StartTLS FTP-Proxy Certificate Monitoring
I would like to monitor our FTP proxy. I can obtain the certificate using the command
openssl s_client -connect <hostname>:21 -starttls ftp -servername <hostname> -showcerts
However, in the active check “Check certificates”, the only options available for StartTLS are SMTP, Postgres, IMAP and LDAP. These options do not work, as the expected protocol on the remote end is FTP.
Does anyone know of a way to monitor StartTLS connections using the FTP protocol with CheckMK? Is it possible to submit this as a feature request?
We are on Checkmk Pro 2.5.0p6.
Kind regards,
Lukas
You can submit a new feature request on the Ideas portal
In the meantime, you could use any Nagios plugin like check_ssl_cert out there to monitor.
Thanks for your feedback. I submitted an idea request.
I would really appreciate it if this request received some upvotes.
