 SANDVINE-RADIUS-MIB.txt
-rw-r--r-- 1 root root 7614 Jan 16 13:02 SANDVINE-RECORD-GENERATOR-MIB.txt
-rw-r--r-- 1 root root 14769 Jan 16 13:02 SANDVINE-RXSERVER-MIB.txt
-rw-r--r-- 1 root root 9067 Jan 16 13:02 SANDVINE-S9-MIB.txt
-rw-r--r-- 1 root root 3705 Jan 16 13:02 SANDVINE-SUBSCRIBER-MAPPING-MIB.txt
-rw-r--r-- 1 root root 10837 Jan 16 13:02 SANDVINE-SYCLIENT-MIB.txt
-rw-r--r-- 1 root root 10375 Jan 16 13:02 SANDVINE-TEXTINPUT-MIB.txt
-rw-r--r-- 1 root root 3899 Jan 16 13:03 SANDVINE-USAGE-MANAGEMENT-MIB.txt
-rw-r--r-- 1 root root 5506 Jan 16 13:03 SANDVINE-USAGESERVER-MIB.txt
-rw-r--r-- 1 root root 5123 Jan 16 13:03 SANDVINE-VIP-MIB.txt
-rw-r--r-- 1 root root 45323 Dec 1 08:14 SCTP-MIB.txt
-rw-r--r-- 1 root root 4649 Dec 1 08:14 SMUX-MIB.txt
-rw-r--r-- 1 root root 15490 Dec 1 08:14 SNMP-COMMUNITY-MIB.txt
-rw-r--r-- 1 root root 22342 Dec 1 08:14 SNMP-FRAMEWORK-MIB.txt
-rw-r--r-- 1 root root 5496 Dec 1 08:14 SNMP-MPD-MIB.txt
-rw-r--r-- 1 root root 20014 Dec 1 08:14 SNMP-NOTIFICATION-MIB.txt
-rw-r--r-- 1 root root 9106 Dec 1 08:14 SNMP-PROXY-MIB.txt
-rw-r--r-- 1 root root 22769 Dec 1 08:14 SNMP-TARGET-MIB.txt
-rw-r--r-- 1 root root 43927 Dec 1 08:14 SNMP-TLS-TM-MIB.txt
-rw-r--r-- 1 root root 8912 Dec 1 08:14 SNMP-TSM-MIB.txt
-rw-r--r-- 1 root root 39201 Dec 1 08:14 SNMP-USER-BASED-SM-MIB.txt
-rw-r--r-- 1 root root 2205 Dec 1 08:14 SNMP-USM-AES-MIB.txt
-rw-r--r-- 1 root root 21101 Dec 1 08:14 SNMP-USM-DH-OBJECTS-MIB.txt
-rw-r--r-- 1 root root 4400 Dec 1 08:14 SNMP-USM-HMAC-SHA2-MIB.txt
-rw-r--r-- 1 root root 8263 Dec 1 08:14 SNMPv2-CONF.txt
-rw-r--r-- 1 root root 29305 Dec 1 08:14 SNMPv2-MIB.txt
-rw-r--r-- 1 root root 8924 Dec 1 08:14 SNMPv2-SMI.txt
-rw-r--r-- 1 root root 38034 Dec 1 08:14 SNMPv2-TC.txt
-rw-r--r-- 1 root root 5775 Dec 1 08:14 SNMPv2-TM.txt
-rw-r--r-- 1 root root 34162 Dec 1 08:14 SNMP-VIEW-BASED-ACM-MIB.txt
-rw-r--r-- 1 root root 28564 Dec 1 08:14 TCP-MIB.txt
-rw-r--r-- 1 root root 16418 Dec 1 08:14 TRANSPORT-ADDRESS-MIB.txt
-rw-r--r-- 1 root root 27826 Dec 1 08:14 TUNNEL-MIB.txt
-rw-r--r-- 1 root root 2163 Dec 1 08:14 UCD-DEMO-MIB.txt
-rw-r--r-- 1 root root 4965 Dec 1 08:14 UCD-DISKIO-MIB.txt
-rw-r--r-- 1 root root 3087 Dec 1 08:14 UCD-DLMOD-MIB.txt
-rw-r--r-- 1 root root 8118 Dec 1 08:14 UCD-IPFWACC-MIB.txt
-rw-r--r-- 1 root root 52820 Dec 1 08:14 UCD-SNMP-MIB.txt
-rw-r--r-- 1 root root 20882 Dec 1 08:14 UDP-MIB.txt
