Hello, is there any option to monitor old versions of Kubernetes in CMK 2.2 version as was possible in CMK 2.1 version?
There were possible to use old version as ** Kubernetes (depracated) ** datasource in CMK 2.1, but its not possible to set in CMK 2.2.
Yeah, of course, best way is to upgrade K8s, but i large enviroment we have some solutions, where is not possible to upgrade K8s, andI would like to avoid for running separe site CMK 2.1 version for that.
Which informations of a Kubernetes cluster do you want to check?
Depending on the answer, maybe the k8s local check could be an alternative? It works with most versions of Kubernetes and all Checkmk 2.x versions. It monitors the availability of Kubernetes objects like Pods, Services, Deployments etc, but does not collect performance data.
