CMK version: 2.2.0p5
OS version: Centos 8.5
Error message: Allocation status: not initialized
Hi everybody,
i need a kind help for a little annoying thing.
I’m monitoring a synology storage with 2 cache disks.
these cache disks are correctly not initialized by the storage, but checkmk throws a warning state because of it, and i cannot force it as “OK” in WATO because is says that “This check is not configurable via WATO”.
below a screenshot of what i mean.
Could someone please help me get me through this?
Thank you all in advance.
Thomas
r.sander
(Robert Sander)
August 4, 2023, 9:29am
2
Why not just set an acknowledgment on the service and be good with it?
Hi Robert, thanks for replying.
i cannot just set an acknowledgment on “allocation status” because the parameters are not configurable by WATO (screen below)
also, i’m afraid that if i set an ack on the entire service, then if something wrong will occurs to the disk i’ll not be warned about. Please correct me if i’m wrong.
best regards,
Thomas
This is a very old bug inside the Synology disk check.
At discovery time the check must remember the disk state and compare this to the actual one. Not initialized is perfectly fine if this is a spare disk and should not be displayed as WARN.
Yes Andreas, in fact i’ve read other topics about this same issue, but never solved.
If this problem is not fixable for some reasons, would be very confy to make this check configurable by WATO and have the possibility to put the “Allocation status” as alwasy ok…
Thanks everyone for the replies so far.
thomflipx8
(Thomflipx8)
November 2, 2023, 10:22am
6
Could someone of the CheckMK team follow up on this?
i think it’s a little thing that could make many people happy.
bests,
Thomas
Sara
November 3, 2023, 3:41pm
7
Hello Thomflipx8,
There was, indeed, an old bug regarding Synology, that was fixed this March: https://checkmk.com/werk/15280 .
Now, if the status of the disk is transferred correctly as hotspare or as ssd-cache in the SNMP walk, the warning is not displayed, when device is not initialized.
Keep in mind that the Synology firmware was also not reporting the states correctly for some time. From some customers we know that this has been fixed in the latest Synology firmware.
Nevertheless, unfortunately, we cannot know how Synology device transfers the information about the disk configuration in every case and in each hardware version, so in cases where the device is not directly stating that it is one of the above (hotspare or ssd-cache) Checkmk is reacting as it would by default to a non-initialized disk.
Please take into account that what is being reported by Synology via the interface we are using might not be consistent to what Synoglogy shows is the admin UI.
tilgeh
April 12, 2024, 6:32am
8
Hi Sara,
We have a Synology SA3600 with some Expansion Units. Hot Spare Disks in the Main Unit get interpreted correctly in Checkmk, but Hot Spare Disks located on an Expansion Unit are displayed as ‘Warning: Not Initialized.’ We have installed the latest DSM and Expansion Firmware updates.
Is it possible that this is a bug in Checkmk?
Can you share the snmpwalk for these ID’s?
> fetch=SNMPTree(
> base=".1.3.6.1.4.1.6574.2.1.1",
> oids=[
> "2", # SYNOLOGY-DISK-MIB::diskID
> "3", # SYNOLOGY-DISK-MIB::diskModel
> "5", # SYNOLOGY-DISK-MIB::diskStatus
> "6", # SYNOLOGY-DISK-MIB::diskTemperature
> "7", # diskRole (available from DSM 7.0 and above)
> # data => Used by storage pool
> # hotspare => Assigned as a hot spare disk
> # ssd_cache => Used by SSD Cache
> # none => Not used by storage pool, nor hot spare, nor SSD Cache
> # unknown => Some error occurred
> "13", # diskHealthStatus (available from DSM 7.1 and above)
Maybe we can then look what’s wrong?
Also, whats the DSM version ?
tilgeh
April 12, 2024, 12:34pm
11
The DSM Version is: DSM 7.2.1-69057 Update 4
And the Snmp Walk is:
.1.3.6.1.4.1.6574.2.1.1.1.0 0
.1.3.6.1.4.1.6574.2.1.1.1.1 1
.1.3.6.1.4.1.6574.2.1.1.1.2 2
.1.3.6.1.4.1.6574.2.1.1.1.3 3
.1.3.6.1.4.1.6574.2.1.1.1.4 4
.1.3.6.1.4.1.6574.2.1.1.1.5 5
.1.3.6.1.4.1.6574.2.1.1.1.6 6
.1.3.6.1.4.1.6574.2.1.1.1.7 7
.1.3.6.1.4.1.6574.2.1.1.1.8 8
.1.3.6.1.4.1.6574.2.1.1.1.9 9
.1.3.6.1.4.1.6574.2.1.1.1.10 10
.1.3.6.1.4.1.6574.2.1.1.1.11 11
.1.3.6.1.4.1.6574.2.1.1.1.12 12
.1.3.6.1.4.1.6574.2.1.1.1.13 13
.1.3.6.1.4.1.6574.2.1.1.1.14 14
.1.3.6.1.4.1.6574.2.1.1.1.15 15
.1.3.6.1.4.1.6574.2.1.1.1.16 16
.1.3.6.1.4.1.6574.2.1.1.1.17 17
.1.3.6.1.4.1.6574.2.1.1.1.18 18
.1.3.6.1.4.1.6574.2.1.1.1.19 19
.1.3.6.1.4.1.6574.2.1.1.1.20 20
.1.3.6.1.4.1.6574.2.1.1.1.21 21
.1.3.6.1.4.1.6574.2.1.1.1.22 22
.1.3.6.1.4.1.6574.2.1.1.1.23 23
.1.3.6.1.4.1.6574.2.1.1.1.24 24
.1.3.6.1.4.1.6574.2.1.1.1.25 25
.1.3.6.1.4.1.6574.2.1.1.1.26 26
.1.3.6.1.4.1.6574.2.1.1.1.27 27
.1.3.6.1.4.1.6574.2.1.1.1.28 28
.1.3.6.1.4.1.6574.2.1.1.1.29 29
.1.3.6.1.4.1.6574.2.1.1.1.30 30
.1.3.6.1.4.1.6574.2.1.1.1.31 31
.1.3.6.1.4.1.6574.2.1.1.1.32 32
.1.3.6.1.4.1.6574.2.1.1.1.33 33
.1.3.6.1.4.1.6574.2.1.1.1.34 34
.1.3.6.1.4.1.6574.2.1.1.1.35 35
.1.3.6.1.4.1.6574.2.1.1.1.36 36
.1.3.6.1.4.1.6574.2.1.1.1.37 37
.1.3.6.1.4.1.6574.2.1.1.1.38 38
.1.3.6.1.4.1.6574.2.1.1.1.39 39
.1.3.6.1.4.1.6574.2.1.1.1.40 40
.1.3.6.1.4.1.6574.2.1.1.1.41 41
.1.3.6.1.4.1.6574.2.1.1.1.42 42
.1.3.6.1.4.1.6574.2.1.1.1.43 43
.1.3.6.1.4.1.6574.2.1.1.1.44 44
.1.3.6.1.4.1.6574.2.1.1.1.45 45
.1.3.6.1.4.1.6574.2.1.1.1.46 46
.1.3.6.1.4.1.6574.2.1.1.1.47 47
.1.3.6.1.4.1.6574.2.1.1.1.48 48
.1.3.6.1.4.1.6574.2.1.1.1.49 49
.1.3.6.1.4.1.6574.2.1.1.1.50 50
.1.3.6.1.4.1.6574.2.1.1.1.51 51
.1.3.6.1.4.1.6574.2.1.1.1.52 52
.1.3.6.1.4.1.6574.2.1.1.1.53 53
.1.3.6.1.4.1.6574.2.1.1.1.54 54
.1.3.6.1.4.1.6574.2.1.1.1.55 55
.1.3.6.1.4.1.6574.2.1.1.1.56 56
.1.3.6.1.4.1.6574.2.1.1.1.57 57
.1.3.6.1.4.1.6574.2.1.1.1.58 58
.1.3.6.1.4.1.6574.2.1.1.1.59 59
.1.3.6.1.4.1.6574.2.1.1.1.60 60
.1.3.6.1.4.1.6574.2.1.1.1.61 61
.1.3.6.1.4.1.6574.2.1.1.1.62 62
.1.3.6.1.4.1.6574.2.1.1.1.63 63
.1.3.6.1.4.1.6574.2.1.1.1.64 64
.1.3.6.1.4.1.6574.2.1.1.1.65 65
.1.3.6.1.4.1.6574.2.1.1.1.66 66
.1.3.6.1.4.1.6574.2.1.1.1.67 67
.1.3.6.1.4.1.6574.2.1.1.1.68 68
.1.3.6.1.4.1.6574.2.1.1.1.69 69
.1.3.6.1.4.1.6574.2.1.1.1.70 70
.1.3.6.1.4.1.6574.2.1.1.1.71 71
.1.3.6.1.4.1.6574.2.1.1.1.72 72
.1.3.6.1.4.1.6574.2.1.1.1.73 73
.1.3.6.1.4.1.6574.2.1.1.1.74 74
.1.3.6.1.4.1.6574.2.1.1.1.75 75
.1.3.6.1.4.1.6574.2.1.1.1.76 76
.1.3.6.1.4.1.6574.2.1.1.1.77 77
.1.3.6.1.4.1.6574.2.1.1.1.78 78
.1.3.6.1.4.1.6574.2.1.1.1.79 79
.1.3.6.1.4.1.6574.2.1.1.1.80 80
.1.3.6.1.4.1.6574.2.1.1.1.81 81
.1.3.6.1.4.1.6574.2.1.1.1.82 82
.1.3.6.1.4.1.6574.2.1.1.1.83 83
.1.3.6.1.4.1.6574.2.1.1.1.84 84
