We are using CMK EE 2.3.0p25 and switched to the new MSSQL mk-sql.exe check.
When configuring the MSSQL Jobs rule in WATO, it does not allow mapping the “Schedule” state to different status.
If this is being detected and an alert is being raised, we should have a way to map to different states, since in SQL you can have jobs that are enabled without a schedule.
The only way to get around this now is to disable the job (and ignore that state), or ignore the job so that it is not being monitored.
