Hello everbody,
is it possible for a host e.g. add a URL that links to an internal wiki?
Hello everbody,
Yes it is possible
Go to -> Rule-Based Configuration of Host & Service Parameters -> Custom icons or actions for hosts in status GUI
There you can define an icon and url for hosts.
hey
Thank you for your answer. an icon appears on the host, but i can’t click it. In the rule the URL starts with https://…
Strange.
How does the definition of your Icon/Action looks like.
For the defined URL you can select how it is opened. Don’t select “current content area” if you use HTTPS.
https://checkmk.de/cms_views.html#%20Eigene%20Icons%20und%20Aktionen%20einfĂĽgen
i followed this guide from point 8 …
the url looks this https://wiki.domainname.de
Ok and how does your definition looks like?
Sorry… what do you mean with definiton ?
Then i don’t see why it should not work.
In my systems this is working without any problem.
It will only have a problem if you try to open in the same frameset as your monitoring site.
Looks like the wrong ruleset
(German “Symbolbild für Hosts in Status GUI”, English “Icon image for hosts in status GUI”). That’s really just for displaying an icon, no linked action.
You need “Custom icons or actions for hosts in status GUI”. Same WATO category, but different ruleset
Beginner Mistake
best thanks, you have helped me a lot
I’m too late
That was why i requested the rule definition. Was now only the defined action not assigned correctly to the host?
Hey Andreas,
i have choose the wrong ruleset. i took “Icon image for hosts in status GUI” and not “Custom icons or actions for hosts in status GUI”.