.1.3.6.1.4.1.6574.2.1.1.1.85 85
.1.3.6.1.4.1.6574.2.1.1.1.86 86
.1.3.6.1.4.1.6574.2.1.1.1.87 87
.1.3.6.1.4.1.6574.2.1.1.1.88 88
.1.3.6.1.4.1.6574.2.1.1.1.89 89
.1.3.6.1.4.1.6574.2.1.1.1.90 90
.1.3.6.1.4.1.6574.2.1.1.1.91 91
.1.3.6.1.4.1.6574.2.1.1.1.92 92
.1.3.6.1.4.1.6574.2.1.1.1.93 93
.1.3.6.1.4.1.6574.2.1.1.1.94 94
.1.3.6.1.4.1.6574.2.1.1.1.95 95
.1.3.6.1.4.1.6574.2.1.1.2.0 Disk 11
.1.3.6.1.4.1.6574.2.1.1.2.1 Disk 4
.1.3.6.1.4.1.6574.2.1.1.2.2 Disk 3
.1.3.6.1.4.1.6574.2.1.1.2.3 Disk 2
.1.3.6.1.4.1.6574.2.1.1.2.4 Disk 6
.1.3.6.1.4.1.6574.2.1.1.2.5 Disk 10
.1.3.6.1.4.1.6574.2.1.1.2.6 Disk 9
.1.3.6.1.4.1.6574.2.1.1.2.7 Disk 1
.1.3.6.1.4.1.6574.2.1.1.2.8 Disk 5
.1.3.6.1.4.1.6574.2.1.1.2.9 Disk 8
.1.3.6.1.4.1.6574.2.1.1.2.10 Disk 12
.1.3.6.1.4.1.6574.2.1.1.2.11 Disk 7
.1.3.6.1.4.1.6574.2.1.1.2.12 (Expansion Unit 1) Disk 10
.1.3.6.1.4.1.6574.2.1.1.2.13 (Expansion Unit 1) Disk 5
.1.3.6.1.4.1.6574.2.1.1.2.14 (Expansion Unit 1) Disk 9
.1.3.6.1.4.1.6574.2.1.1.2.15 (Expansion Unit 1) Disk 1
.1.3.6.1.4.1.6574.2.1.1.2.16 (Expansion Unit 1) Disk 11
.1.3.6.1.4.1.6574.2.1.1.2.17 (Expansion Unit 1) Disk 4
.1.3.6.1.4.1.6574.2.1.1.2.18 (Expansion Unit 1) Disk 8
.1.3.6.1.4.1.6574.2.1.1.2.19 (Expansion Unit 1) Disk 12
.1.3.6.1.4.1.6574.2.1.1.2.20 (Expansion Unit 1) Disk 6
.1.3.6.1.4.1.6574.2.1.1.2.21 (Expansion Unit 1) Disk 2
.1.3.6.1.4.1.6574.2.1.1.2.22 (Expansion Unit 1) Disk 7
.1.3.6.1.4.1.6574.2.1.1.2.23 (Expansion Unit 1) Disk 3
.1.3.6.1.4.1.6574.2.1.1.2.24 (Expansion Unit 2) Disk 10
.1.3.6.1.4.1.6574.2.1.1.2.25 (Expansion Unit 2) Disk 5
.1.3.6.1.4.1.6574.2.1.1.2.26 (Expansion Unit 2) Disk 9
.1.3.6.1.4.1.6574.2.1.1.2.27 (Expansion Unit 2) Disk 1
.1.3.6.1.4.1.6574.2.1.1.2.28 (Expansion Unit 2) Disk 11
.1.3.6.1.4.1.6574.2.1.1.2.29 (Expansion Unit 2) Disk 4
.1.3.6.1.4.1.6574.2.1.1.2.30 (Expansion Unit 2) Disk 8
.1.3.6.1.4.1.6574.2.1.1.2.31 (Expansion Unit 2) Disk 12
.1.3.6.1.4.1.6574.2.1.1.2.32 (Expansion Unit 2) Disk 6
.1.3.6.1.4.1.6574.2.1.1.2.33 (Expansion Unit 2) Disk 2
.1.3.6.1.4.1.6574.2.1.1.2.34 (Expansion Unit 2) Disk 7
.1.3.6.1.4.1.6574.2.1.1.2.35 (Expansion Unit 2) Disk 3
.1.3.6.1.4.1.6574.2.1.1.2.36 (Expansion Unit 3) Disk 10
.1.3.6.1.4.1.6574.2.1.1.2.37 (Expansion Unit 3) Disk 5
.1.3.6.1.4.1.6574.2.1.1.2.38 (Expansion Unit 3) Disk 9
.1.3.6.1.4.1.6574.2.1.1.2.39 (Expansion Unit 3) Disk 1
.1.3.6.1.4.1.6574.2.1.1.2.40 (Expansion Unit 3) Disk 11
.1.3.6.1.4.1.6574.2.1.1.2.41 (Expansion Unit 3) Disk 4
.1.3.6.1.4.1.6574.2.1.1.2.42 (Expansion Unit 3) Disk 8
.1.3.6.1.4.1.6574.2.1.1.2.43 (Expansion Unit 3) Disk 12
.1.3.6.1.4.1.6574.2.1.1.2.44 (Expansion Unit 3) Disk 6
.1.3.6.1.4.1.6574.2.1.1.2.45 (Expansion Unit 3) Disk 2
.1.3.6.1.4.1.6574.2.1.1.2.46 (Expansion Unit 3) Disk 7
.1.3.6.1.4.1.6574.2.1.1.2.47 (Expansion Unit 3) Disk 3
.1.3.6.1.4.1.6574.2.1.1.2.48 (Expansion Unit 4) Disk 10
.1.3.6.1.4.1.6574.2.1.1.2.49 (Expansion Unit 4) Disk 5
.1.3.6.1.4.1.6574.2.1.1.2.50 (Expansion Unit 4) Disk 9
.1.3.6.1.4.1.6574.2.1.1.2.51 (Expansion Unit 4) Disk 1
.1.3.6.1.4.1.6574.2.1.1.2.52 (Expansion Unit 4) Disk 11
.1.3.6.1.4.1.6574.2.1.1.2.53 (Expansion Unit 4) Disk 4
.1.3.6.1.4.1.6574.2.1.1.2.54 (Expansion Unit 4) Disk 8
.1.3.6.1.4.1.6574.2.1.1.2.55 (Expansion Unit 4) Disk 12
.1.3.6.1.4.1.6574.2.1.1.2.56 (Expansion Unit 4) Disk 6
.1.3.6.1.4.1.6574.2.1.1.2.57 (Expansion Unit 4) Disk 2
.1.3.6.1.4.1.6574.2.1.1.2.58 (Expansion Unit 4) Disk 7
.1.3.6.1.4.1.6574.2.1.1.2.59 (Expansion Unit 4) Disk 3
.1.3.6.1.4.1.6574.2.1.1.2.60 (Expansion Unit 5) Disk 10
.1.3.6.1.4.1.6574.2.1.1.2.61 (Expansion Unit 5) Disk 5
.1.3.6.1.4.1.6574.2.1.1.2.62 (Expansion Unit 5) Disk 9
.1.3.6.1.4.1.6574.2.1.1.2.63 (Expansion Unit 5) Disk 1
.1.3.6.1.4.1.6574.2.1.1.2.64 (Expansion Unit 5) Disk 11
.1.3.6.1.4.1.6574.2.1.1.2.65 (Expansion Unit 5) Disk 4
.1.3.6.1.4.1.6574.2.1.1.2.66 (Expansion Unit 5) Disk 8
.1.3.6.1.4.1.6574.2.1.1.2.67 (Expansion Unit 5) Disk 12
.1.3.6.1.4.1.6574.2.1.1.2.68 (Expansion Unit 5) Disk 6
.1.3.6.1.4.1.6574.2.1.1.2.69 (Expansion Unit 5) Disk 2
.1.3.6.1.4.1.6574.2.1.1.2.70 (Expansion Unit 5) Disk 7
.1.3.6.1.4.1.6574.2.1.1.2.71 (Expansion Unit 5) Disk 3
.1.3.6.1.4.1.6574.2.1.1.2.72 (Expansion Unit 6) Disk 10
.1.3.6.1.4.1.6574.2.1.1.2.73 (Expansion Unit 6) Disk 5
.1.3.6.1.4.1.6574.2.1.1.2.74 (Expansion Unit 6) Disk 9
.1.3.6.1.4.1.6574.2.1.1.2.75 (Expansion Unit 6) Disk 1
.1.3.6.1.4.1.6574.2.1.1.2.76 (Expansion Unit 6) Disk 11
.1.3.6.1.4.1.6574.2.1.1.2.77 (Expansion Unit 6) Disk 4
.1.3.6.1.4.1.6574.2.1.1.2.78 (Expansion Unit 6) Disk 8
.1.3.6.1.4.1.6574.2.1.1.2.79 (Expansion Unit 6) Disk 12
.1.3.6.1.4.1.6574.2.1.1.2.80 (Expansion Unit 6) Disk 6
.1.3.6.1.4.1.6574.2.1.1.2.81 (Expansion Unit 6) Disk 2
.1.3.6.1.4.1.6574.2.1.1.2.82 (Expansion Unit 6) Disk 7
.1.3.6.1.4.1.6574.2.1.1.2.83 (Expansion Unit 6) Disk 3
.1.3.6.1.4.1.6574.2.1.1.2.84 (Expansion Unit 7) Disk 10
.1.3.6.1.4.1.6574.2.1.1.2.85 (Expansion Unit 7) Disk 5
.1.3.6.1.4.1.6574.2.1.1.2.86 (Expansion Unit 7) Disk 9
.1.3.6.1.4.1.6574.2.1.1.2.87 (Expansion Unit 7) Disk 1
.1.3.6.1.4.1.6574.2.1.1.2.88 (Expansion Unit 7) Disk 11
.1.3.6.1.4.1.6574.2.1.1.2.89 (Expansion Unit 7) Disk 4
.1.3.6.1.4.1.6574.2.1.1.2.90 (Expansion Unit 7) Disk 8
.1.3.6.1.4.1.6574.2.1.1.2.91 (Expansion Unit 7) Disk 12
.1.3.6.1.4.1.6574.2.1.1.2.92 (Expansion Unit 7) Disk 6
.1.3.6.1.4.1.6574.2.1.1.2.93 (Expansion Unit 7) Disk 2
.1.3.6.1.4.1.6574.2.1.1.2.94 (Expansion Unit 7) Disk 7
.1.3.6.1.4.1.6574.2.1.1.2.95 (Expansion Unit 7) Disk 3
.1.3.6.1.4.1.6574.2.1.1.3.0 ST16000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.1 ST16000NM004J
.1.3.6.1.4.1.6574.2.1.1.3.2 ST16000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.3 ST16000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.4 ST16000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.5 ST16000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.6 ST16000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.7 ST16000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.8 ST16000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.9 ST16000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.10 ST16000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.11 ST16000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.12 ST16000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.13 ST16000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.14 ST16000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.15 ST16000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.16 ST16000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.17 ST16000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.18 