Hello Andreas,
You right, it seems there is some crash involved.
$ cmk --debug -vvII MyHost
Discovering services and host labels on: MyHost
MyHost:
+ FETCHING DATA
[cpu_tracking] Start [7f3c2992dd00]
Connecting via TCP to 192.168.0.1:6556 (5.0s timeout)
[cpu_tracking] Stop [7f3c2992dd00 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=5.010000001639128))]
Try aquire lock on /omd/sites/company/var/check_mk/crashes/base/5a7a9804-8c15-11eb-b8bc-000c29f47f56/crash.info
Got lock on /omd/sites/company/var/check_mk/crashes/base/5a7a9804-8c15-11eb-b8bc-000c29f47f56/crash.info
Releasing lock on /omd/sites/company/var/check_mk/crashes/base/5a7a9804-8c15-11eb-b8bc-000c29f47f56/crash.info
Released lock on /omd/sites/company/var/check_mk/crashes/base/5a7a9804-8c15-11eb-b8bc-000c29f47f56/crash.info
File "/omd/sites/company/bin/cmk", line 92, in <module>
File "/omd/sites/company/lib/python3/cmk/base/modes/__init__.py", line 69, in call
return handler(*handler_args)
File "/omd/sites/company/lib/python3/cmk/base/modes/check_mk.py", line 1531, in mode_discover
discovery.do_discovery(
File "/omd/sites/company/lib/python3/cmk/base/discovery.py", line 370, in do_discovery
fetcher_messages=list(
File "/omd/sites/company/lib/python3/cmk/base/checkers/_checkers.py", line 246, in fetch_all
raw_data = source.fetch()
File "/omd/sites/company/lib/python3/cmk/base/checkers/_abstract.py", line 162, in fetch
with self._make_fetcher() as fetcher:
File "/omd/sites/company/lib/python3/cmk/fetchers/_base.py", line 189, in __enter__
self.open()
File "/omd/sites/company/lib/python3/cmk/fetchers/tcp.py", line 73, in open
self._socket.connect(self.address)
socket.timeout: timed out
I see there is ton of file in /omd/sites/company/var/check_mk/crashes/[base]|[check] .
I did a omd stop, wipe of all the file, omd start, but same result
content of the crash file is
cat /omd/sites/company/var/check_mk/crashes/base/1341c83e-8c17-11eb-b748-000c29f47f56/crash.info
{"time": 1616531629.4787204, "os": "Debian GNU/Linux 10 (buster)", "version": "2.0.0p1", "edition": "cee", "core": "cmc", "python_version": "3.8.7 (default, Feb 3 2021, 02:52:08) \n[GCC 10.1.0]", "python_paths": ["/opt/omd/versions/2.0.0p1.cee/bin", "/omd/sites/company/local/lib/python3", "/omd/sites/company/lib/python38.zip", "/omd/sites/company/lib/python3.8", "/omd/sites/company/lib/python3.8/lib-dynload", "/omd/sites/company/lib/python3.8/site-packages", "/omd/sites/company/lib/python3"], "id": "1341c83e-8c17-11eb-b748-000c29f47f56", "crash_type": "base", "exc_type": "timeout", "exc_value": "timed out", "exc_traceback": [["/omd/sites/company/bin/cmk", 92, "<module>", "exit_status = modes.call(mode_name, mode_args, opts, args)"], ["/omd/sites/company/lib/python3/cmk/base/modes/__init__.py", 69, "call", "return handler(*handler_args)"], ["/omd/sites/company/lib/python3/cmk/base/modes/check_mk.py", 1531, "mode_discover", "discovery.do_discovery("], ["/omd/sites/company/lib/python3/cmk/base/discovery.py", 370, "do_discovery", "fetcher_messages=list("], ["/omd/sites/company/lib/python3/cmk/base/checkers/_checkers.py", 246, "fetch_all", "raw_data = source.fetch()"], ["/omd/sites/company/lib/python3/cmk/base/checkers/_abstract.py", 162, "fetch", "with self._make_fetcher() as fetcher:"], ["/omd/sites/company/lib/python3/cmk/fetchers/_base.py", 189, "__enter__", "self.open()"], ["/omd/sites/company/lib/python3/cmk/fetchers/tcp.py", 73, "open", "self._socket.connect(self.address)"]], "local_vars": "eydzxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx==", "details": {"argv": ["/omd/sites/company/bin/cmk", "--debug", "-vvII", "Myhost"], "env": {"SHELL": "/bin/bash", "OMD_ROOT": "/omd/sites/company", "NAGIOS_PLUGIN_STATE_DIRECTORY": "/omd/sites/company/var/monitoring-plugins", "PWD": "/omd/sites/company", "LOGNAME": "company", "MANPATH": "/omd/sites/company/share/man:", "MODULEBUILDRC": "/omd/sites/company/.modulebuildrc", "HOME": "/omd/sites/company", "LANG": "C.UTF-8", "PERL5LIB": "/omd/sites/company/local/lib/perl5/lib/perl5:/omd/sites/company/lib/perl5/lib/perl5:", "OMD_SITE": "company", "TERM": "xterm", "USER": "company", "PERL_MM_OPT": "INSTALL_BASE=/omd/sites/company/local/lib/perl5/", "SHLVL": "1", "LD_LIBRARY_PATH": "/omd/sites/company/local/lib:/omd/sites/company/lib", "REQUESTS_CA_BUNDLE": "/omd/sites/company/var/ssl/ca-certificates.crt", "LC_ALL": "C.UTF-8", "PATH": "/omd/sites/company/lib/perl5/bin:/omd/sites/company/local/bin:/omd/sites/company/bin:/omd/sites/company/local/lib/perl5/bin:/usr/local/bin:/usr/bin:/bin:/usr/local/games:/usr/games", "MP_STATE_DIRECTORY": "/omd/sites/company/var/monitoring-plugins", "MAIL": "/var/mail/company", "MAILRC": "/omd/sites/company/etc/mail.rc", "_": "/omd/sites/company/bin/cmk"}}}
Is this because the plugin need adapted to cmk2.0 or my host lack some ressource ?
