SNMPv3 context not applied to snmpget (HP printer, context Jetdirect)
CMK version:
CheckMK 2.4.0p5 raw edition
OS version:
Ubuntu 24.04.2 LTS
OMD[site]:~$ cmk --debug -vvvvvI hostname
Discovering services and host labels on: hostname
hostname:
+ FETCHING DATA
  Source: SourceInfo(hostname='hostname', ipaddress='10.10.10.10', ident='snmp', fetcher_type=<FetcherType.SNMP: 7>, source_type=<SourceType.HOST: 1>)
[cpu_tracking] Start [7e6fdb5fdb80]
Read from cache: SNMPFileCache(path_template=/omd/sites/site/tmp/check_mk/data_source_cache/snmp/{mode}/hostname, max_age=MaxAge(checking=0, discovery=90.0, inventory=90.0), simulation=False, use_only_cache=False, file_cache_mode=1)
  SNMP scan:
       Getting OID .1.3.6.1.2.1.1.1.0...
Running 'snmpget -v3 -l authPriv -a sha -u redacted -A redacted -x AES -X redacted -m "" -M "" -On -OQ -Oe -Ot 10.10.10.10 .1.3.6.1.2.1.1.1.0'
ERROR: SNMP error: snmpget: Bad context specified
       Getting OID .1.3.6.1.2.1.1.1.0 failed.
When using SNMPv3 contexts configured in Checkmk, the context isn’t being applied to snmpget calls. If I hardcode the context (e.g., -n Jetdirect) in lib/python3/cmk/fetchers/snmp_backend/classic.py, the snmpget command succeeds and retrieves the correct data. Subsequent snmpbulkwalk calls then correctly pick up and apply the context from the Checkmk configuration. It appears that snmpget is ignoring the configured SNMPv3 context. Is this a bug, or am I missing something?
Hi Slano,
yes this is a bug and I’m currently working on a fix.
But there are two known partial workarounds:
  1. Use SNMPv2
  2. Add a “Hosts without system description OID” rule (this will only provide the most basic information, see: [Check_mk (deutsch)] SNMPv3 Context mit HP Drucker - #3 by dcf5ecae3f27d2ce)
I’ll post a link to the werk once the fix is ready.
Have a nice day
Andreas
Good news. The fix has passed reviews and will be available to all maintained versions of Checkmk.
For more details see Werk #18341: snmplib: Always use SNMPv3 contexts in requests
Perfect, thanks a lot for the info as well as the fix!
Hello!
Solution
Thank you!
