Vertiv UPS Monitoring
CMK version: Checkmk Raw Edition 2.3.0p19
OS version: Ubuntu LTS 24.04
I am running into an issue trying to monitor my Vertiv PSI5MT120LI UPS, with a IS-UNITY-DP network card. I am monitoring it using SNMPv3, and it does track mostly everything correctly, however, ‘OUT load phase 1’ (ups_out_load) never returns any data. It does not present an error, however it always just shows 0%. I can see on the battery that it does have more than 0% (11%ish), and I know there are devices connected to it, so I know that is not the problem. I am wondering if anyone has any insight on this. I tried searching for a Vertiv UPS plugin on the Exchange, but resulted with no luck. I do have some pretty good knowledge of CheckMK as I have done multiple deployments with it, but not enough to actually dig into the issue without some help.
OMD[testcmksite]:~$ cmk --debug -vvn test-ups-1
value store: synchronizing
Trying to acquire lock on /omd/sites/testcmksite/tmp/check_mk/counters/test-ups-1
Got lock on /omd/sites/testcmksite/tmp/check_mk/counters/test-ups-1
Releasing lock on /omd/sites/testcmksite/tmp/check_mk/counters/test-ups-1
Released lock on /omd/sites/testcmksite/tmp/check_mk/counters/test-ups-1
Checkmk version 2.3.0p19
+ FETCHING DATA
  Source: SourceInfo(hostname='test-ups-1', ipaddress='192.168.1.200', ident='snmp', fetcher_type=<FetcherType.SNMP: 7>, source_type=<SourceType.HOST: 1>)
[cpu_tracking] Start [794157e9ad50]
Read from cache: SNMPFileCache(test-ups-1, path_template=/omd/sites/testcmksite/tmp/check_mk/data_source_cache/snmp/{mode}/{hostname}, max_age=MaxAge(checking=0, discovery=90.0, inventory=90.0), simulation=False, use_only_cache=False, file_cache_mode=6)
Not using cache (Too old. Age is 32 sec, allowed is 0 sec)
  SNMP scan:
       Getting OID .1.3.6.1.2.1.1.1.0: Running 'snmpget -v3 -l authPriv -a md5 -u testsnmpuser -A ctEjE8!nAfaYZjK6a8hL -x AES -X ctEjE8!nAfaYZjK6a8hL -m "" -M "" -On -OQ -Oe -Ot 192.168.1.200 .1.3.6.1.2.1.1.1.0'
SNMP answer: ==> ["Uninitialized"]
b'Uninitialized'
       Getting OID .1.3.6.1.2.1.1.2.0: Running 'snmpget -v3 -l authPriv -a md5 -u testsnmpuser -A ctEjE8!nAfaYZjK6a8hL -x AES -X ctEjE8!nAfaYZjK6a8hL -m "" -M "" -On -OQ -Oe -Ot 192.168.1.200 .1.3.6.1.2.1.1.2.0'
SNMP answer: ==> [.1.3.6.1.4.1.476.1.42]
b'.1.3.6.1.4.1.476.1.42'
       Using cached OID .1.3.6.1.2.1.1.2.0: '.1.3.6.1.4.1.476.1.42'
       Getting OID .1.3.6.1.2.1.2.2.1.*: Running 'snmpgetnext -Cf -v3 -l authPriv -a md5 -u testsnmpuser -A ctEjE8!nAfaYZjK6a8hL -x AES -X ctEjE8!nAfaYZjK6a8hL -m "" -M "" -On -OQ -Oe -Ot 192.168.1.200 .1.3.6.1.2.1.2.2.1'
SNMP answer: ==> [1]
b'1'
       Using cached OID .1.3.6.1.2.1.1.1.0: 'Uninitialized'
   SNMP scan found                    if snmp_uptime ups_battery_capacity
Trying to acquire lock on /omd/sites/testcmksite/tmp/check_mk/snmp_scan_cache/test-ups-1.192.168.1.200
Got lock on /omd/sites/testcmksite/tmp/check_mk/snmp_scan_cache/test-ups-1.192.168.1.200
Releasing lock on /omd/sites/testcmksite/tmp/check_mk/snmp_scan_cache/test-ups-1.192.168.1.200
Released lock on /omd/sites/testcmksite/tmp/check_mk/snmp_scan_cache/test-ups-1.192.168.1.200
