I tried the commands suggested and the user/passwords are correct, so I tried making my NAS (a QNAP) into a classic backend one and that got me further. However, when I run ‘cmk --debug -vvI’ command one of the snmpbulkwalks fails, the python script raise and exception and stops.
-I’ve tried to run the snmpbulkwalk command manually which also results in a timeout, to no one’s surprise…
As a new user, I’m not allowed to upload files, so I paste a the error received here. Is there anything I can do on the NAS or the OMD side to fix this, or is it possibly a bug?
Many thanks in advance!
qnap_disks: Fetching data (SNMP walk cache is disabled)
Running ‘snmpbulkwalk -Cr10 -v3 -l authPriv -a md5 -u -A -x DES -X -m “” -M “” -Cc -OQ -OU -On -Ot .1.3.6.1.4.1.24681.1.2.11.1.2’
Running ‘snmpbulkwalk -Cr10 -v3 -l authPriv -a md5 -u -A -x DES -X -m “” -M “” -Cc -OQ -OU -On -Ot .1.3.6.1.4.1.24681.1.2.11.1.3’
Running ‘snmpbulkwalk -Cr10 -v3 -l authPriv -a md5 -u -A -x DES -X -m “” -M “” -Cc -OQ -OU -On -Ot .1.3.6.1.4.1.24681.1.2.11.1.4’
Running ‘snmpbulkwalk -Cr10 -v3 -l authPriv -a md5 -u -A -x DES -X -m “” -M “” -Cc -OQ -OU -On -Ot .1.3.6.1.4.1.24681.1.2.11.1.5’
Running ‘snmpbulkwalk -Cr10 -v3 -l authPriv -a md5 -u -A -x DES -X -m “” -M “” -Cc -OQ -OU -On -Ot .1.3.6.1.4.1.24681.1.2.11.1.6’
Running ‘snmpbulkwalk -Cr10 -v3 -l authPriv -a md5 -u -A -x DES -X -m “” -M “” -Cc -OQ -OU -On -Ot .1.3.6.1.4.1.24681.1.2.11.1.7’
qnap_fans: Fetching data (SNMP walk cache is disabled)
Running ‘snmpbulkwalk -Cr10 -v3 -l authPriv -a md5 -u -A -x DES -X -m “” -M “” -Cc -OQ -OU -On -Ot .1.3.6.1.4.1.24681.1.2.15.1.3’
ERROR: SNMP error: Timeout: No Response from
[cpu_tracking] Stop [7fdcdbeb36d0 - Snapshot(process=posix.times_result(user=0.2799999999999998, system=0.26, children_user=3.13, children_system=0.35, elapsed=12.21000000089407))]
Trying to acquire lock on /omd/sites/mySite/var/check_mk/crashes/base/2ed188ce-c4af-11ec-a5cd-64006a3144f8/crash.info
Got lock on /omd/sites/mySite/var/check_mk/crashes/base/2ed188ce-c4af-11ec-a5cd-64006a3144f8/crash.info
Releasing lock on /omd/sites/mySite/var/check_mk/crashes/base/2ed188ce-c4af-11ec-a5cd-64006a3144f8/crash.info
Released lock on /omd/sites/mySite/var/check_mk/crashes/base/2ed188ce-c4af-11ec-a5cd-64006a3144f8/crash.info
File “/omd/sites/mySite/lib/python3/cmk/fetchers/snmp.py”, line 342, in _fetch_from_io
_from, until, _section = persisted_sections[section_name]
File “/omd/sites/mySite/lib/python3/cmk/fetchers/cache.py”, line 42, in getitem
return self._store.getitem(key)
KeyError: SectionName(‘qnap_fans’)
File “/omd/sites/mySite/bin/cmk”, line 92, in
File “/omd/sites/mySite/lib/python3/cmk/base/modes/init.py”, line 69, in call
return handler(*handler_args)
File “/omd/sites/mySite/lib/python3/cmk/base/modes/check_mk.py”, line 1542, in mode_discover
discovery.do_discovery(
File “/omd/sites/mySite/lib/python3/cmk/base/discovery.py”, line 370, in do_discovery
fetcher_messages=list(
File “/omd/sites/mySite/lib/python3/cmk/base/checkers/_checkers.py”, line 238, in fetch_all
raw_data = source.fetch()
File “/omd/sites/mySite/lib/python3/cmk/base/checkers/_abstract.py”, line 163, in fetch
return fetcher.fetch(self.mode)
File “/omd/sites/mySite/lib/python3/cmk/fetchers/_base.py”, line 268, in fetch
return result.OK(self._fetch(mode))
File “/omd/sites/mySite/lib/python3/cmk/fetchers/_base.py”, line 286, in _fetch
raw_data = self._fetch_from_io(mode)
File “/omd/sites/mySite/lib/python3/cmk/fetchers/snmp.py”, line 348, in _fetch_from_io
fetched_data[section_name] = [
File “/omd/sites/mySite/lib/python3/cmk/fetchers/snmp.py”, line 349, in
snmp_table.get_snmp_table(
File “/omd/sites/mySite/lib/python3/cmk/snmplib/snmp_table.py”, line 82, in get_snmp_table
rowinfo = _get_snmpwalk(
File “/omd/sites/mySite/lib/python3/cmk/snmplib/snmp_table.py”, line 188, in _get_snmpwalk
rowinfo = _perform_snmpwalk(section_name, base, fetchoid, backend=backend)
File “/omd/sites/mySite/lib/python3/cmk/snmplib/snmp_table.py”, line 204, in _perform_snmpwalk
rows = backend.walk(
File “/omd/sites/mySite/lib/python3/cmk/fetchers/snmp_backend/classic.py”, line 137, in walk
raise MKSNMPError(“SNMP Error on %s: %s (Exit-Code: %d)” %
cmk.utils.exceptions.MKSNMPError: SNMP Error on : Timeout: No Response from (Exit-Code: 1)
