Hi
In an attempt to install the iptables-persistent package for the Checkmk virtual appliance I received this error message:
!!! WARNING !!!
You are trying to use apt on a Check_MK Appliance. Installing or updating
packages manually will lead to serious trouble.
Your device will not be supported anymore if you change the installed packages.
!!! WARNING !!!
Do you want to continue? [y/N]:
To configure firewall rules effectively on the appliance this package is extremely important.
My questions are:
Since iptables itself comes preinstalled on the appliance, will I really have serious problems installing this package?
Can we have this package built in with the appliance to avoid the above possible issues, and so we will not need to install it manually at each firmware upgrade?