ST16000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.19 ST16000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.20 ST16000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.21 ST16000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.22 ST16000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.23 ST16000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.24 ST16000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.25 ST16000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.26 ST16000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.27 ST16000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.28 ST16000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.29 ST16000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.30 ST16000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.31 ST16000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.32 ST16000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.33 ST16000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.34 ST16000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.35 ST16000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.36 ST16000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.37 ST16000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.38 ST16000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.39 ST16000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.40 ST16000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.41 ST16000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.42 ST16000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.43 ST16000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.44 ST16000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.45 ST16000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.46 ST16000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.47 ST16000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.48 ST16000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.49 ST16000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.50 ST16000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.51 ST16000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.52 ST16000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.53 ST16000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.54 ST16000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.55 ST16000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.56 ST16000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.57 ST16000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.58 ST16000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.59 ST16000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.60 ST14000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.61 ST14000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.62 ST14000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.63 ST14000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.64 ST14000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.65 ST14000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.66 ST14000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.67 ST14000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.68 ST14000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.69 ST14000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.70 ST14000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.71 ST14000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.72 ST14000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.73 ST14000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.74 ST14000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.75 ST14000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.76 ST14000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.77 ST14000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.78 ST14000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.79 ST14000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.80 ST14000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.81 ST14000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.82 ST14000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.83 ST14000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.84 ST16000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.85 ST16000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.86 ST16000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.87 ST16000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.88 ST16000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.89 ST16000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.90 ST16000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.91 ST16000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.92 ST16000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.93 ST16000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.94 ST16000NM002G
.1.3.6.1.4.1.6574.2.1.1.3.95 ST16000NM002G
.1.3.6.1.4.1.6574.2.1.1.4.0 SAS
.1.3.6.1.4.1.6574.2.1.1.4.1 SAS
.1.3.6.1.4.1.6574.2.1.1.4.2 SAS
.1.3.6.1.4.1.6574.2.1.1.4.3 SAS
.1.3.6.1.4.1.6574.2.1.1.4.4 SAS
.1.3.6.1.4.1.6574.2.1.1.4.5 SAS
.1.3.6.1.4.1.6574.2.1.1.4.6 SAS
.1.3.6.1.4.1.6574.2.1.1.4.7 SAS
.1.3.6.1.4.1.6574.2.1.1.4.8 SAS
.1.3.6.1.4.1.6574.2.1.1.4.9 SAS
.1.3.6.1.4.1.6574.2.1.1.4.10 SAS
.1.3.6.1.4.1.6574.2.1.1.4.11 SAS
.1.3.6.1.4.1.6574.2.1.1.4.12 SAS
.1.3.6.1.4.1.6574.2.1.1.4.13 SAS
.1.3.6.1.4.1.6574.2.1.1.4.14 SAS
.1.3.6.1.4.1.6574.2.1.1.4.15 SAS
.1.3.6.1.4.1.6574.2.1.1.4.16 SAS
.1.3.6.1.4.1.6574.2.1.1.4.17 SAS
.1.3.6.1.4.1.6574.2.1.1.4.18 SAS
.1.3.6.1.4.1.6574.2.1.1.4.19 SAS
.1.3.6.1.4.1.6574.2.1.1.4.20 SAS
.1.3.6.1.4.1.6574.2.1.1.4.21 SAS
.1.3.6.1.4.1.6574.2.1.1.4.22 SAS
.1.3.6.1.4.1.6574.2.1.1.4.23 SAS
.1.3.6.1.4.1.6574.2.1.1.4.24 SAS
.1.3.6.1.4.1.6574.2.1.1.4.25 SAS
.1.3.6.1.4.1.6574.2.1.1.4.26 SAS
.1.3.6.1.4.1.6574.2.1.1.4.27 SAS
.1.3.6.1.4.1.6574.2.1.1.4.28 SAS
.1.3.6.1.4.1.6574.2.1.1.4.29 SAS
.1.3.6.1.4.1.6574.2.1.1.4.30 SAS
.1.3.6.1.4.1.6574.2.1.1.4.31 SAS
.1.3.6.1.4.1.6574.2.1.1.4.32 SAS
.1.3.6.1.4.1.6574.2.1.1.4.33 SAS
.1.3.6.1.4.1.6574.2.1.1.4.34 SAS
.1.3.6.1.4.1.6574.2.1.1.4.35 SAS
.1.3.6.1.4.1.6574.2.1.1.4.36 SAS
.1.3.6.1.4.1.6574.2.1.1.4.37 SAS
.1.3.6.1.4.1.6574.2.1.1.4.38 SAS
.1.3.6.1.4.1.6574.2.1.1.4.39 SAS
.1.3.6.1.4.1.6574.2.1.1.4.40 SAS
.1.3.6.1.4.1.6574.2.1.1.4.41 SAS
.1.3.6.1.4.1.6574.2.1.1.4.42 SAS
.1.3.6.1.4.1.6574.2.1.1.4.43 SAS
.1.3.6.1.4.1.6574.2.1.1.4.44 SAS
.1.3.6.1.4.1.6574.2.1.1.4.45 SAS
.1.3.6.1.4.1.6574.2.1.1.4.46 SAS
.1.3.6.1.4.1.6574.2.1.1.4.47 SAS
.1.3.6.1.4.1.6574.2.1.1.4.48 SAS
.1.3.6.1.4.1.6574.2.1.1.4.49 SAS
.1.3.6.1.4.1.6574.2.1.1.4.50 SAS
