I’m running CheckMK Enterprise 1.6.0p17, and recently I’ve had a couple of issues when activating changes on one distributed node:
State: Failed. Started at: 17:48:12. Finished at: 17:50:03.
Failed: Got invalid data:
Internal automation error: Your request timed out after 110 seconds. This issue may be related to a local configuration problem or a request which works with a too large number of objects. But if you think this issue is a bug, please send a crash report.
File “/omd/sites/ger0/lib/python/cmk/gui/wato/pages/automation.py”, line 186, in _execute_automation_command
html.write(repr(automation.execute(automation.get_request())))
File “/omd/sites/ger0/lib/python/cmk/gui/wato/pages/activate_changes.py”, line 519, in execute
return cmk.gui.watolib.activate_changes.execute_activate_changes(request.domains)
File “/omd/sites/ger0/lib/python/cmk/gui/watolib/activate_changes.py”, line 1285, in execute_activate_changes
warnings = domain_class().activate()
File “/omd/sites/ger0/lib/python/cmk/gui/watolib/config_domains.py”, line 69, in activate
return check_mk_local_automation(config.wato_activation_method)
File “/omd/sites/ger0/lib/python/cmk/gui/watolib/automations.py”, line 112, in check_mk_local_automation
outdata = p.stdout.read()
File “/omd/sites/ger0/lib/python/cmk/gui/htmllib.py”, line 790, in handle_request_timeout
“issue is a bug, please send a crash report.”) % duration)
RequestTimeout: Your request timed out after 110 seconds. This issue may be related to a local configuration problem or a request which works with a too large number of objects. But if you think this issue is a bug, please send a crash report.
I’ve looked at similar topics, for this issue, and one suggestion mentions running this command:
cmk --debug -vvR
This completes successfully with no errors. I did note this line, perhaps unrelated:
Time needed [cmc_all_hosts]: 153.53 sec
This node is busier than other distributed nodes, but I don’t appear to be constrained on cpu or memory. Any ideas?
