Switch Interface Speed Changed as Expected, Yet Status is Now Critical
check-mk-raw-2.1.0p21
RHEL 8.7
Howdy,
We have a few switches (Dell PowerConnect S5232F-ON) that were added and inventoried to our CheckMK Raw 2.1 server while we were still deploying the attached servers. At that time, the servers interfaces were inventoried as “down” and at “0GB/s”.
After provisioning and configuring the host interfaces, they are now connected at 100GB/s (as expected). Now the port interfaces for the servers show up as “(up)CRIT” and “Speed: 100 GBit/s (expected: 0 Bit/s)WARN”
cmk --debug -vvn s5232f-01
Interface host 9 rack1 Q28 NIC2 p1 23 [host 9 rack1 Q28 NIC2 p1/ethernet1/1/9], (up)(!!), MAC: 74:86:E2:XX:XX:XX, Speed: 100 GBit/s (expected: 0 Bit/s)(!), In: 0.00 B/s (0%), Out: 0.00 B/s (0%)
Interface host 9 rack1 Q28 NIC2 p1 65 [host 9 rack1 Q28 NIC2 p1/port-channel9], (up)(!!), MAC: 74:86:E2:YY:YY:YY, Speed: 100 GBit/s (expected: 0 Bit/s)(!), In: 0.00 B/s (0%), Out: 0.00 B/s (0%)
I’ve tried rescanning these switches, but can’t get the interfaces to change to OK status, accepting the UP status and 100GB/s speed.
Short of deleting the switches, which would also delete the history, is there anything else I can do to get CMK to accept the current state of the ports as the known good state?
Thanks, Mike
Move the service from monitored to undecided and back, and it will set to the current values.
Thanks
Unfortunately, it takes about 15 seconds for each service that I click to move to undecided, during which the ability to select the next service is grayed out. With approx 140 interfaces and port groups amongst 4 switches, that’s pretty durn tedious.
Too bad there isn’t an option to select multiple services and then move them as a group to undecided.
you need to click on this option.
It should reset all but be aware if you have some service for example down and it should be up (so it is in critical state)and you do this than it will change it state to ok
best regards,
JF
let’s start in the Display-menu and show the checkboxes:
forum1
Select the interfaces you want to move and then continue in the Action-menu.
Karl
Thanks, I didn’t even notice the Display menu!
Thanks, this worked and maintained the graph history for all of the services.
Hi! If someone’s answer resolved your issue, please consider taking a moment to mark it as a solution – this will show everyone else that the question is resolved + it will show appreciation to the person who helped :slight_smile:
