Ssllabs package not working
i added and enabled this package in checkmk 2.4.0p13 using the cli tool mkp
ssllabs api check - Checkmk Exchange
rebooted the whole linux server, but still no trace of “ssllabs” in the checkmk web gui
“mkp list” shows the plugin as: Enabled (active on this site)
“mkp show ssllabs” shows:
Version: 3.3.1
Packaged on Checkmk Version: 2.3.0p9
Required Checkmk Version: 2.3.0p1
Valid until Checkmk version: No version limitation
can anyone confirm that it works on checkmk 2.4.0p13?
what can i do to troubleshoot this issue?
This mkp will not work with 2.4. It is only compatible up to 2.3.
It has no version limitation as at build time there was no 2.4 existing :wink:
thanks for the info.
i’ll have to find another way to use the ssllabs api
You can try this package. This is based on an older version of the package from the Exchange.
This one work.
Thanks a lot.
Hello!
Thank you!
