Due to the preferred one-way communication I do not use TLS but I use <Symmetric encryption (Linux, Windows).> Are there any limitations of using Symmetric encryption (Linux, Windows), how much it loads the server CPU, RAM, can it be estimated somehow, ultimately I would like to connect to about 1000 , each host will have a separate secret. Will using the same secret by a group of hosts significantly reduce the load on the checkmk server? Thank you in advance for any information.