.1.3.6.1.4.1.6574.2.1.1.4.51 SAS
.1.3.6.1.4.1.6574.2.1.1.4.52 SAS
.1.3.6.1.4.1.6574.2.1.1.4.53 SAS
.1.3.6.1.4.1.6574.2.1.1.4.54 SAS
.1.3.6.1.4.1.6574.2.1.1.4.55 SAS
.1.3.6.1.4.1.6574.2.1.1.4.56 SAS
.1.3.6.1.4.1.6574.2.1.1.4.57 SAS
.1.3.6.1.4.1.6574.2.1.1.4.58 SAS
.1.3.6.1.4.1.6574.2.1.1.4.59 SAS
.1.3.6.1.4.1.6574.2.1.1.4.60 SAS
.1.3.6.1.4.1.6574.2.1.1.4.61 SAS
.1.3.6.1.4.1.6574.2.1.1.4.62 SAS
.1.3.6.1.4.1.6574.2.1.1.4.63 SAS
.1.3.6.1.4.1.6574.2.1.1.4.64 SAS
.1.3.6.1.4.1.6574.2.1.1.4.65 SAS
.1.3.6.1.4.1.6574.2.1.1.4.66 SAS
.1.3.6.1.4.1.6574.2.1.1.4.67 SAS
.1.3.6.1.4.1.6574.2.1.1.4.68 SAS
.1.3.6.1.4.1.6574.2.1.1.4.69 SAS
.1.3.6.1.4.1.6574.2.1.1.4.70 SAS
.1.3.6.1.4.1.6574.2.1.1.4.71 SAS
.1.3.6.1.4.1.6574.2.1.1.4.72 SAS
.1.3.6.1.4.1.6574.2.1.1.4.73 SAS
.1.3.6.1.4.1.6574.2.1.1.4.74 SAS
.1.3.6.1.4.1.6574.2.1.1.4.75 SAS
.1.3.6.1.4.1.6574.2.1.1.4.76 SAS
.1.3.6.1.4.1.6574.2.1.1.4.77 SAS
.1.3.6.1.4.1.6574.2.1.1.4.78 SAS
.1.3.6.1.4.1.6574.2.1.1.4.79 SAS
.1.3.6.1.4.1.6574.2.1.1.4.80 SAS
.1.3.6.1.4.1.6574.2.1.1.4.81 SAS
.1.3.6.1.4.1.6574.2.1.1.4.82 SAS
.1.3.6.1.4.1.6574.2.1.1.4.83 SAS
.1.3.6.1.4.1.6574.2.1.1.4.84 SAS
.1.3.6.1.4.1.6574.2.1.1.4.85 SAS
.1.3.6.1.4.1.6574.2.1.1.4.86 SAS
.1.3.6.1.4.1.6574.2.1.1.4.87 SAS
.1.3.6.1.4.1.6574.2.1.1.4.88 SAS
.1.3.6.1.4.1.6574.2.1.1.4.89 SAS
.1.3.6.1.4.1.6574.2.1.1.4.90 SAS
.1.3.6.1.4.1.6574.2.1.1.4.91 SAS
.1.3.6.1.4.1.6574.2.1.1.4.92 SAS
.1.3.6.1.4.1.6574.2.1.1.4.93 SAS
.1.3.6.1.4.1.6574.2.1.1.4.94 SAS
.1.3.6.1.4.1.6574.2.1.1.4.95 SAS
.1.3.6.1.4.1.6574.2.1.1.5.0 1
.1.3.6.1.4.1.6574.2.1.1.5.1 1
.1.3.6.1.4.1.6574.2.1.1.5.2 1
.1.3.6.1.4.1.6574.2.1.1.5.3 1
.1.3.6.1.4.1.6574.2.1.1.5.4 1
.1.3.6.1.4.1.6574.2.1.1.5.5 1
.1.3.6.1.4.1.6574.2.1.1.5.6 1
.1.3.6.1.4.1.6574.2.1.1.5.7 1
.1.3.6.1.4.1.6574.2.1.1.5.8 1
.1.3.6.1.4.1.6574.2.1.1.5.9 1
.1.3.6.1.4.1.6574.2.1.1.5.10 1
.1.3.6.1.4.1.6574.2.1.1.5.11 1
.1.3.6.1.4.1.6574.2.1.1.5.12 1
.1.3.6.1.4.1.6574.2.1.1.5.13 1
.1.3.6.1.4.1.6574.2.1.1.5.14 1
.1.3.6.1.4.1.6574.2.1.1.5.15 1
.1.3.6.1.4.1.6574.2.1.1.5.16 1
.1.3.6.1.4.1.6574.2.1.1.5.17 1
.1.3.6.1.4.1.6574.2.1.1.5.18 1
.1.3.6.1.4.1.6574.2.1.1.5.19 1
.1.3.6.1.4.1.6574.2.1.1.5.20 1
.1.3.6.1.4.1.6574.2.1.1.5.21 1
.1.3.6.1.4.1.6574.2.1.1.5.22 1
.1.3.6.1.4.1.6574.2.1.1.5.23 1
.1.3.6.1.4.1.6574.2.1.1.5.24 1
.1.3.6.1.4.1.6574.2.1.1.5.25 1
.1.3.6.1.4.1.6574.2.1.1.5.26 1
.1.3.6.1.4.1.6574.2.1.1.5.27 1
.1.3.6.1.4.1.6574.2.1.1.5.28 1
.1.3.6.1.4.1.6574.2.1.1.5.29 3
.1.3.6.1.4.1.6574.2.1.1.5.30 1
.1.3.6.1.4.1.6574.2.1.1.5.31 3
.1.3.6.1.4.1.6574.2.1.1.5.32 1
.1.3.6.1.4.1.6574.2.1.1.5.33 1
.1.3.6.1.4.1.6574.2.1.1.5.34 1
.1.3.6.1.4.1.6574.2.1.1.5.35 1
.1.3.6.1.4.1.6574.2.1.1.5.36 1
.1.3.6.1.4.1.6574.2.1.1.5.37 1
.1.3.6.1.4.1.6574.2.1.1.5.38 1
.1.3.6.1.4.1.6574.2.1.1.5.39 1
.1.3.6.1.4.1.6574.2.1.1.5.40 1
.1.3.6.1.4.1.6574.2.1.1.5.41 1
.1.3.6.1.4.1.6574.2.1.1.5.42 1
.1.3.6.1.4.1.6574.2.1.1.5.43 1
.1.3.6.1.4.1.6574.2.1.1.5.44 1
.1.3.6.1.4.1.6574.2.1.1.5.45 1
.1.3.6.1.4.1.6574.2.1.1.5.46 1
.1.3.6.1.4.1.6574.2.1.1.5.47 1
.1.3.6.1.4.1.6574.2.1.1.5.48 1
.1.3.6.1.4.1.6574.2.1.1.5.49 1
.1.3.6.1.4.1.6574.2.1.1.5.50 1
.1.3.6.1.4.1.6574.2.1.1.5.51 1
.1.3.6.1.4.1.6574.2.1.1.5.52 1
.1.3.6.1.4.1.6574.2.1.1.5.53 1
.1.3.6.1.4.1.6574.2.1.1.5.54 1
.1.3.6.1.4.1.6574.2.1.1.5.55 1
.1.3.6.1.4.1.6574.2.1.1.5.56 1
.1.3.6.1.4.1.6574.2.1.1.5.57 1
.1.3.6.1.4.1.6574.2.1.1.5.58 1
.1.3.6.1.4.1.6574.2.1.1.5.59 1
.1.3.6.1.4.1.6574.2.1.1.5.60 1
.1.3.6.1.4.1.6574.2.1.1.5.61 1
.1.3.6.1.4.1.6574.2.1.1.5.62 1
.1.3.6.1.4.1.6574.2.1.1.5.63 1
.1.3.6.1.4.1.6574.2.1.1.5.64 1
.1.3.6.1.4.1.6574.2.1.1.5.65 1
.1.3.6.1.4.1.6574.2.1.1.5.66 1
.1.3.6.1.4.1.6574.2.1.1.5.67 1
.1.3.6.1.4.1.6574.2.1.1.5.68 1
.1.3.6.1.4.1.6574.2.1.1.5.69 1
.1.3.6.1.4.1.6574.2.1.1.5.70 1
.1.3.6.1.4.1.6574.2.1.1.5.71 1
.1.3.6.1.4.1.6574.2.1.1.5.72 1
.1.3.6.1.4.1.6574.2.1.1.5.73 1
.1.3.6.1.4.1.6574.2.1.1.5.74 1
.1.3.6.1.4.1.6574.2.1.1.5.75 1
.1.3.6.1.4.1.6574.2.1.1.5.76 1
.1.3.6.1.4.1.6574.2.1.1.5.77 1
.1.3.6.1.4.1.6574.2.1.1.5.78 1
.1.3.6.1.4.1.6574.2.1.1.5.79 1
.1.3.6.1.4.1.6574.2.1.1.5.80 1
.1.3.6.1.4.1.6574.2.1.1.5.81 1
.1.3.6.1.4.1.6574.2.1.1.5.82 1
.1.3.6.1.4.1.6574.2.1.1.5.83 1
.1.3.6.1.4.1.6574.2.1.1.5.84 1
.1.3.6.1.4.1.6574.2.1.1.5.85 1
.1.3.6.1.4.1.6574.2.1.1.5.86 1
.1.3.6.1.4.1.6574.2.1.1.5.87 1
.1.3.6.1.4.1.6574.2.1.1.5.88 1
.1.3.6.1.4.1.6574.2.1.1.5.89 1
.1.3.6.1.4.1.6574.2.1.1.5.90 1
.1.3.6.1.4.1.6574.2.1.1.5.91 1
.1.3.6.1.4.1.6574.2.1.1.5.92 1
.1.3.6.1.4.1.6574.2.1.1.5.93 1
.1.3.6.1.4.1.6574.2.1.1.5.94 1
.1.3.6.1.4.1.6574.2.1.1.5.95 1
.1.3.6.1.4.1.6574.2.1.1.6.0 39
.1.3.6.1.4.1.6574.2.1.1.6.1 42
.1.3.6.1.4.1.6574.2.1.1.6.2 42
.1.3.6.1.4.1.6574.2.1.1.6.3 41
.1.3.6.1.4.1.6574.2.1.1.6.4 40
.1.3.6.1.4.1.6574.2.1.1.6.5 39
.1.3.6.1.4.1.6574.2.1.1.6.6 38
.1.3.6.1.4.1.6574.2.1.1.6.7 40
.1.3.6.1.4.1.6574.2.1.1.6.8 39
.1.3.6.1.4.1.6574.2.1.1.6.9 42
.1.3.6.1.4.1.6574.2.1.1.6.10 40
.1.3.6.1.4.1.6574.2.1.1.6.11 41
.1.3.6.1.4.1.6574.2.1.1.6.12 35
.1.3.6.1.4.1.6574.2.1.1.6.13 35
.1.3.6.1.4.1.6574.2.1.1.6.14 36
.1.3.6.1.4.1.6574.2.1.1.6.15 35
.1.3.6.1.4.1.6574.2.1.1.6.16 35
.1.3.6.1.4.1.6574.2.1.1.6.17 38
.1.3.6.1.4.1.6574.2.1.1.6.18 38
.1.3.6.1.4.1.6574.2.1.1.6.19 36
.1.3.6.1.4.1.6574.2.1.1.6.20 35
.1.3.6.1.4.1.6574.2.1.1.6.21 36
.1.3.6.1.4.1.6574.2.1.1.6.22 36
.1.3.6.1.4.1.6574.2.1.1.6.23 36
.1.3.6.1.4.1.6574.2.1.1.6.24 34
.1.3.6.1.4.1.6574.2.1.1.6.25 34
.1.3.6.1.4.1.6574.2.1.1.6.26 34
.1.3.6.1.4.1.6574.2.1.1.6.27 34
.1.3.6.1.4.1.6574.2.1.1.6.28 35
.1.3.6.1.4.1.6574.2.1.1.6.29 35
.1.3.6.1.4.1.6574.2.1.1.6.30 35
.1.3.6.1.4.1.6574.2.1.1.6.31 35
.1.3.6.1.4.1.6574.2.1.1.6.32 34
.1.3.6.1.4.1.6574.2.1.1.6.33 34
.1.3.6.1.4.1.6574.2.1.1.6.34 35
.1.3.6.1.4.1.6574.2.1.1.6.35 34
.1.3.6.1.4.1.6574.2.1.1.6.36 35
.1.3.6.1.4.1.6574.2.1.1.6.37 35
.1.3.6.1.4.1.6574.2.1.1.6.38 35
.1.3.6.1.4.1.6574.2.1.1.6.39 34
.1.3.6.1.4.1.6574.2.1.1.6.40 35
.1.3.6.1.4.1.6574.2.1.1.6.41 35
.1.3.6.1.4.1.6574.2.1.1.6.42 36
.1.3.6.1.4.1.6574.2.1.1.6.43 36
.1.3.6.1.4.1.6574.2.1.1.6.44 35
.1.3.6.1.4.1.6574.2.1.1.6.45 35
.1.3.6.1.4.1.6574.2.1.1.6.46 36
.1.3.6.1.4.1.6574.2.1.1.6.47 35
.1.3.6.1.4.1.6574.2.1.1.6.48 33
.1.3.6.1.4.1.6574.2.1.1.6.49 34
.1.3.6.1.4.1.6574.2.1.1.6.50 33
.1.3.6.1.4.1.6574.2.1.1.6.51 34
.1.3.6.1.4.1.6574.2.1.1.6.52 34
.1.3.6.1.4.1.6574.2.1.1.6.53 36
.1.3.6.1.4.1.6574.2.1.1.6.54 35
.1.3.6.1.4.1.6574.2.1.1.6.55 35
.1.3.6.1.4.1.6574.2.1.1.6.56 34
.1.3.6.1.4.1.6574.2.1.1.6.57 34
.1.3.6.1.4.1.6574.2.1.1.6.58 34
.1.3.6.1.4.1.6574.2.1.1.6.59 34
.1.3.6.1.4.1.6574.2.1.1.6.60 33
.1.3.6.1.4.1.6574.2.1.1.6.61 34
.1.3.6.1.4.1.6574.2.1.1.6.62 33
.1.3.6.1.4.1.6574.2.1.1.6.63 34
.1.3.6.1.4.1.6574.2.1.1.6.64 33
.1.3.6.1.4.1.6574.2.1.1.6.65 35
