CMK version: image: checkmk/check-mk-free:2.0.0p33 OS version:
Error message: no unmonitored services found, no vanished services found, no new host labels, [agent] Communication failed: [Errno 111] Connection refusedCRIT
I am following this document . Video seems to be simple and easy. The documentation as well . i followed step by step process in the document. But i am facing issues. Monitoring Kubernetes
i have kubernetes cluster on one server.
i do have checkmk installed using docker-compose file on other server
I followed all the steps but nothing is monitored kubernetes side
looking for a working session
i followed your document. but there is no luck. nothing is getting monitored or there is no relation at all.
i put my kubernetes cluster ip but its getting new error in the UI
“Failed to tech state [504] gateway time-out retrying in 1 second . in case this error persist for more tahn some seconds ,please verify that all processess on the site are running”
I checked on checkmk its up and running. I donot think so your document is very easy. but implementing on my system why it is so hurdle? need some live support
the current one is a free trail and i already have enterprize version. i can buy i dont mind . but why i am unable to monitor a single kubernetis instance
I am able to login . but i cannot able to monitor all the services what he explained in the video or document. also i cannot see your free time. I am free from 10 am cst to till 2 pm CST. kindly send me the link