if: Fetching data (SNMP walk cache is enabled: Use any locally cached information)
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a md5 -u testsnmpuser -A ctEjE8!nAfaYZjK6a8hL -x AES -X ctEjE8!nAfaYZjK6a8hL -m "" -M "" -Cc -OQ -OU -On -Ot 192.168.1.200 .1.3.6.1.2.1.2.2.1.1'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a md5 -u testsnmpuser -A ctEjE8!nAfaYZjK6a8hL -x AES -X ctEjE8!nAfaYZjK6a8hL -m "" -M "" -Cc -OQ -OU -On -Ot 192.168.1.200 .1.3.6.1.2.1.2.2.1.2'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a md5 -u testsnmpuser -A ctEjE8!nAfaYZjK6a8hL -x AES -X ctEjE8!nAfaYZjK6a8hL -m "" -M "" -Cc -OQ -OU -On -Ot 192.168.1.200 .1.3.6.1.2.1.2.2.1.3'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a md5 -u testsnmpuser -A ctEjE8!nAfaYZjK6a8hL -x AES -X ctEjE8!nAfaYZjK6a8hL -m "" -M "" -Cc -OQ -OU -On -Ot 192.168.1.200 .1.3.6.1.2.1.2.2.1.5'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a md5 -u testsnmpuser -A ctEjE8!nAfaYZjK6a8hL -x AES -X ctEjE8!nAfaYZjK6a8hL -m "" -M "" -Cc -OQ -OU -On -Ot 192.168.1.200 .1.3.6.1.2.1.2.2.1.8'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a md5 -u testsnmpuser -A ctEjE8!nAfaYZjK6a8hL -x AES -X ctEjE8!nAfaYZjK6a8hL -m "" -M "" -Cc -OQ -OU -On -Ot 192.168.1.200 .1.3.6.1.2.1.2.2.1.10'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a md5 -u testsnmpuser -A ctEjE8!nAfaYZjK6a8hL -x AES -X ctEjE8!nAfaYZjK6a8hL -m "" -M "" -Cc -OQ -OU -On -Ot 192.168.1.200 .1.3.6.1.2.1.2.2.1.11'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a md5 -u testsnmpuser -A ctEjE8!nAfaYZjK6a8hL -x AES -X ctEjE8!nAfaYZjK6a8hL -m "" -M "" -Cc -OQ -OU -On -Ot 192.168.1.200 .1.3.6.1.2.1.2.2.1.12'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a md5 -u testsnmpuser -A ctEjE8!nAfaYZjK6a8hL -x AES -X ctEjE8!nAfaYZjK6a8hL -m "" -M "" -Cc -OQ -OU -On -Ot 192.168.1.200 .1.3.6.1.2.1.2.2.1.13'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a md5 -u testsnmpuser -A ctEjE8!nAfaYZjK6a8hL -x AES -X ctEjE8!nAfaYZjK6a8hL -m "" -M "" -Cc -OQ -OU -On -Ot 192.168.1.200 .1.3.6.1.2.1.2.2.1.14'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a md5 -u testsnmpuser -A ctEjE8!nAfaYZjK6a8hL -x AES -X ctEjE8!nAfaYZjK6a8hL -m "" -M "" -Cc -OQ -OU -On -Ot 192.168.1.200 .1.3.6.1.2.1.2.2.1.16'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a md5 -u testsnmpuser -A ctEjE8!nAfaYZjK6a8hL -x AES -X ctEjE8!nAfaYZjK6a8hL -m "" -M "" -Cc -OQ -OU -On -Ot 192.168.1.200 .1.3.6.1.2.1.2.2.1.17'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a md5 -u testsnmpuser -A ctEjE8!nAfaYZjK6a8hL -x AES -X ctEjE8!nAfaYZjK6a8hL -m "" -M "" -Cc -OQ -OU -On -Ot 192.168.1.200 .1.3.6.1.2.1.2.2.1.18'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a md5 -u testsnmpuser -A ctEjE8!nAfaYZjK6a8hL -x AES -X ctEjE8!nAfaYZjK6a8hL -m "" -M "" -Cc -OQ -OU -On -Ot 192.168.1.200 .1.3.6.1.2.1.2.2.1.19'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a md5 -u testsnmpuser -A ctEjE8!nAfaYZjK6a8hL -x AES -X ctEjE8!nAfaYZjK6a8hL -m "" -M "" -Cc -OQ -OU -On -Ot 192.168.1.200 .1.3.6.1.2.1.2.2.1.20'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a md5 -u testsnmpuser -A ctEjE8!nAfaYZjK6a8hL -x AES -X ctEjE8!nAfaYZjK6a8hL -m "" -M "" -Cc -OQ -OU -On -Ot 192.168.1.200 .1.3.6.1.2.1.2.2.1.21'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a md5 -u testsnmpuser -A ctEjE8!nAfaYZjK6a8hL -x AES -X ctEjE8!nAfaYZjK6a8hL -m "" -M "" -Cc -OQ -OU -On -Ot 192.168.1.200 .1.3.6.1.2.1.2.2.1.6'