.1.3.6.1.4.1.6574.2.1.1.6.66 35
.1.3.6.1.4.1.6574.2.1.1.6.67 34
.1.3.6.1.4.1.6574.2.1.1.6.68 34
.1.3.6.1.4.1.6574.2.1.1.6.69 34
.1.3.6.1.4.1.6574.2.1.1.6.70 34
.1.3.6.1.4.1.6574.2.1.1.6.71 34
.1.3.6.1.4.1.6574.2.1.1.6.72 33
.1.3.6.1.4.1.6574.2.1.1.6.73 34
.1.3.6.1.4.1.6574.2.1.1.6.74 33
.1.3.6.1.4.1.6574.2.1.1.6.75 34
.1.3.6.1.4.1.6574.2.1.1.6.76 33
.1.3.6.1.4.1.6574.2.1.1.6.77 34
.1.3.6.1.4.1.6574.2.1.1.6.78 34
.1.3.6.1.4.1.6574.2.1.1.6.79 33
.1.3.6.1.4.1.6574.2.1.1.6.80 33
.1.3.6.1.4.1.6574.2.1.1.6.81 33
.1.3.6.1.4.1.6574.2.1.1.6.82 34
.1.3.6.1.4.1.6574.2.1.1.6.83 33
.1.3.6.1.4.1.6574.2.1.1.6.84 34
.1.3.6.1.4.1.6574.2.1.1.6.85 35
.1.3.6.1.4.1.6574.2.1.1.6.86 35
.1.3.6.1.4.1.6574.2.1.1.6.87 34
.1.3.6.1.4.1.6574.2.1.1.6.88 34
.1.3.6.1.4.1.6574.2.1.1.6.89 35
.1.3.6.1.4.1.6574.2.1.1.6.90 35
.1.3.6.1.4.1.6574.2.1.1.6.91 35
.1.3.6.1.4.1.6574.2.1.1.6.92 35
.1.3.6.1.4.1.6574.2.1.1.6.93 35
.1.3.6.1.4.1.6574.2.1.1.6.94 35
.1.3.6.1.4.1.6574.2.1.1.6.95 35
.1.3.6.1.4.1.6574.2.1.1.7.0 unknown
.1.3.6.1.4.1.6574.2.1.1.7.1 unknown
.1.3.6.1.4.1.6574.2.1.1.7.2 unknown
.1.3.6.1.4.1.6574.2.1.1.7.3 unknown
.1.3.6.1.4.1.6574.2.1.1.7.4 unknown
.1.3.6.1.4.1.6574.2.1.1.7.5 unknown
.1.3.6.1.4.1.6574.2.1.1.7.6 unknown
.1.3.6.1.4.1.6574.2.1.1.7.7 unknown
.1.3.6.1.4.1.6574.2.1.1.7.8 unknown
.1.3.6.1.4.1.6574.2.1.1.7.9 unknown
.1.3.6.1.4.1.6574.2.1.1.7.10 unknown
.1.3.6.1.4.1.6574.2.1.1.7.11 unknown
.1.3.6.1.4.1.6574.2.1.1.7.12 unknown
.1.3.6.1.4.1.6574.2.1.1.7.13 unknown
.1.3.6.1.4.1.6574.2.1.1.7.14 unknown
.1.3.6.1.4.1.6574.2.1.1.7.15 unknown
.1.3.6.1.4.1.6574.2.1.1.7.16 unknown
.1.3.6.1.4.1.6574.2.1.1.7.17 unknown
.1.3.6.1.4.1.6574.2.1.1.7.18 unknown
.1.3.6.1.4.1.6574.2.1.1.7.19 unknown
.1.3.6.1.4.1.6574.2.1.1.7.20 unknown
.1.3.6.1.4.1.6574.2.1.1.7.21 unknown
.1.3.6.1.4.1.6574.2.1.1.7.22 unknown
.1.3.6.1.4.1.6574.2.1.1.7.23 unknown
.1.3.6.1.4.1.6574.2.1.1.7.24 unknown
.1.3.6.1.4.1.6574.2.1.1.7.25 unknown
.1.3.6.1.4.1.6574.2.1.1.7.26 unknown
.1.3.6.1.4.1.6574.2.1.1.7.27 unknown
.1.3.6.1.4.1.6574.2.1.1.7.28 unknown
.1.3.6.1.4.1.6574.2.1.1.7.29 unknown
.1.3.6.1.4.1.6574.2.1.1.7.30 unknown
.1.3.6.1.4.1.6574.2.1.1.7.31 unknown
.1.3.6.1.4.1.6574.2.1.1.7.32 unknown
.1.3.6.1.4.1.6574.2.1.1.7.33 unknown
.1.3.6.1.4.1.6574.2.1.1.7.34 unknown
.1.3.6.1.4.1.6574.2.1.1.7.35 unknown
.1.3.6.1.4.1.6574.2.1.1.7.36 unknown
.1.3.6.1.4.1.6574.2.1.1.7.37 unknown
.1.3.6.1.4.1.6574.2.1.1.7.38 unknown
.1.3.6.1.4.1.6574.2.1.1.7.39 unknown
.1.3.6.1.4.1.6574.2.1.1.7.40 unknown
.1.3.6.1.4.1.6574.2.1.1.7.41 unknown
.1.3.6.1.4.1.6574.2.1.1.7.42 unknown
.1.3.6.1.4.1.6574.2.1.1.7.43 unknown
.1.3.6.1.4.1.6574.2.1.1.7.44 unknown
.1.3.6.1.4.1.6574.2.1.1.7.45 unknown
.1.3.6.1.4.1.6574.2.1.1.7.46 unknown
.1.3.6.1.4.1.6574.2.1.1.7.47 unknown
.1.3.6.1.4.1.6574.2.1.1.7.48 unknown
.1.3.6.1.4.1.6574.2.1.1.7.49 unknown
.1.3.6.1.4.1.6574.2.1.1.7.50 unknown
.1.3.6.1.4.1.6574.2.1.1.7.51 unknown
.1.3.6.1.4.1.6574.2.1.1.7.52 unknown
.1.3.6.1.4.1.6574.2.1.1.7.53 unknown
.1.3.6.1.4.1.6574.2.1.1.7.54 unknown
.1.3.6.1.4.1.6574.2.1.1.7.55 unknown
.1.3.6.1.4.1.6574.2.1.1.7.56 unknown
.1.3.6.1.4.1.6574.2.1.1.7.57 unknown
.1.3.6.1.4.1.6574.2.1.1.7.58 unknown
.1.3.6.1.4.1.6574.2.1.1.7.59 unknown
.1.3.6.1.4.1.6574.2.1.1.7.60 unknown
.1.3.6.1.4.1.6574.2.1.1.7.61 unknown
.1.3.6.1.4.1.6574.2.1.1.7.62 unknown
.1.3.6.1.4.1.6574.2.1.1.7.63 unknown
.1.3.6.1.4.1.6574.2.1.1.7.64 unknown
.1.3.6.1.4.1.6574.2.1.1.7.65 unknown
.1.3.6.1.4.1.6574.2.1.1.7.66 unknown
.1.3.6.1.4.1.6574.2.1.1.7.67 unknown
.1.3.6.1.4.1.6574.2.1.1.7.68 unknown
.1.3.6.1.4.1.6574.2.1.1.7.69 unknown
.1.3.6.1.4.1.6574.2.1.1.7.70 unknown
.1.3.6.1.4.1.6574.2.1.1.7.71 unknown
.1.3.6.1.4.1.6574.2.1.1.7.72 unknown
.1.3.6.1.4.1.6574.2.1.1.7.73 unknown
.1.3.6.1.4.1.6574.2.1.1.7.74 unknown
.1.3.6.1.4.1.6574.2.1.1.7.75 unknown
.1.3.6.1.4.1.6574.2.1.1.7.76 unknown
.1.3.6.1.4.1.6574.2.1.1.7.77 unknown
.1.3.6.1.4.1.6574.2.1.1.7.78 unknown
.1.3.6.1.4.1.6574.2.1.1.7.79 unknown
.1.3.6.1.4.1.6574.2.1.1.7.80 unknown
.1.3.6.1.4.1.6574.2.1.1.7.81 unknown
.1.3.6.1.4.1.6574.2.1.1.7.82 unknown
.1.3.6.1.4.1.6574.2.1.1.7.83 unknown
.1.3.6.1.4.1.6574.2.1.1.7.84 unknown
.1.3.6.1.4.1.6574.2.1.1.7.85 unknown
.1.3.6.1.4.1.6574.2.1.1.7.86 unknown
.1.3.6.1.4.1.6574.2.1.1.7.87 unknown
.1.3.6.1.4.1.6574.2.1.1.7.88 unknown
.1.3.6.1.4.1.6574.2.1.1.7.89 unknown
.1.3.6.1.4.1.6574.2.1.1.7.90 unknown
.1.3.6.1.4.1.6574.2.1.1.7.91 unknown
.1.3.6.1.4.1.6574.2.1.1.7.92 unknown
.1.3.6.1.4.1.6574.2.1.1.7.93 unknown
.1.3.6.1.4.1.6574.2.1.1.7.94 unknown
.1.3.6.1.4.1.6574.2.1.1.7.95 unknown
.1.3.6.1.4.1.6574.2.1.1.8.0 0
.1.3.6.1.4.1.6574.2.1.1.8.1 0
.1.3.6.1.4.1.6574.2.1.1.8.2 0
.1.3.6.1.4.1.6574.2.1.1.8.3 0
.1.3.6.1.4.1.6574.2.1.1.8.4 0
.1.3.6.1.4.1.6574.2.1.1.8.5 0
.1.3.6.1.4.1.6574.2.1.1.8.6 0
.1.3.6.1.4.1.6574.2.1.1.8.7 0
.1.3.6.1.4.1.6574.2.1.1.8.8 0
.1.3.6.1.4.1.6574.2.1.1.8.9 0
.1.3.6.1.4.1.6574.2.1.1.8.10 0
.1.3.6.1.4.1.6574.2.1.1.8.11 0
.1.3.6.1.4.1.6574.2.1.1.8.12 0
.1.3.6.1.4.1.6574.2.1.1.8.13 0
.1.3.6.1.4.1.6574.2.1.1.8.14 0
.1.3.6.1.4.1.6574.2.1.1.8.15 0
.1.3.6.1.4.1.6574.2.1.1.8.16 0
.1.3.6.1.4.1.6574.2.1.1.8.17 0
.1.3.6.1.4.1.6574.2.1.1.8.18 0
.1.3.6.1.4.1.6574.2.1.1.8.19 0
.1.3.6.1.4.1.6574.2.1.1.8.20 0
.1.3.6.1.4.1.6574.2.1.1.8.21 0
.1.3.6.1.4.1.6574.2.1.1.8.22 0
.1.3.6.1.4.1.6574.2.1.1.8.23 0
.1.3.6.1.4.1.6574.2.1.1.8.24 0
.1.3.6.1.4.1.6574.2.1.1.8.25 0
.1.3.6.1.4.1.6574.2.1.1.8.26 0
.1.3.6.1.4.1.6574.2.1.1.8.27 0
.1.3.6.1.4.1.6574.2.1.1.8.28 0
.1.3.6.1.4.1.6574.2.1.1.8.29 0
.1.3.6.1.4.1.6574.2.1.1.8.30 0
.1.3.6.1.4.1.6574.2.1.1.8.31 0
.1.3.6.1.4.1.6574.2.1.1.8.32 0
.1.3.6.1.4.1.6574.2.1.1.8.33 0
.1.3.6.1.4.1.6574.2.1.1.8.34 0
.1.3.6.1.4.1.6574.2.1.1.8.35 0
.1.3.6.1.4.1.6574.2.1.1.8.36 0
.1.3.6.1.4.1.6574.2.1.1.8.37 0
.1.3.6.1.4.1.6574.2.1.1.8.38 0
.1.3.6.1.4.1.6574.2.1.1.8.39 0
.1.3.6.1.4.1.6574.2.1.1.8.40 0
.1.3.6.1.4.1.6574.2.1.1.8.41 0
.1.3.6.1.4.1.6574.2.1.1.8.42 0
.1.3.6.1.4.1.6574.2.1.1.8.43 0
.1.3.6.1.4.1.6574.2.1.1.8.44 0
.1.3.6.1.4.1.6574.2.1.1.8.45 0
.1.3.6.1.4.1.6574.2.1.1.8.46 0
.1.3.6.1.4.1.6574.2.1.1.8.47 0
.1.3.6.1.4.1.6574.2.1.1.8.48 0
.1.3.6.1.4.1.6574.2.1.1.8.49 0
.1.3.6.1.4.1.6574.2.1.1.8.50 0
.1.3.6.1.4.1.6574.2.1.1.8.51 0
.1.3.6.1.4.1.6574.2.1.1.8.52 0
.1.3.6.1.4.1.6574.2.1.1.8.53 0
.1.3.6.1.4.1.6574.2.1.1.8.54 0
.1.3.6.1.4.1.6574.2.1.1.8.55 0
.1.3.6.1.4.1.6574.2.1.1.8.56 0
.1.3.6.1.4.1.6574.2.1.1.8.57 0
.1.3.6.1.4.1.6574.2.1.1.8.58 0
.1.3.6.1.4.1.6574.2.1.1.8.59 0
.1.3.6.1.4.1.6574.2.1.1.8.60 0
.1.3.6.1.4.1.6574.2.1.1.8.61 0
.1.3.6.1.4.1.6574.2.1.1.8.62 0
.1.3.6.1.4.1.6574.2.1.1.8.63 0
.1.3.6.1.4.1.6574.2.1.1.8.64 0
.1.3.6.1.4.1.6574.2.1.1.8.65 0
.1.3.6.1.4.1.6574.2.1.1.8.66 0
