Using variables ($_HOSTTAGS$) in active checks
Hi there,
in the ruleset for “Classical active and passive Monitoring checks” for command line it says about the usage of variables:
grafik
What is the right syntax for such a rule when using (own) $_HOSTTAGS$? I guess I will have to use the “Tag ID”? Couldn’t find a valid example yet so I thought I give it a try here…
All custom attributes defined for the host are available as $_HOST[VARNAME]$. Replace “[VARNAME]” with the upper case name of your variable.
For example, a host attribute named foo with the value bar would result in the macro $_HOSTFOO$ being replaced with bar .
