Starting with Robotmk
I am trying to dip my toes into Robotmk… So far I have
  • set up a Windows server
  • deployed the Robotmk scheduler via the appropriate rule
  • configured a proxy in that rule
I then try to initialize the runtime environment:
C:\ProgramData\checkmk\agent\bin\rcc.exe config import -f C:\robotmk\rcc_home\current_user\profile_robotmk.yaml
C:\ProgramData\checkmk\agent\bin\rcc.exe task shell
The second command starts to fetch stuff via the proxy, but then fails with
info     libmamba Download error (35) SSL connect error [https://conda.anaconda.org/conda-forge/noarch/repodata.json.zst]
    schannel: next InitializeSecurityContext failed: Unknown error (0x80092013) - The revocation function was unable to check revocation because the revocation server was offline.
This request should probably go to a Let’s Encrypt server, for which I don’t see an attempt in the proxy logs. On the other hand
openssl s_client -servername conda.anaconda.org -connect conda.anaconda.org:443 -crl_check
Verify return code: 3 (unable to get certificate CRL)
I am not so sure there is even a CRL to fetch at all. What am I missing here?
Hi Jörn,
how does your RCC profile config look like?
Regards, Simon
Straight out of the rule:
description: Robotmk RCC profile
settings:
  certificates:
    verify-ssl: false
    ssl-no-revoke: false
    legacy-renegotiation-allowed: false
  network:
    no-proxy: localhost,127.0.0.1
    https-proxy: http://proxy.xxx:3128
    http-proxy: http://proxy.xxx:3128
  meta:
    source: Robotmk
    version: ""
Looking at these values, I just tried
ssl-no-revoke: true
(double negations are always fun…), but the build still fails.
Unless reloading the profile is more complicated than simply repeating
@joernc , can you please DM me
  • conda.yaml
  • robot.yaml
  • the profile YAML
I will test this on another machine behind a proxy server.
Regards, Simon