.1.3.6.1.4.1.6574.2.1.1.8.67 0
.1.3.6.1.4.1.6574.2.1.1.8.68 0
.1.3.6.1.4.1.6574.2.1.1.8.69 0
.1.3.6.1.4.1.6574.2.1.1.8.70 0
.1.3.6.1.4.1.6574.2.1.1.8.71 0
.1.3.6.1.4.1.6574.2.1.1.8.72 0
.1.3.6.1.4.1.6574.2.1.1.8.73 0
.1.3.6.1.4.1.6574.2.1.1.8.74 0
.1.3.6.1.4.1.6574.2.1.1.8.75 0
.1.3.6.1.4.1.6574.2.1.1.8.76 0
.1.3.6.1.4.1.6574.2.1.1.8.77 0
.1.3.6.1.4.1.6574.2.1.1.8.78 0
.1.3.6.1.4.1.6574.2.1.1.8.79 0
.1.3.6.1.4.1.6574.2.1.1.8.80 0
.1.3.6.1.4.1.6574.2.1.1.8.81 0
.1.3.6.1.4.1.6574.2.1.1.8.82 0
.1.3.6.1.4.1.6574.2.1.1.8.83 0
.1.3.6.1.4.1.6574.2.1.1.8.84 0
.1.3.6.1.4.1.6574.2.1.1.8.85 0
.1.3.6.1.4.1.6574.2.1.1.8.86 0
.1.3.6.1.4.1.6574.2.1.1.8.87 0
.1.3.6.1.4.1.6574.2.1.1.8.88 0
.1.3.6.1.4.1.6574.2.1.1.8.89 0
.1.3.6.1.4.1.6574.2.1.1.8.90 0
.1.3.6.1.4.1.6574.2.1.1.8.91 0
.1.3.6.1.4.1.6574.2.1.1.8.92 0
.1.3.6.1.4.1.6574.2.1.1.8.93 0
.1.3.6.1.4.1.6574.2.1.1.8.94 0
.1.3.6.1.4.1.6574.2.1.1.8.95 0
.1.3.6.1.4.1.6574.2.1.1.9.0 -1
.1.3.6.1.4.1.6574.2.1.1.9.1 -1
.1.3.6.1.4.1.6574.2.1.1.9.2 -1
.1.3.6.1.4.1.6574.2.1.1.9.3 -1
.1.3.6.1.4.1.6574.2.1.1.9.4 -1
.1.3.6.1.4.1.6574.2.1.1.9.5 -1
.1.3.6.1.4.1.6574.2.1.1.9.6 -1
.1.3.6.1.4.1.6574.2.1.1.9.7 -1
.1.3.6.1.4.1.6574.2.1.1.9.8 -1
.1.3.6.1.4.1.6574.2.1.1.9.9 -1
.1.3.6.1.4.1.6574.2.1.1.9.10 -1
.1.3.6.1.4.1.6574.2.1.1.9.11 -1
.1.3.6.1.4.1.6574.2.1.1.9.12 -1
.1.3.6.1.4.1.6574.2.1.1.9.13 -1
.1.3.6.1.4.1.6574.2.1.1.9.14 -1
.1.3.6.1.4.1.6574.2.1.1.9.15 -1
.1.3.6.1.4.1.6574.2.1.1.9.16 -1
.1.3.6.1.4.1.6574.2.1.1.9.17 -1
.1.3.6.1.4.1.6574.2.1.1.9.18 -1
.1.3.6.1.4.1.6574.2.1.1.9.19 -1
.1.3.6.1.4.1.6574.2.1.1.9.20 -1
.1.3.6.1.4.1.6574.2.1.1.9.21 -1
.1.3.6.1.4.1.6574.2.1.1.9.22 -1
.1.3.6.1.4.1.6574.2.1.1.9.23 -1
.1.3.6.1.4.1.6574.2.1.1.9.24 -1
.1.3.6.1.4.1.6574.2.1.1.9.25 -1
.1.3.6.1.4.1.6574.2.1.1.9.26 -1
.1.3.6.1.4.1.6574.2.1.1.9.27 -1
.1.3.6.1.4.1.6574.2.1.1.9.28 -1
.1.3.6.1.4.1.6574.2.1.1.9.29 -1
.1.3.6.1.4.1.6574.2.1.1.9.30 -1
.1.3.6.1.4.1.6574.2.1.1.9.31 -1
.1.3.6.1.4.1.6574.2.1.1.9.32 -1
.1.3.6.1.4.1.6574.2.1.1.9.33 -1
.1.3.6.1.4.1.6574.2.1.1.9.34 -1
.1.3.6.1.4.1.6574.2.1.1.9.35 -1
.1.3.6.1.4.1.6574.2.1.1.9.36 -1
.1.3.6.1.4.1.6574.2.1.1.9.37 -1
.1.3.6.1.4.1.6574.2.1.1.9.38 -1
.1.3.6.1.4.1.6574.2.1.1.9.39 -1
.1.3.6.1.4.1.6574.2.1.1.9.40 -1
.1.3.6.1.4.1.6574.2.1.1.9.41 -1
.1.3.6.1.4.1.6574.2.1.1.9.42 -1
.1.3.6.1.4.1.6574.2.1.1.9.43 -1
.1.3.6.1.4.1.6574.2.1.1.9.44 -1
.1.3.6.1.4.1.6574.2.1.1.9.45 -1
.1.3.6.1.4.1.6574.2.1.1.9.46 -1
.1.3.6.1.4.1.6574.2.1.1.9.47 -1
.1.3.6.1.4.1.6574.2.1.1.9.48 -1
.1.3.6.1.4.1.6574.2.1.1.9.49 -1
.1.3.6.1.4.1.6574.2.1.1.9.50 -1
.1.3.6.1.4.1.6574.2.1.1.9.51 -1
.1.3.6.1.4.1.6574.2.1.1.9.52 -1
.1.3.6.1.4.1.6574.2.1.1.9.53 -1
.1.3.6.1.4.1.6574.2.1.1.9.54 -1
.1.3.6.1.4.1.6574.2.1.1.9.55 -1
.1.3.6.1.4.1.6574.2.1.1.9.56 -1
.1.3.6.1.4.1.6574.2.1.1.9.57 -1
.1.3.6.1.4.1.6574.2.1.1.9.58 -1
.1.3.6.1.4.1.6574.2.1.1.9.59 -1
.1.3.6.1.4.1.6574.2.1.1.9.60 -1
.1.3.6.1.4.1.6574.2.1.1.9.61 -1
.1.3.6.1.4.1.6574.2.1.1.9.62 -1
.1.3.6.1.4.1.6574.2.1.1.9.63 -1
.1.3.6.1.4.1.6574.2.1.1.9.64 -1
.1.3.6.1.4.1.6574.2.1.1.9.65 -1
.1.3.6.1.4.1.6574.2.1.1.9.66 -1
.1.3.6.1.4.1.6574.2.1.1.9.67 -1
.1.3.6.1.4.1.6574.2.1.1.9.68 -1
.1.3.6.1.4.1.6574.2.1.1.9.69 -1
.1.3.6.1.4.1.6574.2.1.1.9.70 -1
.1.3.6.1.4.1.6574.2.1.1.9.71 -1
.1.3.6.1.4.1.6574.2.1.1.9.72 -1
.1.3.6.1.4.1.6574.2.1.1.9.73 -1
.1.3.6.1.4.1.6574.2.1.1.9.74 -1
.1.3.6.1.4.1.6574.2.1.1.9.75 -1
.1.3.6.1.4.1.6574.2.1.1.9.76 -1
.1.3.6.1.4.1.6574.2.1.1.9.77 -1
.1.3.6.1.4.1.6574.2.1.1.9.78 -1
.1.3.6.1.4.1.6574.2.1.1.9.79 -1
.1.3.6.1.4.1.6574.2.1.1.9.80 -1
.1.3.6.1.4.1.6574.2.1.1.9.81 -1
.1.3.6.1.4.1.6574.2.1.1.9.82 -1
.1.3.6.1.4.1.6574.2.1.1.9.83 -1
.1.3.6.1.4.1.6574.2.1.1.9.84 -1
.1.3.6.1.4.1.6574.2.1.1.9.85 -1
.1.3.6.1.4.1.6574.2.1.1.9.86 -1
.1.3.6.1.4.1.6574.2.1.1.9.87 -1
.1.3.6.1.4.1.6574.2.1.1.9.88 -1
.1.3.6.1.4.1.6574.2.1.1.9.89 -1
.1.3.6.1.4.1.6574.2.1.1.9.90 -1
.1.3.6.1.4.1.6574.2.1.1.9.91 -1
.1.3.6.1.4.1.6574.2.1.1.9.92 -1
.1.3.6.1.4.1.6574.2.1.1.9.93 -1
.1.3.6.1.4.1.6574.2.1.1.9.94 -1
.1.3.6.1.4.1.6574.2.1.1.9.95 -1
.1.3.6.1.4.1.6574.2.1.1.10.0 0
.1.3.6.1.4.1.6574.2.1.1.10.1 0
.1.3.6.1.4.1.6574.2.1.1.10.2 0
.1.3.6.1.4.1.6574.2.1.1.10.3 0
.1.3.6.1.4.1.6574.2.1.1.10.4 0
.1.3.6.1.4.1.6574.2.1.1.10.5 0
.1.3.6.1.4.1.6574.2.1.1.10.6 0
.1.3.6.1.4.1.6574.2.1.1.10.7 0
.1.3.6.1.4.1.6574.2.1.1.10.8 0
.1.3.6.1.4.1.6574.2.1.1.10.9 0
.1.3.6.1.4.1.6574.2.1.1.10.10 0
.1.3.6.1.4.1.6574.2.1.1.10.11 0
.1.3.6.1.4.1.6574.2.1.1.10.12 0
.1.3.6.1.4.1.6574.2.1.1.10.13 0
.1.3.6.1.4.1.6574.2.1.1.10.14 0
.1.3.6.1.4.1.6574.2.1.1.10.15 0
.1.3.6.1.4.1.6574.2.1.1.10.16 0
.1.3.6.1.4.1.6574.2.1.1.10.17 0
.1.3.6.1.4.1.6574.2.1.1.10.18 0
.1.3.6.1.4.1.6574.2.1.1.10.19 0
.1.3.6.1.4.1.6574.2.1.1.10.20 0
.1.3.6.1.4.1.6574.2.1.1.10.21 0
.1.3.6.1.4.1.6574.2.1.1.10.22 0
.1.3.6.1.4.1.6574.2.1.1.10.23 0
.1.3.6.1.4.1.6574.2.1.1.10.24 0
.1.3.6.1.4.1.6574.2.1.1.10.25 0
.1.3.6.1.4.1.6574.2.1.1.10.26 0
.1.3.6.1.4.1.6574.2.1.1.10.27 0
.1.3.6.1.4.1.6574.2.1.1.10.28 0
.1.3.6.1.4.1.6574.2.1.1.10.29 0
.1.3.6.1.4.1.6574.2.1.1.10.30 0
.1.3.6.1.4.1.6574.2.1.1.10.31 0
.1.3.6.1.4.1.6574.2.1.1.10.32 0
.1.3.6.1.4.1.6574.2.1.1.10.33 0
.1.3.6.1.4.1.6574.2.1.1.10.34 0
.1.3.6.1.4.1.6574.2.1.1.10.35 0
.1.3.6.1.4.1.6574.2.1.1.10.36 0
.1.3.6.1.4.1.6574.2.1.1.10.37 0
.1.3.6.1.4.1.6574.2.1.1.10.38 0
.1.3.6.1.4.1.6574.2.1.1.10.39 0
.1.3.6.1.4.1.6574.2.1.1.10.40 0
.1.3.6.1.4.1.6574.2.1.1.10.41 0
.1.3.6.1.4.1.6574.2.1.1.10.42 0
.1.3.6.1.4.1.6574.2.1.1.10.43 0
.1.3.6.1.4.1.6574.2.1.1.10.44 0
.1.3.6.1.4.1.6574.2.1.1.10.45 0
.1.3.6.1.4.1.6574.2.1.1.10.46 0
.1.3.6.1.4.1.6574.2.1.1.10.47 0
.1.3.6.1.4.1.6574.2.1.1.10.48 0
.1.3.6.1.4.1.6574.2.1.1.10.49 0
.1.3.6.1.4.1.6574.2.1.1.10.50 0
.1.3.6.1.4.1.6574.2.1.1.10.51 0
.1.3.6.1.4.1.6574.2.1.1.10.52 0
.1.3.6.1.4.1.6574.2.1.1.10.53 0
.1.3.6.1.4.1.6574.2.1.1.10.54 0
.1.3.6.1.4.1.6574.2.1.1.10.55 0
.1.3.6.1.4.1.6574.2.1.1.10.56 0
.1.3.6.1.4.1.6574.2.1.1.10.57 0
.1.3.6.1.4.1.6574.2.1.1.10.58 0
.1.3.6.1.4.1.6574.2.1.1.10.59 0
.1.3.6.1.4.1.6574.2.1.1.10.60 0
.1.3.6.1.4.1.6574.2.1.1.10.61 0
.1.3.6.1.4.1.6574.2.1.1.10.62 0
.1.3.6.1.4.1.6574.2.1.1.10.63 0
.1.3.6.1.4.1.6574.2.1.1.10.64 0
.1.3.6.1.4.1.6574.2.1.1.10.65 0
.1.3.6.1.4.1.6574.2.1.1.10.66 0
.1.3.6.1.4.1.6574.2.1.1.10.67 0
.1.3.6.1.4.1.6574.2.1.1.10.68 0
.1.3.6.1.4.1.6574.2.1.1.10.69 0
.1.3.6.1.4.1.6574.2.1.1.10.70 0
.1.3.6.1.4.1.6574.2.1.1.10.71 0
.1.3.6.1.4.1.6574.2.1.1.10.72 0
.1.3.6.1.4.1.6574.2.1.1.10.73 0
.1.3.6.1.4.1.6574.2.1.1.10.74 0
.1.3.6.1.4.1.6574.2.1.1.10.75 0
.1.3.6.1.4.1.6574.2.1.1.10.76 0
.1.3.6.1.4.1.6574.2.1.1.10.77 0
.1.3.6.1.4.1.6574.2.1.1.10.78 0
.1.3.6.1.4.1.6574.2.1.1.10.79 0
.1.3.6.1.4.1.6574.2.1.1.10.80 0
.1.3.6.1.4.1.6574.2.1.1.10.81 0
