Hi there,
i’m having issues on getting the ldaps check to work on a 1.6.0p8 CRE.
The ldap check (with almost exactly the same settings) is working as expected.
The Root Certificates are installed on the ubuntu 18.04 machine aswell and a
‘openssl s_client -connect fqdn.dc.de:636’ shows no certificate validation errors.
The normal ldap check:
root@Server:/usr/local/share/ca-certificates# /opt/omd/versions/1.6.0p8.cre/lib/nagios/plugins/checkldap -H fqdn.dc.de -b ‘DC=fqdn,DC=domain,DC=de’ -D ‘checkmk@fqdn.dc.de’ -P ‘password’
LDAP OK - 0,004 seconds response time|time=0,003631s;;;0,000000
Ldaps: with error:
root@Server:/usr/local/share/ca-certificates# /opt/omd/versions/1.6.0p8.cre/lib/nagios/plugins/check_ldaps -H fqdn.dc.de -b ‘DC=fqdn,DC=domain,DC=de’ -D ‘checkmk@fqdn.dc.de’ -P ‘password’ -p 636 -v
ldap_bind: Can’t contact LDAP server (-1)
additional info: (unknown error code)
Could not bind to the LDAP server
Has anynone an idea where I can look for a more detailed error message, or what that could be ?
Kind regards,
Constantin
