Unable to activate Changes for central site. Error running automation call restart (exit code 1), error:... TypeError: tuple indices must be integers or slices, not str
CMK version: 2.4.0p32
OS version: RHEL 9.7
Started at: 08:19:01. Finished at: 08:19:04.Error running automation call restart (exit code 1), error:
An error occurred: Error creating configuration: Traceback (most recent call last):
  File "/omd/sites/wato/lib/python3/cmk/base/cee/microcore_config.py", line 2177, in _hosts_worker
    hosts_data = _compute_worker_hosts_data(
  File "/omd/sites/wato/lib/python3/cmk/base/cee/microcore_config.py", line 2065, in _compute_worker_hosts_data
    helper_config_manager.get_host_data(
  File "/omd/sites/wato/lib/python3/cmk/base/cee/microcore_config.py", line 3050, in get_host_data
    host_class(config_cache, hostname, hosts_config, passwords, ip_address_of),
  File "/omd/sites/wato/lib/python3/cmk/base/cee/microcore_config.py", line 1320, in __init__
    host_attrs=config_cache.get_host_attributes(
  File "/omd/sites/wato/lib/python3/cmk/base/config.py", line 3521, in get_host_attributes
    attrs = self.extra_host_attributes(hostname)
  File "/omd/sites/wato/lib/python3/cmk/base/config.py", line 2353, in extra_host_attributes
    values = self.ruleset_matcher.get_host_values(host_name, ruleset)
  File "/omd/sites/wato/lib/python3/cmk/utils/rulesets/ruleset_matcher.py", line 254, in get_host_values
    self.ruleset_optimizer.get_host_ruleset(ruleset, with_foreign_hosts)
  File "/omd/sites/wato/lib/python3/cmk/utils/rulesets/ruleset_matcher.py", line 581, in get_host_ruleset
    return self.__host_ruleset_cache.setdefault(cache_id, _impl(ruleset, with_foreign_hosts))
  File "/omd/sites/wato/lib/python3/cmk/utils/rulesets/ruleset_matcher.py", line 572, in _impl
    for hostname in self._all_matching_hosts(rule["condition"], with_foreign_hosts):
Sorry for the long title.
since Friday morning we are no longer able to activate changes on our central site. After just some seconds we get the error above.
The Activation works fine for the remote sites.
We Updated to 2.4.0p32 (from 2.4.0p26) on Wednesday. Besides a Nagvis issue everything worked just fine. We were able to activate changes on Thursday. Thursday evening the server was restarted and on Friday morning the activation of changes was no longer possible for the central site.
omd restart does not fix the problem.
output of cmk -R --debug -vvv:
Trying to acquire lock on /omd/sites/wato/etc/check_mk/main.mk
Got lock on /omd/sites/wato/etc/check_mk/main.mk
Generating configuration for core (type cmc)…
Trying to acquire lock on /omd/sites/wato/var/check_mk/passwords_merged
Got lock on /omd/sites/wato/var/check_mk/passwords_merged
Releasing lock on /omd/sites/wato/var/check_mk/passwords_merged
Released lock on /omd/sites/wato/var/check_mk/passwords_merged
Trying to acquire lock on /omd/sites/wato/var/check_mk/core/helper_config/serial.mk
Got lock on /omd/sites/wato/var/check_mk/core/helper_config/serial.mk
Releasing lock on /omd/sites/wato/var/check_mk/core/helper_config/serial.mk
Released lock on /omd/sites/wato/var/check_mk/core/helper_config/serial.mk
Trying to acquire lock on /omd/sites/wato/var/check_mk/licensing/licensed_state
Got lock on /omd/sites/wato/var/check_mk/licensing/licensed_state
Releasing lock on /omd/sites/wato/var/check_mk/licensing/licensed_state
Released lock on /omd/sites/wato/var/check_mk/licensing/licensed_state
