**CMK version:2.1p48 bookwarm
**OS version:debain 12 bookwarm
before going to update 1.6.9 to 1.7.7 , python looks like
CMK appliance 1.7.7 not getting up after reboot only on master or center site
When using this “/usr/bin/env” trick, it assumes that /usr/bin/env does existing on the host, and that the proper “python3” executable (/usr/bin/python3) is the first found in the search path.
if “/usr/bin/env” is not present, or another “python3” is not found, or is the incorrect one, you will get this error.
