For example, you can find a folder with the RestAPI, but only under the unique ID. So if you have changed the name of the folder, the unique ID is of course still the same, but you cannot see it directly. The error here is that folders cannot be found with the RestAPI unless you have the unique ID. To simplify everything and have a better overview, I would like to be able to change the unique ID or have the RestAPI work with the “Title” instead of the unique ID. Does anyone have a solution or alternative?
I have a problem with the renaming of the unique ID. If I change the unique ID of a folder and click on save, it changes automatically back to the previous unique ID. Can you tell me something about that?
