Unhandled exception: 400: Site connection not initiated ([Errno 104] Connection reset by peer)
CMK version: 2.5.0p13
OS version: Debian Trixie
Error message: Unhandled exception: 400: Site connection not initiated ([Errno 104] Connection reset by peer).
all connections are lost in distributed monitoring after updating checkmk-pro from 2.5.0p11 to 2.5.0p13. Port 6557 is open on all sites, sites components are running. in liveproxyd.log
Could not send heartbeat for 10 secs - no free channel
although Maximum concurrent Livestatus connections ist set to 100, an increase didn’t help neither, telnet from master to remote doesn’t work neither.
~$ ss -tan state established '( sport = :6557 )' | wc -l
1
~$ telnet slave01 6557
Trying 192.168.1.12...
Connected to slave01.
Escape character is '^]'.
Connection closed by foreign host.
~$ netstat -tulpn | grep 6557
(Not all processes could be identified, non-owned process info
 will not be shown, you would have to be root to see it all.)
tcp6       0      0 :::6557                 :::*                    LISTEN      34433/xinetd
master is still logged in to all remote sites bit is connected. The community update went without any issues.
web.log has many such entries
2026-09-14 06:59:15,408 [40] [cmk.web 42824] Failed to fetch peer certificate
  File "/omd/sites/$master/lib/python3/cmk/gui/wato/pages/sites.py", line 1954, in page
    cert_details = list(self._fetch_certificate_details())
  File "/omd/sites/$master/lib/python3/cmk/utils/encryption.py", line 71, in fetch_certificate_details
    verify_chain_results = _fetch_certificate_chain_verify_results(
        trusted_ca_file, address_family, address
  File "/omd/sites/$master/lib/python3/cmk/utils/encryption.py", line 109, in _fetch_certificate_chain_verify_results
    sock.do_handshake()
  File "/omd/sites/$master/lib/python3.13/site-packages/OpenSSL/SSL.py", line 2487, in do_handshake
    self._raise_ssl_error(self._ssl, result)
  File "/omd/sites/$master/lib/python3.13/site-packages/OpenSSL/SSL.py", line 2074, in _raise_ssl_error
    raise SysCallError(errno, errorcode.get(errno))
OpenSSL.SSL.SysCallError: (104, 'ECONNRESET')
and now I got this error:
Got invalid data:
Internal automation error: too many values to unpack (expected 2)
  File "/omd/sites/remote01/lib/python3/cmk/gui/wato/pages/automation.py", line 302, in _execute_automation_command
    response.set_data(repr(automation.execute(automation.get_request(config, request))))
  File "/omd/sites/remote01/lib/python3/cmk/gui/watolib/automation_commands.py", line 83, in execute
    "omd_status": self._get_omd_status(),
  File "/omd/sites/remote01/lib/python3/cmk/gui/watolib/automation_commands.py", line 76, in _get_omd_status
    return self._parse_omd_status(result.stdout)
  File "/omd/sites/remote01/lib/python3/cmk/gui/watolib/automation_commands.py", line 61, in _parse_omd_status
    status = {key: int(val) for key, val in (el.split(" ") for el in raw_status.splitlines())}
ValueError: too many values to unpack (expected 2)
Any ideas what went wrong here?
What do you see if you test with openssl from your central site to one of the remote instances?
openssl s_client -connect slave01:6557
With your telnet test, this should not work if TLS is enabled on the remote sites.
If there was no TLS enabled on the remote site then you can check your distributed monitoring configuration for these sites and look if TLS is also disabled there.
Hi Andres, you are right, TLS is enabled, so telnet doesn’t work, with openssl s_client -connect I get this:
Connecting to 192.168.1.12
CONNECTED(00000003)
write:errno=104
no peer certificate available
No client certificate CA names sent
Negotiated TLS1.3 group: <NULL>
SSL handshake has read 0 bytes and written 1555 bytes
Verification: OK
New, (NONE), Cipher is (NONE)
Protocol: TLSv1.3
This TLS version forbids renegotiation.
Compression: NONE
Expansion: NONE
No ALPN negotiated
Early data was not sent
It looks like TLS is not active at the remote site currently.
well, it is enabled all the time, everything worked until 2.5.0p11, the issue arised after the update to 2.5.0p13, this is the config from one remote:
~$ omd config show
ADMIN_MAIL:
AGENT_RECEIVER: on
AGENT_RECEIVER_PORT: 8000
APACHE_MODE: own
APACHE_TCP_ADDR: 127.0.0.1
APACHE_TCP_PORT: 5000
AUTOMATION_HELPER: on
AUTOSTART: on
CORE: cmc
LIVEPROXYD: on
LIVESTATUS_TCP: on
LIVESTATUS_TCP_ONLY_FROM: 192.168.1.10
LIVESTATUS_TCP_PORT: 6557
LIVESTATUS_TCP_TLS: on
MCP_SERVER: off
MCP_TRACE_FORWARD: off
MKEVENTD: on
MKEVENTD_SNMPTRAP: off
MKEVENTD_SYSLOG: off
MKEVENTD_SYSLOG_TCP: off
MULTISITE_AUTHORISATION: on
MULTISITE_COOKIE_AUTH: on
PIGGYBACK_HUB: off
RABBITMQ_DIST_PORT: 25672
RABBITMQ_MANAGEMENT_PORT: 15671
RABBITMQ_ONLY_FROM: ::
RABBITMQ_PORT: 5672
TMPFS: on
TRACE_RECEIVE: off
TRACE_SEND: off
Can you have a look on the remote site inside the ~/tmp/run folder?