lgp_info: Fetching data (SNMP walk cache is enabled: Use any locally cached information)
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a md5 -u testsnmpuser -A ctEjE8!nAfaYZjK6a8hL -x AES -X ctEjE8!nAfaYZjK6a8hL -m "" -M "" -Cc -OQ -OU -On -Ot 192.168.1.200 .1.3.6.1.4.1.476.1.42.2.1.2.0'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a md5 -u testsnmpuser -A ctEjE8!nAfaYZjK6a8hL -x AES -X ctEjE8!nAfaYZjK6a8hL -m "" -M "" -Cc -OQ -OU -On -Ot 192.168.1.200 .1.3.6.1.4.1.476.1.42.2.1.3.0'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a md5 -u testsnmpuser -A ctEjE8!nAfaYZjK6a8hL -x AES -X ctEjE8!nAfaYZjK6a8hL -m "" -M "" -Cc -OQ -OU -On -Ot 192.168.1.200 .1.3.6.1.4.1.476.1.42.2.1.4.0'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a md5 -u testsnmpuser -A ctEjE8!nAfaYZjK6a8hL -x AES -X ctEjE8!nAfaYZjK6a8hL -m "" -M "" -Cc -OQ -OU -On -Ot 192.168.1.200 .1.3.6.1.4.1.476.1.42.2.4.2.1.2'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a md5 -u testsnmpuser -A ctEjE8!nAfaYZjK6a8hL -x AES -X ctEjE8!nAfaYZjK6a8hL -m "" -M "" -Cc -OQ -OU -On -Ot 192.168.1.200 .1.3.6.1.4.1.476.1.42.2.4.2.1.3'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a md5 -u testsnmpuser -A ctEjE8!nAfaYZjK6a8hL -x AES -X ctEjE8!nAfaYZjK6a8hL -m "" -M "" -Cc -OQ -OU -On -Ot 192.168.1.200 .1.3.6.1.4.1.476.1.42.2.4.2.1.6'
liebert_system: Fetching data (SNMP walk cache is enabled: Use any locally cached information)
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a md5 -u testsnmpuser -A ctEjE8!nAfaYZjK6a8hL -x AES -X ctEjE8!nAfaYZjK6a8hL -m "" -M "" -Cc -OQ -OU -On -Ot 192.168.1.200 .1.3.6.1.4.1.476.1.42.3.9.20.1.10.1.2.1.4123'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a md5 -u testsnmpuser -A ctEjE8!nAfaYZjK6a8hL -x AES -X ctEjE8!nAfaYZjK6a8hL -m "" -M "" -Cc -OQ -OU -On -Ot 192.168.1.200 .1.3.6.1.4.1.476.1.42.3.9.20.1.20.1.2.1.4123'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a md5 -u testsnmpuser -A ctEjE8!nAfaYZjK6a8hL -x AES -X ctEjE8!nAfaYZjK6a8hL -m "" -M "" -Cc -OQ -OU -On -Ot 192.168.1.200 .1.3.6.1.4.1.476.1.42.3.9.20.1.10.1.2.1.4240'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a md5 -u testsnmpuser -A ctEjE8!nAfaYZjK6a8hL -x AES -X ctEjE8!nAfaYZjK6a8hL -m "" -M "" -Cc -OQ -OU -On -Ot 192.168.1.200 .1.3.6.1.4.1.476.1.42.3.9.20.1.20.1.2.1.4240'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a md5 -u testsnmpuser -A ctEjE8!nAfaYZjK6a8hL -x AES -X ctEjE8!nAfaYZjK6a8hL -m "" -M "" -Cc -OQ -OU -On -Ot 192.168.1.200 .1.3.6.1.4.1.476.1.42.3.9.20.1.10.1.2.1.4706'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a md5 -u testsnmpuser -A ctEjE8!nAfaYZjK6a8hL -x AES -X ctEjE8!nAfaYZjK6a8hL -m "" -M "" -Cc -OQ -OU -On -Ot 192.168.1.200 .1.3.6.1.4.1.476.1.42.3.9.20.1.20.1.2.1.4706'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a md5 -u testsnmpuser -A ctEjE8!nAfaYZjK6a8hL -x AES -X ctEjE8!nAfaYZjK6a8hL -m "" -M "" -Cc -OQ -OU -On -Ot 192.168.1.200 .1.3.6.1.4.1.476.1.42.3.9.20.1.10.1.2.1.5074'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a md5 -u testsnmpuser -A ctEjE8!nAfaYZjK6a8hL -x AES -X ctEjE8!nAfaYZjK6a8hL -m "" -M "" -Cc -OQ -OU -On -Ot 192.168.1.200 .1.3.6.1.4.1.476.1.42.3.9.20.1.20.1.2.1.5074'
