Timeout of check_mk_agent because of fileinfo
CMK version: 2.3.0p21
OS version: Ubuntu 24.04
We’re trying to monitor a backup server which collects the data from about 100 servers. But we got the problem, that the Checkmk Agent always runs into a timeout, because it need about 20 minutes to complete.
This is due to the large number of files that we need to check.
I have the following setting in the fileinfo.cfg:
/data0/rsnapshot/*/*/*/sicherung/mysql/*.sql
/data0/rsnapshot/*/*/*/sicherung/etc/*.tar.gz
/data0/rsnapshot/*/*/*/sicherung/www/*.tar.gz
I also made a group pattern, because this is the result for the few times the check runs through:
Is there any way to outsource the fileinfo part so that I can run it asynchronously via a cronjob, create a textfile with the results and just parse this textfile?
This would be much much faster and the check would not run into a timeout nearly evertime it runs.
Thanks in advance
Man-in-Black
Fist of all don’t use fileinfo, use mk_filestats instead.
In mk_filestats you can play around with the filename, filesize and fileage filters and the diffrent aggregation options to get the best result for your needs. On servers with many files I often use count_only or extremes_only as aggregation.
In addition, mk_filestats can also be executed async.
Thanks for the reply.
I’ve tested it with the mk_filestats.
But I got the same problem.
The agents just runs like forever.
I think I will try to replicate the logic of the script to write the results into a textfile and then just parse this file.
So I can schedule this script via cron but the agent will just run in time.
I’ve ended up by writing a own local script which will do the same, but runs within a couple of seconds.
If you’re interested in it:
#!/usr/bin/env python3
import os
import glob
import time
def check_backups(path, file_type):
    files = glob.glob(path)
    count = len(files)
    total_size = sum(os.path.getsize(f) for f in files)
    newest_file = max(files, key=os.path.getmtime) if files else None
    newest_time = os.path.getmtime(newest_file) if newest_file else 0
    age_seconds = time.time() - newest_time
    status = 0
    if age_seconds > 36 * 3600:
        status = 2
    elif age_seconds > 24 * 3600:
        status = 1
    return count, total_size, age_seconds, status
def format_time(seconds):
    days, remainder = divmod(int(seconds), 86400)
    hours, remainder = divmod(remainder, 3600)
    minutes, _ = divmod(remainder, 60)
    return f"{days}d {hours}h {minutes}m"
def format_size(size_bytes):
    size_mb = size_bytes / (1024 * 1024)
    if size_mb < 1000:
        return f"{size_mb:.2f} MB"
    size_gb = size_mb / 1024
    if size_gb < 1000:
        return f"{size_gb:.2f} GB"
    size_tb = size_gb / 1024
    return f"{size_tb:.2f} TB"
mysql_files = check_backups("/data0/rsnapshot/*/*/*/sicherung/mysql/*.sql", "MySQL")
etc_files = check_backups("/data0/rsnapshot/*/*/*/sicherung/etc/*.tar.gz", "etc")
www_files = check_backups("/data0/rsnapshot/*/*/*/sicherung/www/*.tar.gz", "www")
for file_type, (count, size, age, status) in [
    ("MySQL", mysql_files),
    ("etc", etc_files),
    ("www", www_files)
    status_text = ["OK", "WARN", "CRIT"][status]
    formatted_age = format_time(age)
    formatted_size = format_size(size)
    print(f"{status} RBackup_{file_type} count={count}|size={size}|age={age:.0f} {status_text} - {count} files, {formatted_size}, {formatted_age} old")
not as customizable as the builtin version, but way faster and enough for my specific usecase.
Thanks for the help.