time period …(removed this lines because of the names)
Starting full compilation for all hosts
Creating global helper config…Trying to acquire lock on /omd/sites/wato/var/check_mk/core/helper_config/4811/rrd_config/cmc_log_rrdcreation
Got lock on /omd/sites/wato/var/check_mk/core/helper_config/4811/rrd_config/cmc_log_rrdcreation
Releasing lock on /omd/sites/wato/var/check_mk/core/helper_config/4811/rrd_config/cmc_log_rrdcreation
Released lock on /omd/sites/wato/var/check_mk/core/helper_config/4811/rrd_config/cmc_log_rrdcreation
Trying to acquire lock on /omd/sites/wato/var/check_mk/core/helper_config/4811/inventory_plugins_index.json
Got lock on /omd/sites/wato/var/check_mk/core/helper_config/4811/inventory_plugins_index.json
Releasing lock on /omd/sites/wato/var/check_mk/core/helper_config/4811/inventory_plugins_index.json
Released lock on /omd/sites/wato/var/check_mk/core/helper_config/4811/inventory_plugins_index.json
OK
Creating cmc protobuf configuration…Releasing lock on /omd/sites/wato/etc/check_mk/main.mk
Released lock on /omd/sites/wato/etc/check_mk/main.mk
Trying to acquire lock on /omd/sites/wato/var/check_mk/crashes/base/433666fc-7907-11f1-bb85-005056bd0e74/crash.info
Got lock on /omd/sites/wato/var/check_mk/crashes/base/433666fc-7907-11f1-bb85-005056bd0e74/crash.info
Releasing lock on /omd/sites/wato/var/check_mk/crashes/base/433666fc-7907-11f1-bb85-005056bd0e74/crash.info
Released lock on /omd/sites/wato/var/check_mk/crashes/base/433666fc-7907-11f1-bb85-005056bd0e74/crash.info
File “/omd/sites/wato/bin/cmk”, line 151, in
exit_status = modes.call(mode_name, mode_args, opts, args, trace_context)
File “/omd/sites/wato/lib/python3/cmk/base/modes/init.py”, line 91, in call
return handler(*handler_args)
File “/omd/sites/wato/lib/python3/cmk/base/modes/check_mk.py”, line 1494, in mode_restart
cmk.base.core.do_restart(
File “/omd/sites/wato/lib/python3/cmk/base/core.py”, line 92, in do_restart
core_config.do_create_config(
File “/omd/sites/wato/lib/python3/cmk/base/core_config.py”, line 289, in do_create_config
_create_core_config(
File “/omd/sites/wato/lib/python3/cmk/base/core_config.py”, line 401, in _create_core_config
core.create_config(
File “/omd/sites/wato/lib/python3/cmk/base/core_config.py”, line 75, in create_config
self._create_config(
File “/omd/sites/wato/lib/python3/cmk/base/cee/microcore_config.py”, line 3405, in _create_config
data = create_core_config(
File “/omd/sites/wato/lib/python3/cmk/base/cee/microcore_config.py”, line 3323, in create_core_config
hosts_results = _serialize_config_hosts(
File “/omd/sites/wato/lib/python3/cmk/base/cee/microcore_config.py”, line 2912, in _serialize_config_hosts
hosts.compute_configuration(
File “/omd/sites/wato/lib/python3/cmk/base/cee/microcore_config.py”, line 2553, in compute_configuration
for r in _compute_hosts_configurations(
File “/omd/sites/wato/lib/python3/cmk/base/cee/microcore_config.py”, line 3469, in _one_worker_per_chunk
raise Exception(“\n”.join(map(str, errors)))
Exception: Traceback (most recent call last):
File “/omd/sites/wato/lib/python3/cmk/base/cee/microcore_config.py”, line 2177, in _hosts_worker
File “/omd/sites/wato/lib/python3/cmk/base/cee/microcore_config.py”, line 2065, in _compute_worker_hosts_data
File “/omd/sites/wato/lib/python3/cmk/base/cee/microcore_config.py”, line 3050, in get_host_data
File “/omd/sites/wato/lib/python3/cmk/base/cee/microcore_config.py”, line 1320, in init