liebert_system_events: Fetching data (SNMP walk cache is enabled: Use any locally cached information)
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a md5 -u testsnmpuser -A ctEjE8!nAfaYZjK6a8hL -x AES -X ctEjE8!nAfaYZjK6a8hL -m "" -M "" -Cc -OQ -OU -On -Ot 192.168.1.200 .1.3.6.1.4.1.476.1.42.3.9.20.1.10.1.2.100'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a md5 -u testsnmpuser -A ctEjE8!nAfaYZjK6a8hL -x AES -X ctEjE8!nAfaYZjK6a8hL -m "" -M "" -Cc -OQ -OU -On -Ot 192.168.1.200 .1.3.6.1.4.1.476.1.42.3.9.20.1.20.1.2.100'
liebert_temp_air: Fetching data (SNMP walk cache is enabled: Use any locally cached information)
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a md5 -u testsnmpuser -A ctEjE8!nAfaYZjK6a8hL -x AES -X ctEjE8!nAfaYZjK6a8hL -m "" -M "" -Cc -OQ -OU -On -Ot 192.168.1.200 .1.3.6.1.4.1.476.1.42.3.9.20.1.10.1.2.1.4291'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a md5 -u testsnmpuser -A ctEjE8!nAfaYZjK6a8hL -x AES -X ctEjE8!nAfaYZjK6a8hL -m "" -M "" -Cc -OQ -OU -On -Ot 192.168.1.200 .1.3.6.1.4.1.476.1.42.3.9.20.1.20.1.2.1.4291'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a md5 -u testsnmpuser -A ctEjE8!nAfaYZjK6a8hL -x AES -X ctEjE8!nAfaYZjK6a8hL -m "" -M "" -Cc -OQ -OU -On -Ot 192.168.1.200 .1.3.6.1.4.1.476.1.42.3.9.20.1.30.1.2.1.4291'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a md5 -u testsnmpuser -A ctEjE8!nAfaYZjK6a8hL -x AES -X ctEjE8!nAfaYZjK6a8hL -m "" -M "" -Cc -OQ -OU -On -Ot 192.168.1.200 .1.3.6.1.4.1.476.1.42.3.9.20.1.10.1.2.1.5002'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a md5 -u testsnmpuser -A ctEjE8!nAfaYZjK6a8hL -x AES -X ctEjE8!nAfaYZjK6a8hL -m "" -M "" -Cc -OQ -OU -On -Ot 192.168.1.200 .1.3.6.1.4.1.476.1.42.3.9.20.1.20.1.2.1.5002'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a md5 -u testsnmpuser -A ctEjE8!nAfaYZjK6a8hL -x AES -X ctEjE8!nAfaYZjK6a8hL -m "" -M "" -Cc -OQ -OU -On -Ot 192.168.1.200 .1.3.6.1.4.1.476.1.42.3.9.20.1.30.1.2.1.5002'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a md5 -u testsnmpuser -A ctEjE8!nAfaYZjK6a8hL -x AES -X ctEjE8!nAfaYZjK6a8hL -m "" -M "" -Cc -OQ -OU -On -Ot 192.168.1.200 .1.3.6.1.2.1.1.1'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a md5 -u testsnmpuser -A ctEjE8!nAfaYZjK6a8hL -x AES -X ctEjE8!nAfaYZjK6a8hL -m "" -M "" -Cc -OQ -OU -On -Ot 192.168.1.200 .1.3.6.1.2.1.1.2'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a md5 -u testsnmpuser -A ctEjE8!nAfaYZjK6a8hL -x AES -X ctEjE8!nAfaYZjK6a8hL -m "" -M "" -Cc -OQ -OU -On -Ot 192.168.1.200 .1.3.6.1.2.1.1.4'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a md5 -u testsnmpuser -A ctEjE8!nAfaYZjK6a8hL -x AES -X ctEjE8!nAfaYZjK6a8hL -m "" -M "" -Cc -OQ -OU -On -Ot 192.168.1.200 .1.3.6.1.2.1.1.5'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a md5 -u testsnmpuser -A ctEjE8!nAfaYZjK6a8hL -x AES -X ctEjE8!nAfaYZjK6a8hL -m "" -M "" -Cc -OQ -OU -On -Ot 192.168.1.200 .1.3.6.1.2.1.1.6'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a md5 -u testsnmpuser -A ctEjE8!nAfaYZjK6a8hL -x AES -X ctEjE8!nAfaYZjK6a8hL -m "" -M "" -Cc -OQ -OU -On -Ot 192.168.1.200 .1.3.6.1.2.1.1.3'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a md5 -u testsnmpuser -A ctEjE8!nAfaYZjK6a8hL -x AES -X ctEjE8!nAfaYZjK6a8hL -m "" -M "" -Cc -OQ -OU -On -Ot 192.168.1.200 .1.3.6.1.2.1.25.1.1'
ups_battery_capacity: Fetching data (SNMP walk cache is enabled: Use any locally cached information)
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a md5 -u testsnmpuser -A ctEjE8!nAfaYZjK6a8hL -x AES -X ctEjE8!nAfaYZjK6a8hL -m "" -M "" -Cc -OQ -OU -On -Ot 192.168.1.200 .1.3.6.1.2.1.33.1.2.3.0'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a md5 -u testsnmpuser -A ctEjE8!nAfaYZjK6a8hL -x AES -X ctEjE8!nAfaYZjK6a8hL -m "" -M "" -Cc -OQ -OU -On -Ot 192.168.1.200 .1.3.6.1.2.1.33.1.2.4.0'
ups_battery_warnings_eaton_mg: Fetching data (SNMP walk cache is enabled: Use any locally cached information)
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a md5 -u testsnmpuser -A ctEjE8!nAfaYZjK6a8hL -x AES -X ctEjE8!nAfaYZjK6a8hL -m "" -M "" -Cc -OQ -OU -On -Ot 192.168.1.200 .1.3.6.1.4.1.705.1.5.9.0'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a md5 -u testsnmpuser -A ctEjE8!nAfaYZjK6a8hL -x AES -X ctEjE8!nAfaYZjK6a8hL -m "" -M "" -Cc -OQ -OU -On -Ot 192.168.1.200 .1.3.6.1.4.1.705.1.5.11.0'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a md5 -u testsnmpuser -A ctEjE8!nAfaYZjK6a8hL -x AES -X ctEjE8!nAfaYZjK6a8hL -m "" -M "" -Cc -OQ -OU -On -Ot 192.168.1.200 .1.3.6.1.4.1.705.1.5.14.0'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a md5 -u testsnmpuser -A ctEjE8!nAfaYZjK6a8hL -x AES -X ctEjE8!nAfaYZjK6a8hL -m "" -M "" -Cc -OQ -OU -On -Ot 192.168.1.200 .1.3.6.1.4.1.705.1.5.15.0'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a md5 -u testsnmpuser -A ctEjE8!nAfaYZjK6a8hL -x AES -X ctEjE8!nAfaYZjK6a8hL -m "" -M "" -Cc -OQ -OU -On -Ot 192.168.1.200 .1.3.6.1.4.1.705.1.5.16.0'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a md5 -u testsnmpuser -A ctEjE8!nAfaYZjK6a8hL -x AES -X ctEjE8!nAfaYZjK6a8hL -m "" -M "" -Cc -OQ -OU -On -Ot 192.168.1.200 .1.3.6.1.4.1.705.1.7.4.0'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a md5 -u testsnmpuser -A ctEjE8!nAfaYZjK6a8hL -x AES -X ctEjE8!nAfaYZjK6a8hL -m "" -M "" -Cc -OQ -OU -On -Ot 192.168.1.200 .1.3.6.1.4.1.705.1.7.7.0'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a md5 -u testsnmpuser -A ctEjE8!nAfaYZjK6a8hL -x AES -X ctEjE8!nAfaYZjK6a8hL -m "" -M "" -Cc -OQ -OU -On -Ot 192.168.1.200 .1.3.6.1.4.1.705.1.7.10.0'
ups_in_freq: Fetching data (SNMP walk cache is enabled: Use any locally cached information)
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a md5 -u testsnmpuser -A ctEjE8!nAfaYZjK6a8hL -x AES -X ctEjE8!nAfaYZjK6a8hL -m "" -M "" -Cc -OQ -OU -On -Ot 192.168.1.200 .1.3.6.1.2.1.33.1.3.3.1.2'
