I get the error: Failed to send notificaion. Status: 400, Response: Invalid webhook URL.
When I open the webhook URL manually I also get an errror: “Invalid webhook request - GET not supported”
Anyone has an idea how to solve this issue?
Thanks in advance.
Hi, thank you for your response.
Sincerly I didn’t understand where I have to move the script file, can you give me the path?
Is this the same path where I added the other script?
download the mkp file to your Checkmk and then: Setup > Maintenance: Extension packages > Upload package. Checkmk will upload and extract into the correct path.
If you don’t have the Enterprise Edition: Copy the mkp file into your site directory and then install on the CLI: mkp install FILE