File “/omd/sites/wato/lib/python3/cmk/base/config.py”, line 3521, in get_host_attributes
File “/omd/sites/wato/lib/python3/cmk/base/config.py”, line 2353, in extra_host_attributes
File “/omd/sites/wato/lib/python3/cmk/utils/rulesets/ruleset_matcher.py”, line 254, in get_host_values
File “/omd/sites/wato/lib/python3/cmk/utils/rulesets/ruleset_matcher.py”, line 581, in get_host_ruleset
File “/omd/sites/wato/lib/python3/cmk/utils/rulesets/ruleset_matcher.py”, line 572, in _impl
for hostname in self._all_matching_hosts(rule[“condition”], with_foreign_hosts):
Content of the mentioned crash reports:
    "core": "cmc",
    "crash_type": "base",
    "details": {
        "argv": [
            "/omd/sites/wato/bin/cmk",
            "-R",
            "--debug",
            "-vvv"
        "env": {
            "BASH_FUNC_which%%": "() {  ( alias;\n eval ${which_declare} ) | /usr/bin/which --tty-only --read-alias --read-functions --show-tilde --show-dot $@\n}",
            "DEBUGINFOD_IMA_CERT_PATH": "/etc/keys/ima:",
            "EDITOR": "vim",
            "HISTCONTROL": "ignoredups",
            "HISTSIZE": "1000",
            "HOME": "/omd/sites/wato",
            "HOSTNAME": "v971l015",
            "LANG": "C.utf8",
            "LC_ALL": "C.utf8",
            "LD_LIBRARY_PATH": "/omd/sites/wato/local/lib:/omd/sites/wato/lib",
            "LESSOPEN": "||/usr/bin/lesspipe.sh %s",
            "LOGNAME": "wato",
            "LS_COLORS": "rs=0:di=01;34:ln=01;36:mh=00:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=40;31;01:mi=01;37;41:su=37;41:sg=30;43:ca=30;41:tw=30;42:ow=34;42:st=37;44:ex=01;32:*.tar=01;31:*.tgz=01;31:*.arc=01;31:*.arj=01;31:*.taz=01;31:*.lha=01;31:*.lz4=01;31:*.lzh=01;31:*.lzma=01;31:*.tlz=01;31:*.txz=01;31:*.tzo=01;31:*.t7z=01;31:*.zip=01;31:*.z=01;31:*.dz=01;31:*.gz=01;31:*.lrz=01;31:*.lz=01;31:*.lzo=01;31:*.xz=01;31:*.zst=01;31:*.tzst=01;31:*.bz2=01;31:*.bz=01;31:*.tbz=01;31:*.tbz2=01;31:*.tz=01;31:*.deb=01;31:*.rpm=01;31:*.jar=01;31:*.war=01;31:*.ear=01;31:*.sar=01;31:*.rar=01;31:*.alz=01;31:*.ace=01;31:*.zoo=01;31:*.cpio=01;31:*.7z=01;31:*.rz=01;31:*.cab=01;31:*.wim=01;31:*.swm=01;31:*.dwm=01;31:*.esd=01;31:*.jpg=01;35:*.jpeg=01;35:*.mjpg=01;35:*.mjpeg=01;35:*.gif=01;35:*.bmp=01;35:*.pbm=01;35:*.pgm=01;35:*.ppm=01;35:*.tga=01;35:*.xbm=01;35:*.xpm=01;35:*.tif=01;35:*.tiff=01;35:*.png=01;35:*.svg=01;35:*.svgz=01;35:*.mng=01;35:*.pcx=01;35:*.mov=01;35:*.mpg=01;35:*.mpeg=01;35:*.m2v=01;35:*.mkv=01;35:*.webm=01;35:*.webp=01;35:*.ogm=01;35:*.mp4=01;35:*.m4v=01;35:*.mp4v=01;35:*.vob=01;35:*.qt=01;35:*.nuv=01;35:*.wmv=01;35:*.asf=01;35:*.rm=01;35:*.rmvb=01;35:*.flc=01;35:*.avi=01;35:*.fli=01;35:*.flv=01;35:*.gl=01;35:*.dl=01;35:*.xcf=01;35:*.xwd=01;35:*.yuv=01;35:*.cgm=01;35:*.emf=01;35:*.ogv=01;35:*.ogx=01;35:*.aac=01;36:*.au=01;36:*.flac=01;36:*.m4a=01;36:*.mid=01;36:*.midi=01;36:*.mka=01;36:*.mp3=01;36:*.mpc=01;36:*.ogg=01;36:*.ra=01;36:*.wav=01;36:*.oga=01;36:*.opus=01;36:*.spx=01;36:*.xspf=01;36:",
            "MAIL": "/var/spool/mail/wato",
            "MAILRC": "/omd/sites/wato/etc/mail.rc",
            "MANPATH": "/omd/sites/wato/share/man:",
            "MODULEBUILDRC": "/omd/sites/wato/.modulebuildrc",
            "MP_STATE_DIRECTORY": "/omd/sites/wato/var/monitoring-plugins",
            "NAGIOS_PLUGIN_STATE_DIRECTORY": "/omd/sites/wato/var/monitoring-plugins",
            "OMD_ROOT": "/omd/sites/wato",
            "OMD_SITE": "wato",
            "PATH": "/omd/sites/wato/lib/rabbitmq/sbin:/omd/sites/wato/lib/perl5/bin:/omd/sites/wato/local/bin:/omd/sites/wato/bin:/omd/sites/wato/local/lib/perl5/bin:/usr/local/bin:/usr/bin:/usr/local/sbin:/usr/sbin",
            "PERL5LIB": "/omd/sites/wato/local/lib/perl5/lib/perl5:/omd/sites/wato/lib/perl5/lib/perl5:",
            "PERL_MM_OPT": "INSTALL_BASE=/omd/sites/wato/local/lib/perl5/",
            "PWD": "/omd/sites/wato",
            "RABBITMQ_ERLANG_COOKIE": "UZMSLSTINAOXDWLAWDTO",
            "RABBITMQ_HOME": "/omd/sites/wato",
            "RABBITMQ_NODENAME": "rabbit-wato@localhost",
            "REQUESTS_CA_BUNDLE": "/omd/sites/wato/var/ssl/ca-certificates.crt",
            "SHELL": "/bin/bash",
            "SHLVL": "1",
            "SQLITE_TMPDIR": "/omd/sites/wato/tmp",
            "SSL_CERT_FILE": "/omd/sites/wato/var/ssl/ca-certificates.crt",
            "TERM": "xterm",
            "USER": "wato",
            "XDG_DATA_DIRS": "/omd/sites/wato/.local/share/flatpak/exports/share:/var/lib/flatpak/exports/share:/usr/local/share:/usr/share",
            "_": "/omd/sites/wato/bin/cmk",
            "which_declare": "declare -f"
    "edition": "cee",
    "exc_traceback": [
            151,
            "<module>",
            "exit_status = modes.call(mode_name, mode_args, opts, args, trace_context)"
            "/omd/sites/wato/lib/python3/cmk/base/modes/__init__.py",
            91,
            "call",
            "return handler(*handler_args)"
            "/omd/sites/wato/lib/python3/cmk/base/modes/check_mk.py",
            1494,
            "mode_restart",
            "cmk.base.core.do_restart("
            "/omd/sites/wato/lib/python3/cmk/base/core.py",
            92,
            "do_restart",
            "core_config.do_create_config("
            "/omd/sites/wato/lib/python3/cmk/base/core_config.py",
            289,
            "do_create_config",
            "_create_core_config("
            401,
            "_create_core_config",
            "core.create_config("
            75,
            "create_config",
            "self._create_config("
            3405,
            "_create_config",
            "data = create_core_config("
            3323,
            "create_core_config",
            "hosts_results = _serialize_config_hosts("
            2912,
            "_serialize_config_hosts",
            "hosts.compute_configuration("
            2553,
            "compute_configuration",
            "for r in _compute_hosts_configurations("
            3469,
            "_one_worker_per_chunk",
            "raise Exception(\"\\n\".join(map(str, errors)))"
    "exc_type": "Exception",
    "exc_value": "Traceback (most recent call last):\n  File \"/omd/sites/wato/lib/python3/cmk/base/cee/microcore_config.py\", line 2177, in _hosts_worker\n    hosts_data = _compute_worker_hosts_data(\n                 ^^^^^^^^^^^^^^^^^^^^^^^^^^^\n  File \"/omd/sites/wato/lib/python3/cmk/base/cee/microcore_config.py\", line 2065, in _compute_worker_hosts_data\n    helper_config_manager.get_host_data(\n  File \"/omd/sites/wato/lib/python3/cmk/base/cee/microcore_config.py\", line 3050, in get_host_data\n    host_class(config_cache, hostname, hosts_config, passwords, ip_address_of),\n    ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n  File \"/omd/sites/wato/lib/python3/cmk/base/cee/microcore_config.py\", line 1320, in __init__\n    host_attrs=config_cache.get_host_attributes(\n               ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n  File \"/omd/sites/wato/lib/python3/cmk/base/config.py\", line 3521, in get_host_attributes\n    attrs = self.extra_host_attributes(hostname)\n            ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n  File \"/omd/sites/wato/lib/python3/cmk/base/config.py\", line 2353, in extra_host_attributes\n    values = self.ruleset_matcher.get_host_values(host_name, ruleset)\n             ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n  File \"/omd/sites/wato/lib/python3/cmk/utils/rulesets/ruleset_matcher.py\", line 254, in get_host_values\n    self.ruleset_optimizer.get_host_ruleset(ruleset, with_foreign_hosts)\n  File \"/omd/sites/wato/lib/python3/cmk/utils/rulesets/ruleset_matcher.py\", line 581, in get_host_ruleset\n    return self.__host_ruleset_cache.setdefault(cache_id, _impl(ruleset, with_foreign_hosts))\n                                                          ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n  File \"/omd/sites/wato/lib/python3/cmk/utils/rulesets/ruleset_matcher.py\", line 572, in _impl\n    for hostname in self._all_matching_hosts(rule[\"condition\"], with_foreign_hosts):\n                                             ~~~~^^^^^^^^^^^^^\nTypeError: tuple indices must be integers or slices, not str\n\nTraceback (most recent call last):\n  File \"/omd/sites/wato/lib/python3/cmk/base/cee/microcore_config.py\", line 2177, in _hosts_worker\n    hosts_data = _compute_worker_hosts_data(\n                 ^^^^^^^^^^^^^^^^^^^^^^^^^^^\n  File \"/omd/sites/wato/lib/python3/cmk/base/cee/microcore_config.py\", line 2065, in _compute_worker_hosts_data\n    helper_config_manager.get_host_data(\n  File \"/omd/sites/wato/lib/python3/cmk/base/cee/microcore_config.py\", line 3050, in get_host_data\n    host_class(config_cache, hostname, hosts_config, passwords, ip_address_of),\n    ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n  File \"/omd/sites/wato/lib/python3/cmk/base/cee/microcore_config.py\", line 1320, in __init__\n    host_attrs=config_cache.get_host_attributes(\n               ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n  File \"/omd/sites/wato/lib/python3/cmk/base/config.py\", line 3521, in get_host_attributes\n    attrs = self.extra_host_attributes(hostname)\n            ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n  File \"/omd/sites/wato/lib/python3/cmk/base/config.py\", line 2353, in extra_host_attributes\n    values = self.ruleset_matcher.get_host_values(host_name, ruleset)\n             ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n  File \"/omd/sites/wato/lib/python3/cmk/utils/rulesets/ruleset_matcher.py\", line 254, in get_host_values\n    self.ruleset_optimizer.get_host_ruleset(ruleset, with_foreign_hosts)\n  File \"/omd/sites/wato/lib/python3/cmk/utils/rulesets/ruleset_matcher.py\", line 581, in get_host_ruleset\n    return self.