Hi All,
I’m a new user to checkmk, using 2.0.0p8 (CRE).
Setting up the environment has been painless.
There seems to however be a bug with editing the view properties of elements in the dashboard.
For example checking or unchecking the Play alarm sounds doesn’t save for me when I save the element.
However if I check the box above Make view sortable by user at the same time I’m making a change to the Play alarm sounds checkbox the setting change will save.
Other setting changes in the element seem to save ok, it appears to only be a behavior for the View Properties group.
I can’t find a bug tracker, so if this isn’t the right spot please let me know.
Cheers,
Heath
