Hi Team, we are planning to upgrade checkmk RAW 1.6 to 2.2 or 2.3. is it ok to clone the VM of 1.6 and upgrade to 2.0 >2.1 >2.2 or 2.3
or
Create a clean new environment with RH linux 8 or 9 and migrate rules and hosts (semi-manually. It is bit manual work, but an upgrade over so many versions might end up being application functionality issues? Since its a major upgrade from 1.6 to 2.2 or 2.3
Please suggest.
Upgrade to 2.2 (assuming you are on Linux 7 etc) and then backup/restore to 2.2 on a new Linux 8/9 host. Once everything bedded in upgrade to 2.3 on the new host.
There is a way to do the backup restore over the network directly which helps reduce the downtime.
