I have a question. This is all data I get after configuring snmp v3 . So this are all the data Check_mk, then I get SNMP_info and Uptime. Is there any way to get cpu and disk utilization and how.
Hi boomlau,
there is no screenshot attached.
What device type are you monitoring ?
I am monitoring virtual machine, with rocky linux 9.
Do I need to configure some function in python or something else ?
You will have to install the checkmk agent in the virtual machine.