.1.3.6.1.4.1.6574.2.1.1.10.82 0
.1.3.6.1.4.1.6574.2.1.1.10.83 0
.1.3.6.1.4.1.6574.2.1.1.10.84 0
.1.3.6.1.4.1.6574.2.1.1.10.85 0
.1.3.6.1.4.1.6574.2.1.1.10.86 0
.1.3.6.1.4.1.6574.2.1.1.10.87 0
.1.3.6.1.4.1.6574.2.1.1.10.88 0
.1.3.6.1.4.1.6574.2.1.1.10.89 0
.1.3.6.1.4.1.6574.2.1.1.10.90 0
.1.3.6.1.4.1.6574.2.1.1.10.91 0
.1.3.6.1.4.1.6574.2.1.1.10.92 0
.1.3.6.1.4.1.6574.2.1.1.10.93 0
.1.3.6.1.4.1.6574.2.1.1.10.94 0
.1.3.6.1.4.1.6574.2.1.1.10.95 0
.1.3.6.1.4.1.6574.2.1.1.11.0 -1
.1.3.6.1.4.1.6574.2.1.1.11.1 -1
.1.3.6.1.4.1.6574.2.1.1.11.2 -1
.1.3.6.1.4.1.6574.2.1.1.11.3 -1
.1.3.6.1.4.1.6574.2.1.1.11.4 -1
.1.3.6.1.4.1.6574.2.1.1.11.5 -1
.1.3.6.1.4.1.6574.2.1.1.11.6 -1
.1.3.6.1.4.1.6574.2.1.1.11.7 -1
.1.3.6.1.4.1.6574.2.1.1.11.8 -1
.1.3.6.1.4.1.6574.2.1.1.11.9 -1
.1.3.6.1.4.1.6574.2.1.1.11.10 -1
.1.3.6.1.4.1.6574.2.1.1.11.11 -1
.1.3.6.1.4.1.6574.2.1.1.11.12 -1
.1.3.6.1.4.1.6574.2.1.1.11.13 -1
.1.3.6.1.4.1.6574.2.1.1.11.14 -1
.1.3.6.1.4.1.6574.2.1.1.11.15 -1
.1.3.6.1.4.1.6574.2.1.1.11.16 -1
.1.3.6.1.4.1.6574.2.1.1.11.17 -1
.1.3.6.1.4.1.6574.2.1.1.11.18 -1
.1.3.6.1.4.1.6574.2.1.1.11.19 -1
.1.3.6.1.4.1.6574.2.1.1.11.20 -1
.1.3.6.1.4.1.6574.2.1.1.11.21 -1
.1.3.6.1.4.1.6574.2.1.1.11.22 -1
.1.3.6.1.4.1.6574.2.1.1.11.23 -1
.1.3.6.1.4.1.6574.2.1.1.11.24 -1
.1.3.6.1.4.1.6574.2.1.1.11.25 -1
.1.3.6.1.4.1.6574.2.1.1.11.26 -1
.1.3.6.1.4.1.6574.2.1.1.11.27 -1
.1.3.6.1.4.1.6574.2.1.1.11.28 -1
.1.3.6.1.4.1.6574.2.1.1.11.29 -1
.1.3.6.1.4.1.6574.2.1.1.11.30 -1
.1.3.6.1.4.1.6574.2.1.1.11.31 -1
.1.3.6.1.4.1.6574.2.1.1.11.32 -1
.1.3.6.1.4.1.6574.2.1.1.11.33 -1
.1.3.6.1.4.1.6574.2.1.1.11.34 -1
.1.3.6.1.4.1.6574.2.1.1.11.35 -1
.1.3.6.1.4.1.6574.2.1.1.11.36 -1
.1.3.6.1.4.1.6574.2.1.1.11.37 -1
.1.3.6.1.4.1.6574.2.1.1.11.38 -1
.1.3.6.1.4.1.6574.2.1.1.11.39 -1
.1.3.6.1.4.1.6574.2.1.1.11.40 -1
.1.3.6.1.4.1.6574.2.1.1.11.41 -1
.1.3.6.1.4.1.6574.2.1.1.11.42 -1
.1.3.6.1.4.1.6574.2.1.1.11.43 -1
.1.3.6.1.4.1.6574.2.1.1.11.44 -1
.1.3.6.1.4.1.6574.2.1.1.11.45 -1
.1.3.6.1.4.1.6574.2.1.1.11.46 -1
.1.3.6.1.4.1.6574.2.1.1.11.47 -1
.1.3.6.1.4.1.6574.2.1.1.11.48 -1
.1.3.6.1.4.1.6574.2.1.1.11.49 -1
.1.3.6.1.4.1.6574.2.1.1.11.50 -1
.1.3.6.1.4.1.6574.2.1.1.11.51 -1
.1.3.6.1.4.1.6574.2.1.1.11.52 -1
.1.3.6.1.4.1.6574.2.1.1.11.53 -1
.1.3.6.1.4.1.6574.2.1.1.11.54 -1
.1.3.6.1.4.1.6574.2.1.1.11.55 -1
.1.3.6.1.4.1.6574.2.1.1.11.56 -1
.1.3.6.1.4.1.6574.2.1.1.11.57 -1
.1.3.6.1.4.1.6574.2.1.1.11.58 -1
.1.3.6.1.4.1.6574.2.1.1.11.59 -1
.1.3.6.1.4.1.6574.2.1.1.11.60 -1
.1.3.6.1.4.1.6574.2.1.1.11.61 -1
.1.3.6.1.4.1.6574.2.1.1.11.62 -1
.1.3.6.1.4.1.6574.2.1.1.11.63 -1
.1.3.6.1.4.1.6574.2.1.1.11.64 -1
.1.3.6.1.4.1.6574.2.1.1.11.65 -1
.1.3.6.1.4.1.6574.2.1.1.11.66 -1
.1.3.6.1.4.1.6574.2.1.1.11.67 -1
.1.3.6.1.4.1.6574.2.1.1.11.68 -1
.1.3.6.1.4.1.6574.2.1.1.11.69 -1
.1.3.6.1.4.1.6574.2.1.1.11.70 -1
.1.3.6.1.4.1.6574.2.1.1.11.71 -1
.1.3.6.1.4.1.6574.2.1.1.11.72 -1
.1.3.6.1.4.1.6574.2.1.1.11.73 -1
.1.3.6.1.4.1.6574.2.1.1.11.74 -1
.1.3.6.1.4.1.6574.2.1.1.11.75 -1
.1.3.6.1.4.1.6574.2.1.1.11.76 -1
.1.3.6.1.4.1.6574.2.1.1.11.77 -1
.1.3.6.1.4.1.6574.2.1.1.11.78 -1
.1.3.6.1.4.1.6574.2.1.1.11.79 -1
.1.3.6.1.4.1.6574.2.1.1.11.80 -1
.1.3.6.1.4.1.6574.2.1.1.11.81 -1
.1.3.6.1.4.1.6574.2.1.1.11.82 -1
.1.3.6.1.4.1.6574.2.1.1.11.83 -1
.1.3.6.1.4.1.6574.2.1.1.11.84 -1
.1.3.6.1.4.1.6574.2.1.1.11.85 -1
.1.3.6.1.4.1.6574.2.1.1.11.86 -1
.1.3.6.1.4.1.6574.2.1.1.11.87 -1
.1.3.6.1.4.1.6574.2.1.1.11.88 -1
.1.3.6.1.4.1.6574.2.1.1.11.89 -1
.1.3.6.1.4.1.6574.2.1.1.11.90 -1
.1.3.6.1.4.1.6574.2.1.1.11.91 -1
.1.3.6.1.4.1.6574.2.1.1.11.92 -1
.1.3.6.1.4.1.6574.2.1.1.11.93 -1
.1.3.6.1.4.1.6574.2.1.1.11.94 -1
.1.3.6.1.4.1.6574.2.1.1.11.95 -1
.1.3.6.1.4.1.6574.2.1.1.12.0 Drive 11
.1.3.6.1.4.1.6574.2.1.1.12.1 Drive 4
.1.3.6.1.4.1.6574.2.1.1.12.2 Drive 3
.1.3.6.1.4.1.6574.2.1.1.12.3 Drive 2
.1.3.6.1.4.1.6574.2.1.1.12.4 Drive 6
.1.3.6.1.4.1.6574.2.1.1.12.5 Drive 10
.1.3.6.1.4.1.6574.2.1.1.12.6 Drive 9
.1.3.6.1.4.1.6574.2.1.1.12.7 Drive 1
.1.3.6.1.4.1.6574.2.1.1.12.8 Drive 5
.1.3.6.1.4.1.6574.2.1.1.12.9 Drive 8
.1.3.6.1.4.1.6574.2.1.1.12.10 Drive 12
.1.3.6.1.4.1.6574.2.1.1.12.11 Drive 7
.1.3.6.1.4.1.6574.2.1.1.12.12 Drive 10 (RX1217sas-1)
.1.3.6.1.4.1.6574.2.1.1.12.13 Drive 5 (RX1217sas-1)
.1.3.6.1.4.1.6574.2.1.1.12.14 Drive 9 (RX1217sas-1)
.1.3.6.1.4.1.6574.2.1.1.12.15 Drive 1 (RX1217sas-1)
.1.3.6.1.4.1.6574.2.1.1.12.16 Drive 11 (RX1217sas-1)
.1.3.6.1.4.1.6574.2.1.1.12.17 Drive 4 (RX1217sas-1)
.1.3.6.1.4.1.6574.2.1.1.12.18 Drive 8 (RX1217sas-1)
.1.3.6.1.4.1.6574.2.1.1.12.19 Drive 12 (RX1217sas-1)
.1.3.6.1.4.1.6574.2.1.1.12.20 Drive 6 (RX1217sas-1)
.1.3.6.1.4.1.6574.2.1.1.12.21 Drive 2 (RX1217sas-1)
.1.3.6.1.4.1.6574.2.1.1.12.22 Drive 7 (RX1217sas-1)
.1.3.6.1.4.1.6574.2.1.1.12.23 Drive 3 (RX1217sas-1)
.1.3.6.1.4.1.6574.2.1.1.12.24 Drive 10 (RX1217sas-2)
.1.3.6.1.4.1.6574.2.1.1.12.25 Drive 5 (RX1217sas-2)
.1.3.6.1.4.1.6574.2.1.1.12.26 Drive 9 (RX1217sas-2)
.1.3.6.1.4.1.6574.2.1.1.12.27 Drive 1 (RX1217sas-2)
.1.3.6.1.4.1.6574.2.1.1.12.28 Drive 11 (RX1217sas-2)
.1.3.6.1.4.1.6574.2.1.1.12.29 Drive 4 (RX1217sas-2)
.1.3.6.1.4.1.6574.2.1.1.12.30 Drive 8 (RX1217sas-2)
.1.3.6.1.4.1.6574.2.1.1.12.31 Drive 12 (RX1217sas-2)
.1.3.6.1.4.1.6574.2.1.1.12.32 Drive 6 (RX1217sas-2)
.1.3.6.1.4.1.6574.2.1.1.12.33 Drive 2 (RX1217sas-2)
.1.3.6.1.4.1.6574.2.1.1.12.34 Drive 7 (RX1217sas-2)
.1.3.6.1.4.1.6574.2.1.1.12.35 Drive 3 (RX1217sas-2)
.1.3.6.1.4.1.6574.2.1.1.12.36 Drive 10 (RX1217sas-3)
.1.3.6.1.4.1.6574.2.1.1.12.37 Drive 5 (RX1217sas-3)
.1.3.6.1.4.1.6574.2.1.1.12.38 Drive 9 (RX1217sas-3)
.1.3.6.1.4.1.6574.2.1.1.12.39 Drive 1 (RX1217sas-3)
.1.3.6.1.4.1.6574.2.1.1.12.40 Drive 11 (RX1217sas-3)
.1.3.6.1.4.1.6574.2.1.1.12.41 Drive 4 (RX1217sas-3)
.1.3.6.1.4.1.6574.2.1.1.12.42 Drive 8 (RX1217sas-3)
.1.3.6.1.4.1.6574.2.1.1.12.43 Drive 12 (RX1217sas-3)
.1.3.6.1.4.1.6574.2.1.1.12.44 Drive 6 (RX1217sas-3)
.1.3.6.1.4.1.6574.2.1.1.12.45 Drive 2 (RX1217sas-3)
.1.3.6.1.4.1.6574.2.1.1.12.46 Drive 7 (RX1217sas-3)
.1.3.6.1.4.1.6574.2.1.1.12.47 Drive 3 (RX1217sas-3)
.1.3.6.1.4.1.6574.2.1.1.12.48 Drive 10 (RX1217sas-4)
.1.3.6.1.4.1.6574.2.1.1.12.49 Drive 5 (RX1217sas-4)
.1.3.6.1.4.1.6574.2.1.1.12.50 Drive 9 (RX1217sas-4)
.1.3.6.1.4.1.6574.2.1.1.12.51 Drive 1 (RX1217sas-4)
.1.3.6.1.4.1.6574.2.1.1.12.52 Drive 11 (RX1217sas-4)
.1.3.6.1.4.1.6574.2.1.1.12.53 Drive 4 (RX1217sas-4)
.1.3.6.1.4.1.6574.2.1.1.12.54 Drive 8 (RX1217sas-4)
.1.3.6.1.4.1.6574.2.1.1.12.55 Drive 12 (RX1217sas-4)
.1.3.6.1.4.1.6574.2.1.1.12.56 Drive 6 (RX1217sas-4)
.1.3.6.1.4.1.6574.2.1.1.12.57 Drive 2 (RX1217sas-4)
.1.3.6.1.4.1.6574.2.1.1.12.58 Drive 7 (RX1217sas-4)
.1.3.6.1.4.1.6574.2.1.1.12.59 Drive 3 (RX1217sas-4)