__host_ruleset_cache.setdefault(cache_id, _impl(ruleset, with_foreign_hosts))\n                                                          ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n  File \"/omd/sites/wato/lib/python3/cmk/utils/rulesets/ruleset_matcher.py\", line 572, in _impl\n    for hostname in self._all_matching_hosts(rule[\"condition\"], with_foreign_hosts):\n                                             ~~~~^^^^^^^^^^^^^\nTypeError: tuple indices must be integers or slices, not str\n\nTraceback (most recent call last):\n  File \"/omd/sites/wato/lib/python3/cmk/base/cee/microcore_config.py\", line 2177, in _hosts_worker\n    hosts_data = _compute_worker_hosts_data(\n                 ^^^^^^^^^^^^^^^^^^^^^^^^^^^\n  File \"/omd/sites/wato/lib/python3/cmk/base/cee/microcore_config.py\", line 2065, in _compute_worker_hosts_data\n    helper_config_manager.get_host_data(\n  File \"/omd/sites/wato/lib/python3/cmk/base/cee/microcore_config.py\", line 3050, in get_host_data\n    host_class(config_cache, hostname, hosts_config, passwords, ip_address_of),\n    ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n  File \"/omd/sites/wato/lib/python3/cmk/base/cee/microcore_config.py\", line 1320, in __init__\n    host_attrs=config_cache.get_host_attributes(\n               ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n  File \"/omd/sites/wato/lib/python3/cmk/base/config.py\", line 3521, in get_host_attributes\n    attrs = self.extra_host_attributes(hostname)\n            ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n  File \"/omd/sites/wato/lib/python3/cmk/base/config.py\", line 2353, in extra_host_attributes\n    values = self.ruleset_matcher.get_host_values(host_name, ruleset)\n             ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n  File \"/omd/sites/wato/lib/python3/cmk/utils/rulesets/ruleset_matcher.py\", line 254, in get_host_values\n    self.ruleset_optimizer.get_host_ruleset(ruleset, with_foreign_hosts)\n  File \"/omd/sites/wato/lib/python3/cmk/utils/rulesets/ruleset_matcher.py\", line 581, in get_host_ruleset\n    return self.__host_ruleset_cache.setdefault(cache_id, _impl(ruleset, with_foreign_hosts))\n                                                          ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n  File \"/omd/sites/wato/lib/python3/cmk/utils/rulesets/ruleset_matcher.py\", line 572, in _impl\n    for hostname in self._all_matching_hosts(rule[\"condition\"], with_foreign_hosts):\n                                             ~~~~^^^^^^^^^^^^^\nTypeError: tuple indices must be integers or slices, not str\n\nTraceback (most recent call last):\n  File \"/omd/sites/wato/lib/python3/cmk/base/cee/microcore_config.py\", line 2177, in _hosts_worker\n    hosts_data = _compute_worker_hosts_data(\n                 ^^^^^^^^^^^^^^^^^^^^^^^^^^^\n  File \"/omd/sites/wato/lib/python3/cmk/base/cee/microcore_config.py\", line 2065, in _compute_worker_hosts_data\n    helper_config_manager.get_host_data(\n  File \"/omd/sites/wato/lib/python3/cmk/base/cee/microcore_config.py\", line 3050, in get_host_data\n    host_class(config_cache, hostname, hosts_config, passwords, ip_address_of),\n    ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n  File \"/omd/sites/wato/lib/python3/cmk/base/cee/microcore_config.py\", line 1320, in __init__\n    host_attrs=config_cache.get_host_attributes(\n               ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n  File \"/omd/sites/wato/lib/python3/cmk/base/config.py\", line 3521, in get_host_attributes\n    attrs = self.extra_host_attributes(hostname)\n            ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n  File \"/omd/sites/wato/lib/python3/cmk/base/config.py\", line 2353, in extra_host_attributes\n    values = self.ruleset_matcher.get_host_values(host_name, ruleset)\n             ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n  File \"/omd/sites/wato/lib/python3/cmk/utils/rulesets/ruleset_matcher.py\", line 254, in get_host_values\n    self.ruleset_optimizer.get_host_ruleset(ruleset, with_foreign_hosts)\n  File \"/omd/sites/wato/lib/python3/cmk/utils/rulesets/ruleset_matcher.py\", line 581, in get_host_ruleset\n    return self.