Upgrade 1.5.XX to 1.6XX
Hi guys:
I need upgrade my check_mk raw 1.5 to 1.6 but when i have my sute updated y cannot acces at check_mk GUI byy error 403 forbidden. I read that mod_proxy is deprecated and now is mod_wgsi but I don’t found any issue in the conf
, can you hepl me ? any idea?
thanks in advance
A little bit more information about your site would be nice.
What was the upgrade message (log file). Was there any error or something?
Operation system used would also be a good information.
Your system Apache needs a mod_proxy that has nothing to do with mod_wsgi, this is needed for the Python code.
did you restart the core apache on you system to reload the config? As Andreas mentioned, more information will be helpful.
Cheers,
Christian
Hi Andres :slight_smile:thanks for your help, we had can resolv the issue. The root cause was a old check_mk.conf . we had removed the file ,linked the new file and site is accesible now . We found the root cause because we had create other new site in 1.5 for test and we can update without errors so it this tell us that the problem was in a file of our configuration.
