Uptime beyond 250 days?
Checkmk Raw Edition 2.1.0p28
Ubuntu 18.04 LTS
As you can see in below graph, the uptime doesn’t count further than 250 days (Service performance data (source code) uptime=21474836;;;;
Does anyone else have that issue or might this be a bug?
The grahp still points to the correct point in time when the server was booted, but when you check the summary: “Up since May 02 2023 02:21:49, Uptime: 248 days 13 hours”, the calculation is wrong and it should be about 300 days now.
This might be counter overflow for a 32-bit counter of the SNMP stack.
Did you double-check the raw SNMP data?
Yeah, it’s the IBM servers’ fault :s
Thanks for the idea, marking it ‘cannot be solved’
Did you try to check mith SNMP V2/V3 to get 64bit counters?
It’s already on v2
