Trouble after upgrading to 2.1 agent
after upgrading to the new 2.1 version and register the agent as described in Monitoring Linux - The new agent for Linux in detail I get the following error: [agent] Host is registered for TLS but not using it
Am I missing something?
CMK version:
2.1
OS version:
ubuntu 20.04
[agent] Host is registered for TLS but not using it**CRIT**
Checkmk version 2.1.0
Trying to acquire lock on /omd/sites/timdebruijn/var/check_mk/license_usage/next_run
Got lock on /omd/sites/timdebruijn/var/check_mk/license_usage/next_run
Trying to acquire lock on /omd/sites/timdebruijn/var/check_mk/license_usage/history.json
Got lock on /omd/sites/timdebruijn/var/check_mk/license_usage/history.json
Releasing lock on /omd/sites/timdebruijn/var/check_mk/license_usage/history.json
Released lock on /omd/sites/timdebruijn/var/check_mk/license_usage/history.json
Releasing lock on /omd/sites/timdebruijn/var/check_mk/license_usage/next_run
Released lock on /omd/sites/timdebruijn/var/check_mk/license_usage/next_run
+ FETCHING DATA
[cpu_tracking] Start [7f4e226d3fa0]
[TCPFetcher] Fetch with cache settings: DefaultAgentFileCache(rss.timdebruijn.lan, base_path=/omd/sites/timdebruijn/tmp/check_mk/cache, max_age=MaxAge(checking=0, discovery=120, inventory=120), disabled=False, use_outdated=False, simulation=False)
Not using cache (Does not exist)
Connecting via TCP to 192.168.1.15:6556 (5.0s timeout)
Closing TCP connection to 192.168.1.15:6556
[cpu_tracking] Stop [7f4e226d3fa0 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.08999999985098839))]
[cpu_tracking] Start [7f4e226cd4c0]
[PiggybackFetcher] Fetch with cache settings: NoCache(rss.timdebruijn.lan, base_path=/omd/sites/timdebruijn/tmp/check_mk/data_source_cache/piggyback, max_age=MaxAge(checking=0, discovery=120, inventory=120), disabled=True, use_outdated=False, simulation=False)
Piggyback file '/omd/sites/timdebruijn/tmp/check_mk/piggyback/rss.timdebruijn.lan/vcsa.timdebruijn.nl': Successfully processed from source 'vcsa.timdebruijn.nl'
No piggyback files for '192.168.1.15'. Skip processing.
[cpu_tracking] Stop [7f4e226cd4c0 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.0))]
+ PARSE FETCHER RESULTS
  -> Not adding sections: Host is registered for TLS but not using it
<<<esx_vsphere_vm:cached(1653924216,90)>>> / Transition NOOPParser -> HostSectionParser
No persisted sections
  -> Add sections: ['esx_vsphere_vm', 'labels']
Received no piggyback data
[cpu_tracking] Start [7f4e226cda90]
value store: synchronizing
Trying to acquire lock on /omd/sites/timdebruijn/tmp/check_mk/counters/rss.timdebruijn.lan
Got lock on /omd/sites/timdebruijn/tmp/check_mk/counters/rss.timdebruijn.lan
Releasing lock on /omd/sites/timdebruijn/tmp/check_mk/counters/rss.timdebruijn.lan
Released lock on /omd/sites/timdebruijn/tmp/check_mk/counters/rss.timdebruijn.lan
CPU load             PEND - Check plugin received no monitoring data
CPU utilization      PEND - Check plugin received no monitoring data
Check_MK Agent       PEND - Check plugin received no monitoring data
Disk IO SUMMARY      PEND - Check plugin received no monitoring data
ESX CPU              demand is 0.147 Ghz, 1 virtual CPUs
ESX Datastores       Stored on nvme1-esxi2 (931.25 GB/91.7% free)
ESX Guest Tools      VMware Tools are installed, but are not managed by VMWare
ESX Heartbeat        Heartbeat status is green
ESX Hostsystem       Running on 192.168.1.32
ESX Memory           Host: 1.03 GB, Guest: 327.00 MB, Ballooned: 0.00 B, Private: 1.00 GB, Shared: 0.00 B
ESX Mounted Devices  HA functionality guaranteed
ESX Name             rss.timdebruijn.lan
ESX Snapshots        Count: 0
Filesystem /         PEND - Check plugin received no monitoring data
Filesystem /boot     PEND - Check plugin received no monitoring data
Interface 2          PEND - Check plugin received no monitoring data
Interface 3          PEND - Check plugin received no monitoring data
Kernel Performance   PEND - Check plugin received no monitoring data
Memory               PEND - Check plugin received no monitoring data
Mount options of /   PEND - Check plugin received no monitoring data
Mount options of /boot PEND - Check plugin received no monitoring data
Number of threads    PEND - Check plugin received no monitoring data
