Please activate the debug level for snmp event-and rule processing in event console and check that port 162 from mkeventd is bind to “0.0.0.0” or the needed interface.
Check if you set your SNMP version and credentials in WATO > Event Console > Settings > Credentials for processing SNMP traps. Also, if you are using SNMPv3, you must add engine ID. Otherwise, the alarms will not appear on CheckMK’s interface only with credentials and version.
I’m using the default SNMP credentials (v1 and v2c, not v3). Using tcpdump (shown above) I don’t see any credentials sent by the PDU or the IPMI interface.