ups_in_voltage: Fetching data (SNMP walk cache is enabled: Use any locally cached information)
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a md5 -u testsnmpuser -A ctEjE8!nAfaYZjK6a8hL -x AES -X ctEjE8!nAfaYZjK6a8hL -m "" -M "" -Cc -OQ -OU -On -Ot 192.168.1.200 .1.3.6.1.2.1.33.1.3.3.1.3'
ups_on_battery_eaton_mg: Fetching data (SNMP walk cache is enabled: Use any locally cached information)
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a md5 -u testsnmpuser -A ctEjE8!nAfaYZjK6a8hL -x AES -X ctEjE8!nAfaYZjK6a8hL -m "" -M "" -Cc -OQ -OU -On -Ot 192.168.1.200 .1.3.6.1.4.1.705.1.7.3.0'
ups_out_load: Fetching data (SNMP walk cache is enabled: Use any locally cached information)
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a md5 -u testsnmpuser -A ctEjE8!nAfaYZjK6a8hL -x AES -X ctEjE8!nAfaYZjK6a8hL -m "" -M "" -Cc -OQ -OU -On -Ot 192.168.1.200 .1.3.6.1.2.1.33.1.4.4.1.2'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a md5 -u testsnmpuser -A ctEjE8!nAfaYZjK6a8hL -x AES -X ctEjE8!nAfaYZjK6a8hL -m "" -M "" -Cc -OQ -OU -On -Ot 192.168.1.200 .1.3.6.1.2.1.33.1.4.4.1.5'
ups_out_voltage: Fetching data (SNMP walk cache is enabled: Use any locally cached information)
Already fetched OID: .1.3.6.1.2.1.33.1.4.4.1.2
ups_seconds_on_battery: Fetching data (SNMP walk cache is enabled: Use any locally cached information)
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a md5 -u testsnmpuser -A ctEjE8!nAfaYZjK6a8hL -x AES -X ctEjE8!nAfaYZjK6a8hL -m "" -M "" -Cc -OQ -OU -On -Ot 192.168.1.200 .1.3.6.1.2.1.33.1.2.2.0'
ups_test: Fetching data (SNMP walk cache is enabled: Use any locally cached information)
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a md5 -u testsnmpuser -A ctEjE8!nAfaYZjK6a8hL -x AES -X ctEjE8!nAfaYZjK6a8hL -m "" -M "" -Cc -OQ -OU -On -Ot 192.168.1.200 .1.3.6.1.2.1.1.3.0'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a md5 -u testsnmpuser -A ctEjE8!nAfaYZjK6a8hL -x AES -X ctEjE8!nAfaYZjK6a8hL -m "" -M "" -Cc -OQ -OU -On -Ot 192.168.1.200 .1.3.6.1.2.1.33.1.7.3'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a md5 -u testsnmpuser -A ctEjE8!nAfaYZjK6a8hL -x AES -X ctEjE8!nAfaYZjK6a8hL -m "" -M "" -Cc -OQ -OU -On -Ot 192.168.1.200 .1.3.6.1.2.1.33.1.7.5'
Running 'snmpbulkwalk -Cr10 -v3 -l authPriv -a md5 -u testsnmpuser -A ctEjE8!nAfaYZjK6a8hL -x AES -X ctEjE8!nAfaYZjK6a8hL -m "" -M "" -Cc -OQ -OU -On -Ot 192.168.1.200 .1.3.6.1.2.1.33.1.7.4'
Write data to cache file /omd/sites/testcmksite/tmp/check_mk/data_source_cache/snmp/checking/test-ups-1
Trying to acquire lock on /omd/sites/testcmksite/tmp/check_mk/data_source_cache/snmp/checking/test-ups-1
Got lock on /omd/sites/testcmksite/tmp/check_mk/data_source_cache/snmp/checking/test-ups-1
Releasing lock on /omd/sites/testcmksite/tmp/check_mk/data_source_cache/snmp/checking/test-ups-1
Released lock on /omd/sites/testcmksite/tmp/check_mk/data_source_cache/snmp/checking/test-ups-1
[cpu_tracking] Stop [794157e9ad50 - Snapshot(process=posix.times_result(user=0.08000000000000007, system=0.009999999999999981, children_user=3.24, children_system=0.26, elapsed=7.0))]
