There seems to be a wide-spread problem with donated plugins which don’t actually work any more under Check_MK v2.0.0. See, for example, Monitoring Folder Size - #3 by Pixelpoint
Is there somewhere a document that outlines the integration with the agent bakery with updates suitable for the new python 3 code? Or even a suggestion for a plugin which works and could be used as a model to copy code from?
In my case I’m trying to use the YUM Update Check, version 2.1.0, which is supposed to work with Check_MK 2.0.0 or higher, and running into issues with shutil not being present, strings and POSIX names not being concatable, etc.
Out of curiosity, is there some particular reason these aren’t uploaded to the Check_MK exchange? I have no objection to GitHub, but find that it’s a sprawling mess unless I already know something specific to search on. That said, I suppose I’ll try searching on a number of variations on “Check_MK” and see what else might be out there.
Though I must say that I’m REALLY not getting the logic of the conditional in the plugin itself that controls when yum is used to update the cached data
The first clause is pretty much always guaranteed to be true given what is almost certainly a spurious ) and if it were just that I’d submit a pull request. But unless I’m missing the mark, the second clause is only true when the plugin is run within 120 seconds of the server being rebooted. I think. Unless I’m really missing something here.
However in my testing, there does seem to be an update only after reboot or if I manually delete $CACHE_RESULT_CHECK.
