Using Agent Updater via Satellite in DMZ
is it possible to use the Checkmk Agent Updater through a satellite site?
Our setup looks like this:
  • The satellite site is located in the DMZ
  • The main site is in the LAN
  • We have a dedicated firewall rule that allows the satellite to reach the main server via TCP 443
  • LAN hosts are already successfully using the Agent Updater
We would now also like to use the Agent Updater for hosts in the DMZ via the satellite site.
Would this setup be supported, and can the updater work in such a scenario?
Thanks in advance!
Yes. Automatic agent updates - Distribute agents and plug-ins automatically