  Source: SourceInfo(hostname='test-ups-1', ipaddress='192.168.1.200', ident='piggyback', fetcher_type=<FetcherType.PIGGYBACK: 4>, source_type=<SourceType.HOST: 1>)
[cpu_tracking] Start [7941587e7920]
Read from cache: NoCache(test-ups-1, path_template=/dev/null, max_age=MaxAge(checking=0.0, discovery=0.0, inventory=0.0), simulation=False, use_only_cache=False, file_cache_mode=1)
No piggyback files for 'test-ups-1'. Skip processing.
No piggyback files for '192.168.1.200'. Skip processing.
Get piggybacked data
[cpu_tracking] Stop [7941587e7920 - Snapshot(process=posix.times_result(user=0.0, system=0.010000000000000009, children_user=0.0, children_system=0.0, elapsed=0.0))]
[cpu_tracking] Start [7941584ea060]
+ PARSE FETCHER RESULTS
  HostKey(hostname='test-ups-1', source_type=<SourceType.HOST: 1>)  -> Add sections: ['if', 'lgp_info', 'liebert_system', 'liebert_system_events', 'liebert_temp_air', 'snmp_info', 'snmp_uptime', 'ups_battery_capacity', 'ups_battery_warnings_eaton_mg', 'ups_in_freq', 'ups_in_voltage', 'ups_on_battery_eaton_mg', 'ups_out_load', 'ups_out_voltage', 'ups_seconds_on_battery', 'ups_test']
  HostKey(hostname='test-ups-1', source_type=<SourceType.HOST: 1>)  -> Add sections: []
Received no piggyback data
Battery capacity     1 hour 9 minutes, On mains, 100.00%
Battery state        No battery warnings reported
IN frequency phase 1 60.0 Hz
IN voltage phase 1   in voltage: 120V, (warn/crit at 110V/100V)
Inlet Temperature    Temperature: 26.0 °C
Interface 1          [eth0], (up), MAC: 00:02:99:2F:B7:9C, Speed: 10 MBit/s, In: 1.38 kB/s (0.11%), Out: 2.91 kB/s (0.23%)
Liebert Info         Model: IS-UNITY-SNMP, Firmware: 8.4.1.0, S/N:
OUT load phase 1     load: 0%
OUT voltage phase 1  out voltage: 120V (warn/crit at 110V/100V)
SNMP Info            Uninitialized, test-ups-1,  IDF,
Self Test            Last test: passed, Time since start of last test: 42 days 23 hours
Status PSI5-1500MT120LI System Model Number: PSI5-1500MT120LI, System Status: Normal Operation
System events        Normal
Uptime               Up since 2024-11-19 10:30:32, Uptime: 49 days 4 hours
[cpu_tracking] Stop [7941584ea060 - Snapshot(process=posix.times_result(user=0.009999999999999787, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.009999999776482582))]
[snmp] Success, [piggyback] Success (but no data found for this host), execution time 7.0 sec | execution_time=7.010 user_time=0.090 system_time=0.020 children_user_time=3.240 children_system_time=0.260 cmk_time_snmp=3.410 cmk_time_agent=0.000
This extension did not work?
https://exchange.checkmk.com/p/vertiv-geist-pdu
PDU != UPS :wink:
@ethede for the problem with the empty output load, only with a full SNMPwalk of the device it is possible to say if the data is present somewhere else.
From your output you can execute the following command manually.
This should show the complete output table of the device. You can look there if you see the expected load.
One other location to look for data would be the tree under .1.3.6.1.4.1.476 as this the enterprise OID of your device.
Upsi. :slight_smile:
