Ja, er erhaltet nun den special agent, aber er erhaltet dies:
[special_redfish] Agent exited with code 1: Agent failed - please submit a crash report! (Crash-ID: fcfb3314-5133-11ee-a671-137039d43f37)**CRIT** , [piggyback] Success (but no data found for this host), execution time 1.3 sec
Crash Report:
Exception
InvalidCredentialsError (HTTP 401 Unauthorized returned: Invalid credentials supplied)
Traceback
File "/omd/sites/site/lib/python3/cmk/special_agents/utils/agent_common.py", line 148, in _special_agent_main_core
return main_fn(args)
File "/omd/sites/site/local/share/check_mk/agents/special/agent_redfish", line 566, in agent_redfish_main
REDFISHOBJ = get_session(args)
File "/omd/sites/site/local/share/check_mk/agents/special/agent_redfish", line 546, in get_session
REDFISHOBJ.login(auth="session")
File "/omd/sites/site/local/lib/python3/redfish/rest/v1.py", line 1006, in login
raise InvalidCredentialsError('HTTP 401 Unauthorized returned: Invalid credentials supplied')
Local Variables
{'auth': 'session',
'data': {'Password': 'pass', 'UserName': 'user'},
'headers': {'Accept': '*/*',
'Content-Type': 'application/json',
'OData-Version': '4.0'},
'message_item': None,
'password': None,
'resp': <redfish.rest.v1.RestResponse object at 0x7f11e2bf0d50>,
'self': <redfish.rest.v1.HttpClient object at 0x7f11e2bcd250>,
'username': None}
Ich hab mich schon am anfang gefragt, was für ein Benutzer in der API rein sollte.
habe ich auch schon versucht, erhalte dies und finde / habe nicht diese url /redfish/v1/AccountService/Accounts/2
Exception
RedfishPasswordChangeRequiredError (('Password Change Required\n', '/redfish/v1/AccountService/Accounts/2'))
Traceback
File "/omd/sites/site/local/lib/python3/redfish/rest/v1.py", line 1001, in login
raise RedfishPasswordChangeRequiredError("Password Change Required\n", message_item["MessageArgs"][0])
Local Variables
{'auth': 'session',
'data': {'Password': 'pass', 'UserName': 'bmc-user'},
'message_item': {'@odata.type': '#Message.v1_1_2.Message',
'Message': 'The password provided for this account must be '
'changed before access is granted. PATCH the '
'Password property for this account located at '
'the target URI '
"'/redfish/v1/AccountService/Accounts/2' to "
'complete this process.',
'MessageArgs': ['/redfish/v1/AccountService/Accounts/2'],
'MessageId': 'Base.1.12.PasswordChangeRequired',
'MessageSeverity': 'Critical',
'Resolution': 'Change the password for this account using a '
'PATCH to the Password property at the URI '
'provided.'},
'password': None,
'resp': <redfish.rest.v1.RestResponse object at 0x7ff1a651c990>,
'self': <redfish.rest.v1.HttpClient object at 0x7ff1a64fce10>,
'username': None}
Das sollte aussagekräftig genug sein.
Das der Agent auf der GUI nur mit einem “Agent exited with code 1:” beendet wird kann ich nicht ändern da dies vom CMK erzeugt wird die Ausgabe.
wir haben bei uns einen SR550 Server im Einsatz und haben das Redfish Plugin ausgerollt und empfangen auch mehrere Service. Wir würden gerne auch die Lokal eingebauten Festplatten und den Status des Raid Controller monitoren. Diese Service können wir nicht abfragen. Hat hierzu jemand eine Lösung? LG Moritz
Bis jetzt konnte ich auch nicht herausfinden, ob man den Health Status der Festplatten überwachen kann. Die Raid Controller sehe ich aber. Welche Version hast du denn?
Lg
Das mit den Festplatten sollte gehn. Habe nur letztens von @mike1098 Output erhalten wo alle Festplatten den gleichen Namen haben. Hier muss ich mir noch überlegen wie ich diese richtige eindeutig bezeichne. Wenn ich den Special Agent Output sehen könnte (PM), dann könnte ich auch sagen was hier das Problem ist.
Was hat da nicht funktioniert. Einfach das neue MKP installieren, danach aktivieren. Beim aktivieren des 2.2.19 wird automatisch das 2.2.17 deaktiviert und kann danach deinstalliert werden.