srw-rw---- 1 SITENAME SITENAME    0 Sep 11 15:00 live=
lrwxrwxrwx 1 SITENAME SITENAME    8 Sep 14 10:07 live-tcp -> live-tls=
srwx------ 1 SITENAME SITENAME    0 Sep 14 10:07 live-tls=
Also on this host itself the openssl test against localhost should also result in an error or?
ls -al tmp/run show the socket is there
srw-rw---- 1 slave01 slave01   0 Sep 14 07:06 live=
lrwxrwxrwx 1 slave01 slave01   8 Sep 14 07:06 live-tcp -> live-tls=
srwx------ 1 slave01 slave01   0 Sep 14 07:06 live-tls=
~$ openssl s_client -connect localhost:6557
Connecting to 127.0.0.1
CONNECTED(00000003)
write:errno=104
SSL handshake has read 0 bytes and written 1524 bytes
Verification: OK
Protocol: TLSv1.3
Compression: NONE
Expansion: NONE
No ALPN negotiated
Verify return code: 0 (ok)
live-tcp points correctly to live-tls and not to live.
Strange. You can check if you stunnel is running correctly.
I found the issue. My bad, the IP of the master has changed, and I forgot to modify the IP in LIVESTATUS_TCP_ONLY_FROM, I fixed it now but still same issues, because probably it should be changed in many files, so I downgraded to 2.5.0p11 and it worked fine, then removed 2.5.0p13 and made a clean upgrade again. Issue disappeared.
Thanks Andreas
Some how this issue produced a further problem, I have now this error in the connfiguration connection in Distributed monitoring for all the sites:
Got invalid data:
Distrubted monitoring works, all hosts and services, notifications etc.. only this error as far as I can tell, the omd status command looks normal:
~$  omd status -V --bare
agent-receiver:     running
mkeventd:           running
liveproxyd:         running
mknotifyd:          running
rrdcached:          running
redis:              running
automation-helper:  running
ui-job-scheduler:   running
cmc:                running
apache:             running
dcd:                running
stunnel:            running
xinetd:             running
crontab:            running
Overall state:      running
I assume this is some kind of side effect of the wrong master site IP that wasn’t resolved afterwords. Any idea how is this related or how to fix it ?
what I found:
~$ omd -v status --bare | while read line; do echo "$line" | awk '{print NF ":" $0}'; done
5:Calling hook: /omd/versions/2.5.0p13.pro/lib/omd/hooks/MCP_SERVER default pro
5:Calling hook: /omd/versions/2.5.0p13.pro/lib/omd/hooks/MCP_TRACE_FORWARD default pro
2:jaeger 5
2:agent-receiver 0
2:mkeventd 0
2:liveproxyd 0
2:mknotifyd 0
2:rrdcached 0
2:redis 0
2:npcd 5
2:pnp_gearman_worker 5
2:automation-helper 0
2:ui-job-scheduler 0
2:cmc 0
2:nagios 5
2:apache 0
2:dcd 0
2:mcp-server 5
2:rabbitmq 5
2:stunnel 0
2:piggyback-hub 5
2:xinetd 0
2:crontab 0
2:OVERALL 0
Each of those lines has 5 space-separated tokens, not 2. The parser crashes on the first line that doesn’t fit the name number pattern, I fixed it on one remote site from:
def _parse_omd_status(self, raw_status: str) -> OMDStatus:
    return status
to:
    status = {}
    for line in raw_status.splitlines():
        parts = line.split()
        if len(parts) != 2:
            continue
        if parts[1].isdigit():
            status[parts[0]] = int(parts[1])
    return status
and I get the expected line in Distributed monitoring:
Online (Version: 2.5.0p13, Edition: Pro, License state: licensed)
I am not sure if these lines should be in the output of omd -v status --bare
I also realized that these two hooks don’t exist in 2.5.0p11, which is the last version I was running and have no idea how they got here, maybe a side effect of the wrong IP?
for now I reverted the change and moved the two hooks to a backup directory on all remote sites, seems to be working. Hopefully this won’t have any side effects, since both commands return off:
~$ /omd/versions/2.5.0p13.pro/lib/omd/hooks/MCP_SERVER default pro
off
~$ /omd/versions/2.5.0p13.pro/lib/omd/hooks/MCP_TRACE_FORWARD default pro
off
