After installing checkmk_1.6P19 i’m trying to go to monitor ISILON but i see that check_mk goes in error with the message
“CRIT - [snmp] SNMP Error on ISILON-A while walking .1.3.6.1.4.1.12124.2.55.1.3. Normally this is caused by a device sending invalid SNMP responses (Details: (genError) A general failure occured (5/1)).CRIT, Got no information from host, execution time 2.2 sec”
The problem is the “emc_isilion_power” check. What version do you used before the update to 1.6.0p19?
If it was a 1.6 version also before then it is strange as this check was not changed since two years.
One thing you can try is to disable the “emc_isilion_power” check with the rule “Disabled checks”.
Try then to do a complete reinventory on the machine with “cmk --debug -vvII ISILION-A”
If there are other problems you will get the error message.
I don’t think this is a bug in CMK it looks more like an SNMP problem on your Isilon system.
Other option is that your Isilon has the data in other OID’s (different firmware can result in different OID’s).
