Hi, I’m trying to do an upgrade from 2.3.0p12.cce to 2.3.0p23.cre
And i’m getting this error. How do I fix it??
CMK version:
2.3.0p23.cre
OS version:
RHEL 8
NameError: name ‘agent_signature_keys’ is not defined
-| Verifying Checkmk configuration...
-| Traceback (most recent call last):
-| File "/omd/sites/dc1/lib/python3/cmk/gui/config.py", line 145, in _load_config_file_to
-| exec(compile(f.read(), path, "exec"), {}, raw_config) # nosec B102 # BNS:aee528
-| File "/omd/sites/dc1/etc/check_mk/multisite.d/wato/agent_signature_keys.mk", line 3, in <module>
-| agent_signature_keys.update({1: {'alias': 'key for dns agents',
-| NameError: name 'agent_signature_keys' is not defined
-| During handling of the above exception, another exception occurred:
-| File "/omd/sites/dc1/lib/python3/cmk/update_config/main.py", line 101, in main_check_config
-| check_config(logger, conflict)
-| File "/omd/sites/dc1/lib/python3/cmk/update_config/main.py", line 238, in check_config
-| with disable_redis(), gui_context():
-| File "/omd/sites/dc1/lib/python3.12/contextlib.py", line 137, in __enter__
-| return next(self.gen)
-| File "/omd/sites/dc1/lib/python3/cmk/gui/utils/script_helpers.py", line 67, in gui_context
-| with app.app_context(), make_request_context(app, environ):
-| File "/omd/sites/dc1/lib/python3.12/site-packages/flask/ctx.py", line 434, in __enter__
-| self.push()
-| File "/omd/sites/dc1/lib/python3.12/site-packages/flask/ctx.py", line 386, in push
-| self.session = session_interface.open_session(self.app, self.request)
-| File "/omd/sites/dc1/lib/python3/cmk/gui/session.py", line 341, in open_session
-| config.initialize()
-| File "/omd/sites/dc1/lib/python3/cmk/gui/config.py", line 132, in initialize
-| load_config()
-| File "/omd/sites/dc1/lib/python3/cmk/gui/config.py", line 185, in load_config
-| _load_config_file_to(p, raw_config)
-| File "/omd/sites/dc1/lib/python3/cmk/gui/config.py", line 149, in _load_config_file_to
-| raise MKConfigError(_("Cannot read configuration file %s: %s:") % (path, e))
-| cmk.gui.exceptions.MKConfigError: Cannot read configuration file /omd/sites/dc1/etc/check_mk/multisite.d/wato/agent_signature_keys.mk: name 'agent_signature_keys' is not defined:
-| Update aborted with Error: Cannot read configuration file /omd/sites/dc1/etc/check_mk/multisite.d/wato/agent_signature_keys.mk: name 'agent_signature_keys' is not defined:.
-| Your site has not been modified.''
**Output of “cmk --debug -vvn hostname”:** (If it is a problem with checks or plugins)
```OMD[dc1]:~$ cmk --debug -vvn prd-asmon1.bld.aipo.gov.au
value store: synchronizing
Trying to acquire lock on /omd/sites/dc1/tmp/check_mk/counters/prd-asmon1.bld.aipo.gov.au
Got lock on /omd/sites/dc1/tmp/check_mk/counters/prd-asmon1.bld.aipo.gov.au
Releasing lock on /omd/sites/dc1/tmp/check_mk/counters/prd-asmon1.bld.aipo.gov.au
Released lock on /omd/sites/dc1/tmp/check_mk/counters/prd-asmon1.bld.aipo.gov.au
Checkmk version 2.3.0p12
Updating IPv4 DNS cache for prd-asmon1.bld.aipo.gov.au: 172.19.11.76
Trying to acquire lock on /omd/sites/dc1/var/check_mk/ipaddresses.cache
Got lock on /omd/sites/dc1/var/check_mk/ipaddresses.cache
Releasing lock on /omd/sites/dc1/var/check_mk/ipaddresses.cache
Released lock on /omd/sites/dc1/var/check_mk/ipaddresses.cache
+ FETCHING DATA
Source: SourceInfo(hostname='prd-asmon1.bld.aipo.gov.au', ipaddress='172.19.11.76', ident='piggyback', fetcher_type=<FetcherType.PIGGYBACK: 4>, source_type=<SourceType.HOST: 1>)
[cpu_tracking] Start [7fe4fa03ef60]
Read from cache: NoCache(prd-asmon1.bld.aipo.gov.au, path_template=/dev/null, max_age=MaxAge(checking=0.0, discovery=0.0, inventory=0.0), simulation=False, use_only_cache=False, file_cache_mode=1)
No piggyback files for 'prd-asmon1.bld.aipo.gov.au'. Skip processing.
No piggyback files for '172.19.11.76'. Skip processing.
Get piggybacked data
[cpu_tracking] Stop [7fe4fa03ef60 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.0))]
[cpu_tracking] Start [7fe4fa31fb30]
+ PARSE FETCHER RESULTS
HostKey(hostname='prd-asmon1.bld.aipo.gov.au', source_type=<SourceType.HOST: 1>) -> Add sections: []
Received no piggyback data
[cpu_tracking] Stop [7fe4fa31fb30 - Snapshot(process=posix.times_result(user=0.020000000000000018, system=0.009999999999999981, children_user=0.0, children_system=0.0, elapsed=0.02000000048428774))]
[piggyback] Success (but no data found for this host), execution time 0.0 sec | execution_time=0.020 user_time=0.020 system_time=0.010 children_user_time=0.000 children_system_time=0.000 cmk_time_agent=0.000
