CMK version:2.1.0p33 cfe
Good evening
I use CheckmMK 2.1.0p33
I have the problem that I can not receive SNMPv3 traps from the Fortigate with CheckMK.
I also have 2 switches with which I can receive SNMPv3 traps.
However SNMPv2 traps work from the Fortigate to CheckMK.
So from CheckMK side there can be no error.
Here is my config in the FortiGate unit
set status enable
set engine-id-type text
set engine-id "800022340354a"
set description "xxxxx"
set contact-info "xxxx"
set location "xxxxx"
set trap-high-cpu-threshold 80
set trap-low-memory-threshold 80
set trap-log-full-threshold 90
set status enable
set trap-status enable
set trap-lport 162
set trap-rport 162
set queries enable
set query-port 161
set notify-hosts "CheckMK Address"
set source-ip "FortiGate IP"
set source-ipv6 ::
set ha-direct disable
set events cpu-high mem-low log-full intf-ip vpn-tun-up vpn-tun-down ha-switch ha-hb-failure ips-signature ips-anomaly av-virus av-oversize av-pattern av-fragmented fm-if-change fm-conf-change bgp-established bgp-backward-transition ha-member-up ha-member-down ent-conf-change av-conserve av-bypass av-oversize-passed av-oversize-blocked ips-pkg-update ips-fail-open temperature-high voltage-alert power-supply-failure faz-disconnect wc-ap-up wc-ap-down fswctl-session-up fswctl-session-down load-balance-real-server-down device-new per-cpu-high dhcp pool-usage ospf-nbr-state-change ospf-virtnbr-state-change
set mib-view ''
set security-level auth-priv
set auth-proto sha512
set auth-pwd ENC xxxxxxxxxxxxxx
set priv-proto aes
set priv-pwd ENC xxxxxxxxxxxxxxxxxxxxx
Maybe someone can help me.
Because the problem exists with not only one Fortigate.
Thanks in advance
