CMK version: 2.1.0p17
OS version: Oracle Linux 9.1
Issue: I am trying to monitor our ElasticSearch (v8.6.0) server, running on Ubuntu 22.04.1 (LTS). I have the CMK agent installed on the machine itself and of course it is reporting back OS level stats as expected. I’m running in to an issue trying to monitor Elastic using the built-in checks in CMK. I add them as monitoring rules in the WATO, but they don’t appear on the host. I’ve also tried to add them as enforced services, but they just don’t leave the pending state. Any help is much appreciated!
Checkmk version 2.1.0p17
Trying to acquire lock on /omd/sites/it/var/check_mk/license_usage/next_run
Got lock on /omd/sites/it/var/check_mk/license_usage/next_run
Trying to acquire lock on /omd/sites/it/var/check_mk/license_usage/history.json
Got lock on /omd/sites/it/var/check_mk/license_usage/history.json
Releasing lock on /omd/sites/it/var/check_mk/license_usage/history.json
Released lock on /omd/sites/it/var/check_mk/license_usage/history.json
Releasing lock on /omd/sites/it/var/check_mk/license_usage/next_run
Released lock on /omd/sites/it/var/check_mk/license_usage/next_run
Updating IPv4 DNS cache for <HOSTNAME>: <IP>
Trying to acquire lock on /omd/sites/it/var/check_mk/ipaddresses.cache
Got lock on /omd/sites/it/var/check_mk/ipaddresses.cache
Releasing lock on /omd/sites/it/var/check_mk/ipaddresses.cache
Released lock on /omd/sites/it/var/check_mk/ipaddresses.cache
+ FETCHING DATA
[cpu_tracking] Start [7fa827f7ccd0]
[PiggybackFetcher] Fetch with cache settings: NoCache(<HOSTNAME>, base_path=/omd/sites/it/tmp/check_mk/data_source_cache/piggyback, max_age=MaxAge(checking=0, discovery=120, inventory=120), disabled=True, use_outdated=False, simulation=False)
No piggyback files for '<HOSTNAME>'. Skip processing.
No piggyback files for '<IP>'. Skip processing.
[cpu_tracking] Stop [7fa827f7ccd0 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.0))]
+ PARSE FETCHER RESULTS
No persisted sections
-> Add sections: []
Received no piggyback data
[cpu_tracking] Start [7fa827f044c0]
value store: synchronizing
Trying to acquire lock on /omd/sites/it/tmp/check_mk/counters/<HOSTNAME>
Got lock on /omd/sites/it/tmp/check_mk/counters/<HOSTNAME>
Releasing lock on /omd/sites/it/tmp/check_mk/counters/<HOSTNAME>
Released lock on /omd/sites/it/tmp/check_mk/counters/<HOSTNAME>
[cpu_tracking] Stop [7fa827f044c0 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.009999999776482582))]
execution time 0.0 sec | execution_time=0.010 user_time=0.000 system_time=0.000 children_user_time=0.000 children_system_time=0.000 cmk_time_agent=0.000
