I can reach altermanager through the ingress
OMD[example_site]:~$ curl https://kube-dev.iznet/alertmanager
<!DOCTYPE html>
<html lang="en">
<head>
<meta charset="utf-8">
<meta name="viewport" content="width=device-width, initial-scale=1, shrink-to-fit=no">
<link rel="icon" type="image/x-icon" href="favicon.ico" />
<title>Alertmanager</title>
</head>
<body>
<script>
// If there is no trailing slash at the end of the path in the url,
// add one. This ensures assets like script.js are loaded properly
if (location.pathname.substr(-1) != '/') {
location.pathname = location.pathname + '/';
console.log('added slash');
</script>
<script src="script.js"></script>
<script>
var app = Elm.Main.init({
flags: {
production: true,
defaultCreator: localStorage.getItem('defaultCreator'),
groupExpandAll: JSON.parse(localStorage.getItem('groupExpandAll'))
app.ports.persistDefaultCreator.subscribe(function(name) {
localStorage.setItem('defaultCreator', name);
app.ports.persistGroupExpandAll.subscribe(function(expanded) {
localStorage.setItem('groupExpandAll', JSON.stringify(expanded));
</script>
</body>
</html>
When I configure the special agent in v2.1.0p15 with custom url kube-dev.iznet/alertmanager (https), the piggyback host has an unhandled problem [special_alertmanager] Agent exited with code 1: 404 Client Error: Not Found for url: **https://kube-dev.iznet/alertmanager/api/v1/rules**
There is no API-Endpoint on the ingress. Where has the custom-url in the special_agent config has to point to?
