I was looking for a “fix” to monitor proxmox veeam backups, unfortunately this is not yet natively supported by veeam powershell mdule itself.
Came accross this in veeam forums and (very dirtly) edited the default veeambackupstatus plugin.
Maybe usefull to someone else.
Feature Request - Support for Proxmox VE with Veeam Powershell
I added this part.
→ hardcoded the Jobtype because it comes back as “VmbApiPolicyTempJob”
$myPVEBackupJobs = [Veeam.Backup.Core.CBackupJob]::GetAll() | Where-Object {$_.TypeToString -like "Proxmox Backup*"}
foreach ($myPVEJob in $myPVEBackupJobs)
$myPVEJobName = $myPVEJob.Name -replace "\'","_" -replace " ","_"
$myPVEJobType = "ProxmoxBackup"
$myPVEJobLastState = $myPVEJob.GetLastState()
$myPVEJobLastResult = $myPVEJob.GetLastResult()
$myPVEJobLastSession = $myPVEJob.FindLastSession()
$myPVEJobCreationTime = $myPVEJobLastSession.CreationTime | get-date -Format "dd.MM.yyyy HH\:mm\:ss" -ErrorAction SilentlyContinue
$myPVEJobEndTime = $myPVEJobLastSession.EndTime | get-date -Format "dd.MM.yyyy HH\:mm\:ss" -ErrorAction SilentlyContinue
$myPVEJobsText = "$myPVEJobsText" + "$myPVEJobName" + "`t" + "$myPVEJobType" + "`t" + "$myPVEJobLastState" + "`t" + "$myPVEJobLastResult" + "`t" + "$myPVEJobCreationTime" + "`t" + "$myPVEJobEndTime" + "`n"
and the output at the end obviously
write-host "$($myJobsText) $($myPVEJobsText)"
param ([switch] $Debug)
$CMK_VERSION = "2.1.0p20"
## VEEAM Backups
## This powershell script needs to be run with the 64bit powershell
## and thus from a 64bit check_mk agent
## If a 64 bit check_mk agent is available it just needs to be renamed with
## the extension .ps1
## If only a 32bit check_mk agent is available it needs to be relocated to a
## directory given in veeam_backup_status.bat and the .bat file needs to be
## started by the check_mk agent instead.
$pshost = get-host
$pswindow = $pshost.ui.rawui
$newsize = $pswindow.buffersize
$newsize.height = 300
$newsize.width = 150
$pswindow.buffersize = $newsize
# Get Information from veeam backup and replication in cmk-friendly format
# V0.9
# Load Veeam Backup and Replication Powershell Snapin
try {
Import-Module Veeam.Backup.PowerShell -ErrorAction Stop -DisableNameChecking
catch {
try {
Add-PSSnapin VeeamPSSnapIn -ErrorAction Stop
catch {
if ($Debug) {Write-Host "No Veeam powershell modules could be loaded"}
Exit 1
try
$tapeJobs = Get-VBRTapeJob
write-host "<<<veeam_tapejobs:sep(124)>>>"
write-host "JobName|JobID|LastResult|LastState"
foreach ($tapeJob in $tapeJobs)
$jobName = $tapeJob.Name
$jobID = $tapeJob.Id
$lastResult = $tapeJob.LastResult
$lastState = $tapeJob.LastState
write-host "$jobName|$jobID|$lastResult|$lastState"
try {
$cdpjobs = Get-VBRCDPPolicy | select-Object Name,NextRun,PolicyState
catch {
write-host "CDP jobs not supported"
$cdpjobs = $false
if ( $cdpjobs ) {
$myCdpJobsText = "<<<veeam_cdp_jobs:sep(124)>>>`n"
foreach ($mycdpjobs in $cdpjobs)
$MyCdpJobsName = $mycdpjobs.Name -replace "\'","_" -replace " ","_"
$MyCdpJobsNextRun = $mycdpjobs.NextRun
if ($MyCdpJobsNextRun -ne $null) { $MyCdpJobsNextRun = get-date -date $MyCdpJobsNextRun -Uformat %s }
else { $MyCdpJobsNextRun = "null" }
$MyCdpJobsPolicyState = $mycdpjobs.PolicyState
$myCdpJobsText = "$myCdpJobsText" + "$MyCdpJobsName" + "|" + "$MyCdpJobsNextRun" + "|" + "$MyCdpJobsPolicyState" + "`n"
write-host $myCdpJobsText
$myJobsText = "<<<veeam_jobs:sep(9)>>>`n"
$myTaskText = ""
$myBackupJobs = Get-VBRJob -WarningAction SilentlyContinue | where {$_.IsScheduleEnabled -eq $true }
foreach ($myJob in $myBackupJobs)
$myJobName = $myJob.Name -replace "\'","_" -replace " ","_"
$myJobType = $myjob.JobType
$myJobLastState = $myJob.GetLastState()
$myJobLastResult = $myJob.GetLastResult()
$myJobLastSession = $myJob.FindLastSession()
$myJobCreationTime = $myJobLastSession.CreationTime | get-date -Format "dd.MM.yyyy HH\:mm\:ss" -ErrorAction SilentlyContinue
$myJobEndTime = $myJobLastSession.EndTime | get-date -Format "dd.MM.yyyy HH\:mm\:ss" -ErrorAction SilentlyContinue
$myJobsText = "$myJobsText" + "$myJobName" + "`t" + "$myJobType" + "`t" + "$myJobLastState" + "`t" + "$myJobLastResult" + "`t" + "$myJobCreationTime" + "`t" + "$myJobEndTime" + "`n"
