Survey: Agent improvements
Hello Community!
My name is Andrea and I work in the Checkmk Product Management team.
Your feedback shapes what we build next!
We’re looking at how to make the Checkmk agent easier to configure, deploy, and update and we’d like to hear where it currently gets in your way through the following survey:
:arrow_right: Agent improvements :arrow_left:
The survey takes about 5-10 minutes, and the results go directly to the team working on agent improvements.
We’re constantly striving to improve Checkmk.
Thanks,
Andrea
thats something you should finally look into regarding agents and improve
https://ideas.checkmk.com/suggestions/306004/let-unix-agents-execute-sectionspluginslocal-checks-in-parallel
Also if you run into a timeout with a plugin or section, take the data you already collected and send it to the server instead of “loosing/dropping” all data you already collected
Cheers
D
Some nice ideas came up in this old thread Restructure the nix agents
I liked the idea that the agent would output JSON.
This would make it much easier to troubleshoot and compare, and filter agent outputs.
The current format with the <<<section>>> and <<<<piggibacked-host>>>>
still feels strange, even after years of working with them.
Some sections can appear mutliple times with the same name,
but with different sep() section attribute, it can be confusing e.g.:
$ check_mk_agent | grep '^<<<docker' | sort | uniq -c
     10 <<<docker_container_labels:sep(0):cached(1780471138,60)>>>
     10 <<<docker_container_labels:sep(124):cached(1780471138,60)>>>
     10 <<<docker_container_network:sep(0):cached(1780471138,60)>>>
     10 <<<docker_container_network:sep(124):cached(1780471138,60)>>>
     10 <<<docker_container_node_name:sep(0):cached(1780471138,60)>>>
     10 <<<docker_container_node_name:sep(124):cached(1780471138,60)>>>
     10 <<<docker_container_status:sep(0):cached(1780471138,60)>>>
     10 <<<docker_container_status:sep(124):cached(1780471138,60)>>>
Troubleshooting e.g. the agent output of the kubernetes special agent is a challange because of that, if you want to compare it with outputs from other clusters or versions.
Hi foobar,
thanks for your suggestions!
Andrea
Hi mimimi,
If you would like to give your suggestion more visibility, we invite you to post it in our Ideas Portal.
This will enable other users to vote on it, allowing us to prioritize it in a targeted manner in the future and, as appropriate, incorporate it into our strategic development planning.
Andrea
Hello Community!
A few weeks ago I shared a survey asking how we can make the Checkmk agent easier to configure, deploy, and update.
I just want to say a big thank you to all the users who took the time to answer — your feedback was incredibly valuable, and it’s now directly in the hands of the team working on agent improvements.
A special thanks as well to everyone who offered to be contacted for further steps — we may reach out for interviews and to test early ideas with you.
Thanks,
Andrea