__host_ruleset_cache.setdefault(cache_id, _impl(ruleset, with_foreign_hosts))\n                                                          ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n  File \"/omd/sites/wato/lib/python3/cmk/utils/rulesets/ruleset_matcher.py\", line 572, in _impl\n    for hostname in self._all_matching_hosts(rule[\"condition\"], with_foreign_hosts):\n                                             ~~~~^^^^^^^^^^^^^\nTypeError: tuple indices must be integers or slices, not str\n\nTraceback (most recent call last):\n  File \"/omd/sites/wato/lib/python3/cmk/base/cee/microcore_config.py\", line 2177, in _hosts_worker\n    hosts_data = _compute_worker_hosts_data(\n                 ^^^^^^^^^^^^^^^^^^^^^^^^^^^\n  File \"/omd/sites/wato/lib/python3/cmk/base/cee/microcore_config.py\", line 2065, in _compute_worker_hosts_data\n    helper_config_manager.get_host_data(\n  File \"/omd/sites/wato/lib/python3/cmk/base/cee/microcore_config.py\", line 3050, in get_host_data\n    host_class(config_cache, hostname, hosts_config, passwords, ip_address_of),\n    ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n  File \"/omd/sites/wato/lib/python3/cmk/base/cee/microcore_config.py\", line 1320, in __init__\n    host_attrs=config_cache.get_host_attributes(\n               ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n  File \"/omd/sites/wato/lib/python3/cmk/base/config.py\", line 3521, in get_host_attributes\n    attrs = self.extra_host_attributes(hostname)\n            ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n  File \"/omd/sites/wato/lib/python3/cmk/base/config.py\", line 2353, in extra_host_attributes\n    values = self.ruleset_matcher.get_host_values(host_name, ruleset)\n             ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n  File \"/omd/sites/wato/lib/python3/cmk/utils/rulesets/ruleset_matcher.py\", line 254, in get_host_values\n    self.ruleset_optimizer.get_host_ruleset(ruleset, with_foreign_hosts)\n  File \"/omd/sites/wato/lib/python3/cmk/utils/rulesets/ruleset_matcher.py\", line 581, in get_host_ruleset\n    return self.__host_ruleset_cache.setdefault(cache_id, _impl(ruleset, with_foreign_hosts))\n                                                          ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n  File \"/omd/sites/wato/lib/python3/cmk/utils/rulesets/ruleset_matcher.py\", line 572, in _impl\n    for hostname in self._all_matching_hosts(rule[\"condition\"], with_foreign_hosts):\n                                             ~~~~^^^^^^^^^^^^^\nTypeError: tuple indices must be integers or slices, not str\n\nTraceback (most recent call last):\n  File \"/omd/sites/wato/lib/python3/cmk/base/cee/microcore_config.py\", line 2177, in _hosts_worker\n    hosts_data = _compute_worker_hosts_data(\n                 ^^^^^^^^^^^^^^^^^^^^^^^^^^^\n  File \"/omd/sites/wato/lib/python3/cmk/base/cee/microcore_config.py\", line 2065, in _compute_worker_hosts_data\n    helper_config_manager.get_host_data(\n  File \"/omd/sites/wato/lib/python3/cmk/base/cee/microcore_config.py\", line 3050, in get_host_data\n    host_class(config_cache, hostname, hosts_config, passwords, ip_address_of),\n    ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n  File \"/omd/sites/wato/lib/python3/cmk/base/cee/microcore_config.py\", line 1320, in __init__\n    host_attrs=config_cache.get_host_attributes(\n               ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n  File \"/omd/sites/wato/lib/python3/cmk/base/config.py\", line 3521, in get_host_attributes\n    attrs = self.extra_host_attributes(hostname)\n            ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n  File \"/omd/sites/wato/lib/python3/cmk/base/config.py\", line 2353, in extra_host_attributes\n    values = self.ruleset_matcher.get_host_values(host_name, ruleset)\n             ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n  File \"/omd/sites/wato/lib/python3/cmk/utils/rulesets/ruleset_matcher.py\", line 254, in get_host_values\n    self.ruleset_optimizer.get_host_ruleset(ruleset, with_foreign_hosts)\n  File \"/omd/sites/wato/lib/python3/cmk/utils/rulesets/ruleset_matcher.py\", line 581, in get_host_ruleset\n    return self.__host_ruleset_cache.setdefault(cache_id, _impl(ruleset, with_foreign_hosts))\n                                                          ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n  File \"/omd/sites/wato/lib/python3/cmk/utils/rulesets/ruleset_matcher.py\", line 572, in _impl\n    for hostname in self._all_matching_hosts(rule[\"condition\"], with_foreign_hosts):\n                                             ~~~~^^^^^^^^^^^^^\nTypeError: tuple indices must be integers or slices, not str\n",
    "id": "433666fc-7907-11f1-bb85-005056bd0e74",
    "local_vars": "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",
    "os": "Red Hat Enterprise Linux release 9.7 (Plow)",
    "python_paths": [
        "/opt/omd/versions/2.4.0p32.cee/bin",
        "/omd/sites/wato/local/lib/python3",
        "/omd/sites/wato/lib/python3/cloud",
        "/omd/sites/wato/lib/python312.zip",
        "/omd/sites/wato/lib/python3.12",
        "/omd/sites/wato/lib/python3.12/lib-dynload",
        "/omd/sites/wato/lib/python3.12/site-packages",
        "/omd/sites/wato/lib/python3"
    "python_version": "3.12.11 (main, Jun  6 2026, 01:53:33) [GCC 14.2.0]",
    "time": 1783320752.451597,
    "version": "2.4.0p32"
I’m thankfull for any help.
Thanks and best regards
Andre
we found the cause of the issue.
some genius had the terrific idea to create a “custom_host_check.mk” file in /opt/omd/sites/wato/etc/check_mk/conf.d/
After deleting that file we were able to activate changes again.
In the rare case someone has a problem like this in the future, here is what we did to debug it:
  1. copied a backup of the site to a Checkmk test server
  2. changed the file /opt/omd/versions/2.4.0p32.cee/lib/python3/cmk/utils/rulesets/ruleset_matcher.py(this is the file that reported the error when activating changes)
    And added some debug lines to return the content of the rule that produces the problem near the line that was reported in the error when we tried to activate changes (line 572 in our case)
  3. ran the command to restore the backup
  4. waited for the command to run into the same error we got when activating changes
  5. checked the added debug output for the rule contents
  6. on the live system we searched the files for the rule we found in step 2: grep -rnw '/opt/omd/sites/wato/' -e 'some content of the rule found in step 2'
  7. after checking the found file did not belong there, delete it
