Support for monitoring Room Alert 32S?
I have a Room Alert 32S, and I am trying to use CMK to monitor the sensors, however nothing is returned when the device is inventoried via SNMP.
Looks like CMK has integrations for 32E according to: AVTECH Room Alert 32E: Sensor Temperature (checkmk.com)
The issue is, 32E is EOL as of January 2024, and you can only buy 32S now.
Are there any plans to maintain this integration and support the latest RA 32S hardware?
We have a plugin for RA12, not sure if it works. Can send you a PN if you are interested.
regards
Mike
@mike1098 that would be great if you can share the plugin for RA12.
Hi @mike1098,
A plugin for RA12 sounds great. I have a RA12S here and I’d like to give it a try.
Thanks!
Okay, I just ended up using Checkmk Exchange and added a couple of OIDs that are interesting to my manually. This totally does the trick for me.