# For Non Backup Jobs (Replicas) we bail out
# because we are interested in the status of the original backup but
# for replicas the overall job state is all we need.
if ($myJob.IsBackup -eq $false) { continue }
# Each backup job has a number of tasks which were executed (VMs which were processed)
# Get all Tasks of the L A S T backup session
# Caution: Each backup job MAY have run SEVERAL times for retries,
# thats why we need all sessions related to the last one if its a retry
$sessions = @($myJobLastSession)
if ($myJobLastSession.IsRetryMode)
$sessions = $myJobLastSession.GetOriginalAndRetrySessions($TRUE)
$myJobLastSessionTasks = $sessions | Get-VBRTaskSession -ErrorAction SilentlyContinue
foreach ($myTask in $myJobLastSessionTasks)
$myTaskName = $myTask.Name -replace "[^ -x7e]" -replace " ","_"
$myTaskText = "$myTaskText" + "<<<<" + "$myTaskName" + ">>>>" + "`n"
$myTaskText = "$myTaskText" + "<<<"+ "veeam_client:sep(9)" +">>>" +"`n"
$myTaskStatus = $myTask.Status
$myTaskText = "$myTaskText" + "Status" + "`t" + "$myTaskStatus" + "`n"
$myTaskText = "$myTaskText" + "JobName" + "`t" + "$myJobName" + "`n"
$myTaskTotalSize = $myTask.Progress.TotalSize
$myTaskText = "$myTaskText" + "TotalSizeByte" + "`t" + "$myTaskTotalSize" + "`n"
$myTaskReadSize = $myTask.Progress.ReadSize
$myTaskText = "$myTaskText" + "ReadSizeByte" + "`t" + "$myTaskReadSize" + "`n"
$myTaskTransferedSize = $myTask.Progress.TransferedSize
$myTaskText = "$myTaskText" + "TransferedSizeByte" + "`t" + "$myTaskTransferedSize" + "`n"
# Starting from Version 9.5U3 StartTime is not supported anymore
If ($myTask.Progress.StartTime -eq $Null) {
$myTaskStartTime = $myTask.Progress.StartTimeLocal
} Else {
$myTaskStartTime = $myTaskStartTime | Get-Date -Format "dd.MM.yyyy HH\:mm\:ss" -ErrorAction SilentlyContinue
$myTaskText = "$myTaskText" + "StartTime" + "`t" + "$myTaskStartTime" + "`n"
# Starting from Version 9.5U3 StopTime is not supported anymore
If ($myTask.Progress.StopTime -eq $Null) {
$myTaskStopTime = $myTask.Progress.StopTimeLocal
} Else {
$myTaskStopTime = $myTaskStopTime | Get-Date -Format "dd.MM.yyyy HH\:mm\:ss" -ErrorAction SilentlyContinue
$myTaskText = "$myTaskText" + "StopTime" + "`t" + "$myTaskStopTime" + "`n"
# Result is a value of type System.TimeStamp. I'm sure there is a more elegant way of formatting the output:
$myTaskDuration = "" + "{0:D2}" -f $myTask.Progress.duration.Days + ":" + "{0:D2}" -f $myTask.Progress.duration.Hours + ":" + "{0:D2}" -f $myTask.Progress.duration.Minutes + ":" + "{0:D2}" -f $myTask.Progress.duration.Seconds
$myTaskText = "$myTaskText" + "DurationDDHHMMSS" + "`t" + "$myTaskDuration" + "`n"
$myTaskAvgSpeed = $myTask.Progress.AvgSpeed
$myTaskText = "$myTaskText" + "AvgSpeedBps" + "`t" + "$myTaskAvgSpeed" + "`n"
$myTaskDisplayName = $myTask.Progress.DisplayName
$myTaskText = "$myTaskText" + "DisplayName" + "`t" + "$myTaskDisplayName" + "`n"
$myBackupHost = Hostname
$myTaskText = "$myTaskText" + "BackupServer" + "`t" + "$myBackupHost" + "`n"
$myTaskText = "$myTaskText" + "<<<<" + ">>>>" +"`n"
write-host $myTaskText
catch
$errMsg = $_.Exception.Message
$errItem = $_.Exception.ItemName
Write-Error "Totally unexpected and unhandled error occured:`n Item: $errItem`n Error Message: $errMsg"
Break