.1.3.6.1.4.1.6574.2.1.1.12.60 Drive 10 (RX1217sas-5)
.1.3.6.1.4.1.6574.2.1.1.12.61 Drive 5 (RX1217sas-5)
.1.3.6.1.4.1.6574.2.1.1.12.62 Drive 9 (RX1217sas-5)
.1.3.6.1.4.1.6574.2.1.1.12.63 Drive 1 (RX1217sas-5)
.1.3.6.1.4.1.6574.2.1.1.12.64 Drive 11 (RX1217sas-5)
.1.3.6.1.4.1.6574.2.1.1.12.65 Drive 4 (RX1217sas-5)
.1.3.6.1.4.1.6574.2.1.1.12.66 Drive 8 (RX1217sas-5)
.1.3.6.1.4.1.6574.2.1.1.12.67 Drive 12 (RX1217sas-5)
.1.3.6.1.4.1.6574.2.1.1.12.68 Drive 6 (RX1217sas-5)
.1.3.6.1.4.1.6574.2.1.1.12.69 Drive 2 (RX1217sas-5)
.1.3.6.1.4.1.6574.2.1.1.12.70 Drive 7 (RX1217sas-5)
.1.3.6.1.4.1.6574.2.1.1.12.71 Drive 3 (RX1217sas-5)
.1.3.6.1.4.1.6574.2.1.1.12.72 Drive 10 (RX1217sas-6)
.1.3.6.1.4.1.6574.2.1.1.12.73 Drive 5 (RX1217sas-6)
.1.3.6.1.4.1.6574.2.1.1.12.74 Drive 9 (RX1217sas-6)
.1.3.6.1.4.1.6574.2.1.1.12.75 Drive 1 (RX1217sas-6)
.1.3.6.1.4.1.6574.2.1.1.12.76 Drive 11 (RX1217sas-6)
.1.3.6.1.4.1.6574.2.1.1.12.77 Drive 4 (RX1217sas-6)
.1.3.6.1.4.1.6574.2.1.1.12.78 Drive 8 (RX1217sas-6)
.1.3.6.1.4.1.6574.2.1.1.12.79 Drive 12 (RX1217sas-6)
.1.3.6.1.4.1.6574.2.1.1.12.80 Drive 6 (RX1217sas-6)
.1.3.6.1.4.1.6574.2.1.1.12.81 Drive 2 (RX1217sas-6)
.1.3.6.1.4.1.6574.2.1.1.12.82 Drive 7 (RX1217sas-6)
.1.3.6.1.4.1.6574.2.1.1.12.83 Drive 3 (RX1217sas-6)
.1.3.6.1.4.1.6574.2.1.1.12.84 Drive 10 (RX1217sas-7)
.1.3.6.1.4.1.6574.2.1.1.12.85 Drive 5 (RX1217sas-7)
.1.3.6.1.4.1.6574.2.1.1.12.86 Drive 9 (RX1217sas-7)
.1.3.6.1.4.1.6574.2.1.1.12.87 Drive 1 (RX1217sas-7)
.1.3.6.1.4.1.6574.2.1.1.12.88 Drive 11 (RX1217sas-7)
.1.3.6.1.4.1.6574.2.1.1.12.89 Drive 4 (RX1217sas-7)
.1.3.6.1.4.1.6574.2.1.1.12.90 Drive 8 (RX1217sas-7)
.1.3.6.1.4.1.6574.2.1.1.12.91 Drive 12 (RX1217sas-7)
.1.3.6.1.4.1.6574.2.1.1.12.92 Drive 6 (RX1217sas-7)
.1.3.6.1.4.1.6574.2.1.1.12.93 Drive 2 (RX1217sas-7)
.1.3.6.1.4.1.6574.2.1.1.12.94 Drive 7 (RX1217sas-7)
.1.3.6.1.4.1.6574.2.1.1.12.95 Drive 3 (RX1217sas-7)
.1.3.6.1.4.1.6574.2.1.1.13.0 1
.1.3.6.1.4.1.6574.2.1.1.13.1 1
.1.3.6.1.4.1.6574.2.1.1.13.2 1
.1.3.6.1.4.1.6574.2.1.1.13.3 1
.1.3.6.1.4.1.6574.2.1.1.13.4 1
.1.3.6.1.4.1.6574.2.1.1.13.5 1
.1.3.6.1.4.1.6574.2.1.1.13.6 1
.1.3.6.1.4.1.6574.2.1.1.13.7 1
.1.3.6.1.4.1.6574.2.1.1.13.8 1
.1.3.6.1.4.1.6574.2.1.1.13.9 1
.1.3.6.1.4.1.6574.2.1.1.13.10 1
.1.3.6.1.4.1.6574.2.1.1.13.11 1
.1.3.6.1.4.1.6574.2.1.1.13.12 1
.1.3.6.1.4.1.6574.2.1.1.13.13 1
.1.3.6.1.4.1.6574.2.1.1.13.14 1
.1.3.6.1.4.1.6574.2.1.1.13.15 1
.1.3.6.1.4.1.6574.2.1.1.13.16 1
.1.3.6.1.4.1.6574.2.1.1.13.17 1
.1.3.6.1.4.1.6574.2.1.1.13.18 1
.1.3.6.1.4.1.6574.2.1.1.13.19 1
.1.3.6.1.4.1.6574.2.1.1.13.20 1
.1.3.6.1.4.1.6574.2.1.1.13.21 1
.1.3.6.1.4.1.6574.2.1.1.13.22 1
.1.3.6.1.4.1.6574.2.1.1.13.23 1
.1.3.6.1.4.1.6574.2.1.1.13.24 1
.1.3.6.1.4.1.6574.2.1.1.13.25 1
.1.3.6.1.4.1.6574.2.1.1.13.26 1
.1.3.6.1.4.1.6574.2.1.1.13.27 1
.1.3.6.1.4.1.6574.2.1.1.13.28 1
.1.3.6.1.4.1.6574.2.1.1.13.29 1
.1.3.6.1.4.1.6574.2.1.1.13.30 1
.1.3.6.1.4.1.6574.2.1.1.13.31 1
.1.3.6.1.4.1.6574.2.1.1.13.32 1
.1.3.6.1.4.1.6574.2.1.1.13.33 1
.1.3.6.1.4.1.6574.2.1.1.13.34 1
.1.3.6.1.4.1.6574.2.1.1.13.35 1
.1.3.6.1.4.1.6574.2.1.1.13.36 1
.1.3.6.1.4.1.6574.2.1.1.13.37 1
.1.3.6.1.4.1.6574.2.1.1.13.38 1
.1.3.6.1.4.1.6574.2.1.1.13.39 1
.1.3.6.1.4.1.6574.2.1.1.13.40 1
.1.3.6.1.4.1.6574.2.1.1.13.41 1
.1.3.6.1.4.1.6574.2.1.1.13.42 1
.1.3.6.1.4.1.6574.2.1.1.13.43 1
.1.3.6.1.4.1.6574.2.1.1.13.44 1
.1.3.6.1.4.1.6574.2.1.1.13.45 1
.1.3.6.1.4.1.6574.2.1.1.13.46 1
.1.3.6.1.4.1.6574.2.1.1.13.47 1
.1.3.6.1.4.1.6574.2.1.1.13.48 1
.1.3.6.1.4.1.6574.2.1.1.13.49 1
.1.3.6.1.4.1.6574.2.1.1.13.50 1
.1.3.6.1.4.1.6574.2.1.1.13.51 1
.1.3.6.1.4.1.6574.2.1.1.13.52 1
.1.3.6.1.4.1.6574.2.1.1.13.53 1
.1.3.6.1.4.1.6574.2.1.1.13.54 1
.1.3.6.1.4.1.6574.2.1.1.13.55 1
.1.3.6.1.4.1.6574.2.1.1.13.56 1
.1.3.6.1.4.1.6574.2.1.1.13.57 1
.1.3.6.1.4.1.6574.2.1.1.13.58 1
.1.3.6.1.4.1.6574.2.1.1.13.59 1
.1.3.6.1.4.1.6574.2.1.1.13.60 1
.1.3.6.1.4.1.6574.2.1.1.13.61 1
.1.3.6.1.4.1.6574.2.1.1.13.62 1
.1.3.6.1.4.1.6574.2.1.1.13.63 1
.1.3.6.1.4.1.6574.2.1.1.13.64 1
.1.3.6.1.4.1.6574.2.1.1.13.65 1
.1.3.6.1.4.1.6574.2.1.1.13.66 1
.1.3.6.1.4.1.6574.2.1.1.13.67 1
.1.3.6.1.4.1.6574.2.1.1.13.68 1
.1.3.6.1.4.1.6574.2.1.1.13.69 1
.1.3.6.1.4.1.6574.2.1.1.13.70 1
.1.3.6.1.4.1.6574.2.1.1.13.71 1
.1.3.6.1.4.1.6574.2.1.1.13.72 1
.1.3.6.1.4.1.6574.2.1.1.13.73 1
.1.3.6.1.4.1.6574.2.1.1.13.74 1
.1.3.6.1.4.1.6574.2.1.1.13.75 1
.1.3.6.1.4.1.6574.2.1.1.13.76 1
.1.3.6.1.4.1.6574.2.1.1.13.77 1
.1.3.6.1.4.1.6574.2.1.1.13.78 1
.1.3.6.1.4.1.6574.2.1.1.13.79 1
.1.3.6.1.4.1.6574.2.1.1.13.80 1
.1.3.6.1.4.1.6574.2.1.1.13.81 1
.1.3.6.1.4.1.6574.2.1.1.13.82 1
.1.3.6.1.4.1.6574.2.1.1.13.83 1
.1.3.6.1.4.1.6574.2.1.1.13.84 1
.1.3.6.1.4.1.6574.2.1.1.13.85 1
.1.3.6.1.4.1.6574.2.1.1.13.86 1
.1.3.6.1.4.1.6574.2.1.1.13.87 1
.1.3.6.1.4.1.6574.2.1.1.13.88 1
.1.3.6.1.4.1.6574.2.1.1.13.89 1
.1.3.6.1.4.1.6574.2.1.1.13.90 1
.1.3.6.1.4.1.6574.2.1.1.13.91 1
.1.3.6.1.4.1.6574.2.1.1.13.92 1
.1.3.6.1.4.1.6574.2.1.1.13.93 1
.1.3.6.1.4.1.6574.2.1.1.13.94 1
.1.3.6.1.4.1.6574.2.1.1.13.95 1
This is unknown for all of them and this is the problem.
As per this line we expect a different role.
Could that be a bug again with Synology disks?
Can you check with Synology support why it’s unknown?
tilgeh
April 16, 2024, 6:18am
13
Thanks for your response. We’ve reached out to Synology Support and received the following answers. This information is shared for those who may be facing similar issues:
Regarding the unknown disk role, our developers are currently working on it. The good news is that an immediate workaround solution has been created by our developers for you should you need it. Attached to this message is a script that has been created by our developers and can be run as a startup script on your NAS to ensure that the issue is no longer present until an official fix has been released via our normal channels.
Here are the steps on how to implement the workaround solution on your NAS:
Step 1: Download the attached script via SSH or you can upload it to the NAS manually.
- wget supweb.synology.com/support_web/KI_76290/workaround.sh
Step 2: Run the script
- bash [script path] mock
Step 3: Create a bootup task in DSM Task Scheduler (with root permission) for the workaround.
Here is an example:
Step 1. cd /volume1/test;wget supweb.synology.com/support_web/KI_76290/workaround.sh
Step 2. bash /volume1/test/workaround.sh mock
Step 3.
Thanks for pasting the response from Synology support. This will definitely be helpful for a lot of people.
Does it work now after applying the workaround solution from Synology?
tilgeh
April 16, 2024, 6:11pm
15
Yes Checkmk shows the “Allocation status” from these Disks now as Hotspare:
