Total Traffic Monitoring for Multiple Hosts/Interfaces
Hi All,
I have created a custom graph where I added several interfaces from different hosts to track their IN/OUT bandwidth individually. I would like to know if it’s possible to create an aggregated graph that shows the sum of all these interfaces as a single, so I can have a dedicated custom graph displaying the total bandwidth. Is this possible?
Here is a sample of the created graph:
I would like to create a total that sums the IN/OUT bandwidth of all the interfaces mentioned above and display it as a single aggregated value.
Note: I only have GUI access and cannot use the Linux/server side.
Thanks a lot in Advanced.
You can select all the metrics in the custom graph and then let it calculate the sum.
Hi Robert,
Thanks a lot for your reply. I can now select all the metrics and calculate the sum, but when I do that, all the individual metrics disappear from the graph and only the summed metric remains.
But that works as well, I can build another custom graph based on the total.
Is there a way to keep both the summed value and the individual metrics together in the same graph?
Many Thanks.
You can copy the summed graph and disassemble the sum again. With that you have all the individual metrics and a total.
Thank you so much, Robert!
Wishing you a wonderful rest of the day.