PostgreSQL ANALYZE MAIN/miniflux PEND - Check plugin received no monitoring data
PostgreSQL ANALYZE MAIN/postgres PEND - Check plugin received no monitoring data
PostgreSQL Bloat MAIN/miniflux PEND - Check plugin received no monitoring data
PostgreSQL Bloat MAIN/postgres PEND - Check plugin received no monitoring data
PostgreSQL Connection Time MAIN PEND - Check plugin received no monitoring data
PostgreSQL Connections MAIN/miniflux PEND - Check plugin received no monitoring data
PostgreSQL Connections MAIN/postgres PEND - Check plugin received no monitoring data
PostgreSQL DB MAIN/miniflux Size PEND - Check plugin received no monitoring data
PostgreSQL DB MAIN/miniflux Statistics PEND - Check plugin received no monitoring data
PostgreSQL DB MAIN/postgres Size PEND - Check plugin received no monitoring data
PostgreSQL DB MAIN/postgres Statistics PEND - Check plugin received no monitoring data
PostgreSQL DB MAIN/template1 Size PEND - Check plugin received no monitoring data
PostgreSQL DB MAIN/template1 Statistics PEND - Check plugin received no monitoring data
PostgreSQL Daemon Sessions MAIN PEND - Check plugin received no monitoring data
PostgreSQL Instance MAIN PEND - Check plugin received no monitoring data
PostgreSQL Locks MAIN/miniflux PEND - Check plugin received no monitoring data
PostgreSQL Locks MAIN/postgres PEND - Check plugin received no monitoring data
PostgreSQL Query Duration MAIN/miniflux PEND - Check plugin received no monitoring data
PostgreSQL Query Duration MAIN/postgres PEND - Check plugin received no monitoring data
PostgreSQL VACUUM MAIN/miniflux PEND - Check plugin received no monitoring data
PostgreSQL VACUUM MAIN/postgres PEND - Check plugin received no monitoring data
PostgreSQL Version main PEND - Check plugin received no monitoring data
Systemd Service Summary PEND - Check plugin received no monitoring data
Systemd Timesyncd Time PEND - Check plugin received no monitoring data
TCP Connections      PEND - Check plugin received no monitoring data
Uptime               PEND - Check plugin received no monitoring data
WireGuard wg0        PEND - Check plugin received no monitoring data
WireGuard wg0 Peer pdLb1t5BLDupVDIk3/DKzOmYYf6Ak3ioz9tBFWBT1G8 PEND - Check plugin received no monitoring data
[cpu_tracking] Stop [7f4e226cda90 - Snapshot(process=posix.times_result(user=0.010000000000000009, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.010000001639127731))]
[agent] Host is registered for TLS but not using it(!!), [piggyback] Successfully processed from source 'vcsa.timdebruijn.nl', Missing monitoring data for plugins: checkmk_agent, cpu_loads, cpu_threads, df, diskstat, kernel_performance, kernel_util, lnx_if, mem_linux, mounts, postgres_bloat, postgres_conn_time, postgres_connections, postgres_instances, postgres_locks, postgres_query_duration, postgres_sessions, postgres_stat_database, postgres_stat_database_size, postgres_stats, postgres_version, systemd_units_services_summary, tcp_conn_stats, timesyncd, uptime, wireguard(!), execution time 0.1 sec | execution_time=0.100 user_time=0.010 system_time=0.000 children_user_time=0.000 children_system_time=0.000 cmk_time_agent=0.090
This was already performed: Monitoring Linux - The new agent for Linux in detail
Yes I did use the” cmk-agent-ctl register command, after that I got this message
Could you please check who is claiming port 6556?
ss -tulpn | grep 6556
This should be cmk-agent-ctl in daemon mode. If it is xinetd remove the Xinetd config file for the Checkmk agent and just reinstall the agent package. If it is systemd please give us the output of
systemctl --version
root@rss:/home/admin# ss -tulpn | grep 6556
tcp    LISTEN  0       4096                       *:6556                *:*      users:(("systemd",pid=1,fd=60))
root@rss:/home/admin# systemctl --version
systemd 245 (245.4-4ubuntu3.17)
+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid
This looks like a leftover service from 2.0. Could you please stop the service:
systemctl status check-mk-agent.socket
Then confirm it is stopped:
ss -tulpn | grep 6556 # should be empty
Then reinstall the agent package and check whether the cmk-agent-ctl does now claim 6556. If this does not help we’ll dig through the post install script tomorrow.
Hi mschlenker,
Thank you for your suggestions. unfortunately it did not work:
root@rss:/home/admin# systemctl status check-mk-agent.socket
● check-mk-agent.socket - Local Checkmk agent socket
     Loaded: loaded (/lib/systemd/system/check-mk-agent.socket; enabled; vendor preset: enabled)
     Active: active (listening) since Mon 2022-05-30 18:46:54 UTC; 12min ago
   Triggers: ● check-mk-agent@0.service
     Listen: /run/check-mk-agent.socket (Stream)
   Accepted: 0; Connected: 0;
      Tasks: 0 (limit: 1066)
     Memory: 52.0K
     CGroup: /system.slice/check-mk-agent.socket
May 30 18:46:54 rss systemd[1]: Starting Local Checkmk agent socket.
May 30 18:46:54 rss systemd[1]: Listening on Local Checkmk agent socket.
root@rss:/home/admin# systemctl stop check-mk-agent.socket
root@rss:/home/admin# systemctl disable check-mk-agent.socket
Removed /etc/systemd/system/sockets.target.wants/check-mk-agent.socket.
root@rss:/home/admin# ls
check-mk-agent_2.1.0-1_all.deb  index.html
root@rss:/home/admin# dpkg -i check-mk-agent_2.1.0-1_all.deb
(Reading database ... 110354 files and directories currently installed.)
Preparing to unpack check-mk-agent_2.1.0-1_all.deb ...
Removing systemd units: check-mk-agent@.service, check-mk-agent-async.service, cmk-agent-ctl-daemon.service, check-mk-agent.socket
Unpacking check-mk-agent (2.1.0-1) over (2.1.0-1) ...
Setting up check-mk-agent (2.1.0-1) ...
Deploying systemd units: check-mk-agent@.service check-mk-agent-async.service cmk-agent-ctl-daemon.service check-mk-agent.socket
Deployed systemd
Creating/updating cmk-agent user account ...
Activating systemd unit 'check-mk-agent-async.service'...
Activating systemd unit 'cmk-agent-ctl-daemon.service'...
Activating systemd unit 'check-mk-agent.socket'...
Created symlink /etc/systemd/system/sockets.target.wants/check-mk-agent.socket → /lib/systemd/system/check-mk-agent.socket.
tcp    LISTEN  0       4096                       *:6556                *:*      users:(("systemd",pid=1,fd=86))
Looking at the post install script, there might be confusion regarding
  • /usr/lib/systemd/system
  • /lib/systemd/system
On Ubuntu 20.04 one should be a symlink to the other. However this is not guaranteed after upgrade from older Ubuntu versions. If both directories are different and both directories contain config files with cmk or check-mk in its name: First uninstall, then remove the remaining config files, then reinstall.
This is a fresh install of 20.04, never done a dist-upgrade…
So I did a apt purge check-mk-agent, and a reinstall of the agent, now it works:
tcp    LISTEN  0       4096                       *:6556                *:*      users:(("cmk-agent-ctl",pid=21196,fd=9))
To help us tracking down: Are you using CRE oder CEE? In case CEE: Vanilla agent or baked agent?
I’m using the CRE version.
I too had problems after upgrading to 2.1 agent (Checkmk Raw Edition 2.1.0)
Systemd Service Summary Total: 153, Disabled: 2, Failed: 2, 2 services failed (cmk-agent-ctl-daemon, systemd-networkd-wait-online)**CRIT**
tls enabled but not being used
registration OK
but port 6556 in use
root@ssfdb1:/tmp#  ss -tulpn | grep 6556
tcp     LISTEN   0        4096                   *:6556                 *:*      users:(("**systemd**",pid=1,fd=82))
root@ssfdb1:/tmp# systemctl start cmk-agent-ctl-daemon.service
root@ssfdb1:/tmp# tail -f /var/log/syslog
May 31 05:04:05 hostname_redacted systemd[1]: Stopped Checkmk agent controller daemon.
May 31 05:04:05 hostname_redacted systemd[1]: Started Checkmk agent controller daemon.
May 31 05:04:06 hostname_redacted cmk-agent-ctl[22636]: ERROR [cmk_agent_ctl] **Address in use** (os error 98)
Fixed by
apt install ./check-mk-agent_2.1.0-1_all.deb
tcp     LISTEN   0        4096                   *:6556                 *:*      users:(("**cmk-agent-ctl**",pid=27176,fd=9))
root@ssfdb1:/tmp#
Phew
That was painful
Thanks Timdebruijn
Julian
Hello together, i got the an Simular Issue after an Upgrade from the 2.0.0p24 to 2.1.0p2 RAW Edition.
Jun 17 10:57:15 nc systemd[1]: cmk-agent-ctl-daemon.service: Scheduled restart job, restart counter is at 2.
Jun 17 10:57:15 nc systemd[1]: Stopped Checkmk agent controller daemon.
Jun 17 10:57:15 nc systemd[1]: cmk-agent-ctl-daemon.service: Start request repeated too quickly.
Jun 17 10:57:15 nc systemd[1]: cmk-agent-ctl-daemon.service: Failed with result ‘exit-code’.
Jun 17 10:57:15 nc systemd[1]: Failed to start Checkmk agent controller daemon.
Tried to adjust the Time in here /etc/systemd/system/multi-user.target.wants/cmk-agent-ctl-daemon.service with an StartLimitInterval=30, but no changes.
Is the Post here OK or should i open a new one ?
2.1.0p4 should fix this issue.
OK, stopping the socket, purging the old install and making sure 6556 is free bedfore installing the 2.1 agent should do the trick.
systemctl stop check_mk.socket
Tell me whether it was the vanilla agent included in all editions or an agent built with the bakery (post install and pre remove differs here) and I’ll file a bug internally.
did this get figured out? I think i may be encountering it
Having problems getting a check-mk-agent_2.1.0p11-1_all.deb to run on a kali 2022.3 box.
# installing
apt install ./check-mk-agent_2.1.0p11-1_all.deb
# checking the services
systemctl status check-mk-agent-async.service
● check-mk-agent-async.service - Checkmk agent - Asynchronous background tasks
     Loaded: loaded (/lib/systemd/system/check-mk-agent-async.service; disabled; preset: disabled)
     Active: active (running) since Sat 2022-09-17 23:04:10 CEST; 2min 51s ago
   Main PID: 1119 (check_mk_agent)
      Tasks: 2 (limit: 4629)
     Memory: 1.5M
        CPU: 238ms
     CGroup: /system.slice/check-mk-agent-async.service
             ├─1119 /bin/bash /usr/bin/check_mk_agent
             └─1682 sleep 60
Sep 17 23:04:10 kali02red systemd[1]: Started Checkmk agent - Asynchronous background tasks.
The socket service can’t start.
× check-mk-agent.socket - Local Checkmk agent socket
     Loaded: loaded (/lib/systemd/system/check-mk-agent.socket; enabled; preset: disabled)
     Active: failed (Result: exit-code) since Sat 2022-09-17 23:04:04 CEST; 3min 20s ago
        CPU: 917us
Sep 17 23:04:04 kali02red systemd[1]: Starting Local Checkmk agent socket...
Sep 17 23:04:04 kali02red systemd[1115]: check-mk-agent.socket: Failed to resolve user cmk-agent: No such process
Sep 17 23:04:04 kali02red systemd[1]: check-mk-agent.socket: Control process exited, code=exited, status=217/USER
Sep 17 23:04:04 kali02red systemd[1]: check-mk-agent.socket: Failed with result 'exit-code'.
Sep 17 23:04:04 kali02red systemd[1]: Failed to listen on Local Checkmk agent socket.
Kali system is up-to-date and I already rebooted the box.
Any ideas??
Once you’re on 2.1.0p15 (or possibly earlier), you no longer need check_mk.socket (or other names along the same lines).
For anyone wondering by, I believe the full solution to problems when upgrading the agent from 2.0.0 to 2.1.0 is:
apt remove check-mk-agent  # Remove 2.0.xxxx
systemctl stop check_mk.socket  # May not exist, but if it does, get rid of it
systemctl disable check_mk.socket  # ...and make sure it doesn't come back again after a reboot
apt update
apt install check-mk-agent # with the intention of install 2.1.xxxx!
You’ll also need to do something like cmk-agent-ctl register ... to switch your agent into SSL mode (and not legacy mode), but that’s a different subject.
