VM Specs: 1 vCPU, 12 Cores Per vCPU, 16GB RAM
OS version: Rocky Linux 9.3
CMK version: Checkmk Raw Edition 2.2.0p17 (About to update to p21)
Checkmk Hosts: 414
Checkmk Services: 39.000
Hello everyone,
we have a relativly new Checkmk instance that is not optimized in its the last bits.
But one thing bothers me quite some time now.
I tried to get some hints for our high CPU usage but I could not find anything that helps.
Apache number of processes and Livestatus usage:
Do we need to take action here?
The service “Check_MK” has some high Perf-O-Meter stats:
Around 10 over 20 seconds
Around 30 under 5 seconds
Everything else inbetween -
Here is glimps of top -c: (ESET Sercurity cannot be removed)
top - 07:32:47 up 1 day, 19:31, 1 user, load average: 50.16, 44.88, 44.28
Tasks: 437 total, 18 running, 419 sleeping, 0 stopped, 0 zombie
%Cpu(s): 81.6 us, 12.7 sy, 0.1 ni, 3.2 id, 1.2 wa, 0.9 hi, 0.4 si, 0.0 st
MiB Mem : 15669.4 total, 2900.0 free, 6167.5 used, 7345.4 buff/cache
MiB Swap: 8012.0 total, 7147.4 free, 864.6 used. 9501.8 avail Mem
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
8418 eset-ef+ 20 0 2211484 546356 20964 S 25.1 3.4 610:49.93 /opt/eset/efs/lib/scand
3491124 MYSITE 20 0 1544876 103892 6612 S 21.5 0.6 97:19.90 /omd/sites/MYSITE/bin/nagios -ud /omd/sites/MYSITE/tmp/nagios/nagios.cfg
4174316 MYSITE 20 0 62964 56748 13072 S 20.8 0.4 0:00.66 /omd/sites/MYSITE/bin/python3 /omd/sites/MYSITE/var/check_mk/core/helper_config/latest/host_checks/MYHOST1
4174296 MYSITE 20 0 63072 56968 13064 S 20.1 0.4 0:00.69 /omd/sites/MYSITE/bin/python3 /omd/sites/MYSITE/var/check_mk/core/helper_config/latest/host_checks/MYHOST2
4174309 MYSITE 20 0 63092 56960 13056 S 19.8 0.4 0:00.62 /omd/sites/MYSITE/bin/python3 /omd/sites/MYSITE/var/check_mk/core/helper_config/latest/host_checks/MYHOST3
4174280 MYSITE 20 0 64084 57412 13044 S 19.5 0.4 0:00.70 /omd/sites/MYSITE/bin/python3 /omd/sites/MYSITE/var/check_mk/core/helper_config/latest/host_checks/MYHOST4
4174311 MYSITE 20 0 63932 57180 13060 S 19.1 0.4 0:00.62 /omd/sites/MYSITE/bin/python3 /omd/sites/MYSITE/var/check_mk/core/helper_config/latest/host_checks/MYHOST5
4174320 MYSITE 20 0 64404 57444 13044 S 19.1 0.4 0:00.58 /omd/sites/MYSITE/bin/python3 /omd/sites/MYSITE/var/check_mk/core/helper_config/latest/host_checks/MYHOST6
4174301 MYSITE 20 0 66412 59768 13076 S 18.2 0.4 0:00.63 /omd/sites/MYSITE/bin/python3 /omd/sites/MYSITE/var/check_mk/core/helper_config/latest/host_checks/MYHOST7
4174278 MYSITE 20 0 63968 57568 13196 S 17.8 0.4 0:00.67 /omd/sites/MYSITE/bin/python3 /omd/sites/MYSITE/var/check_mk/core/helper_config/latest/host_checks/MYHOST8
4174298 MYSITE 20 0 62952 56688 13024 S 17.8 0.4 0:00.63 /omd/sites/MYSITE/bin/python3 /omd/sites/MYSITE/var/check_mk/core/helper_config/latest/host_checks/MYHOST9
4174304 MYSITE 20 0 63928 56844 13036 S 17.8 0.4 0:00.67 /omd/sites/MYSITE/bin/python3 /omd/sites/MYSITE/var/check_mk/core/helper_config/latest/host_checks/MYHOST0
4174300 MYSITE 20 0 64108 56756 13120 S 16.2 0.4 0:00.56 /omd/sites/MYSITE/bin/python3 /omd/sites/MYSITE/var/check_mk/core/helper_config/latest/host_checks/MYHOST11
4174851 MYSITE 20 0 56288 50988 12912 R 15.8 0.3 0:00.48 /omd/sites/MYSITE/bin/python3 /omd/sites/MYSITE/var/check_mk/core/helper_config/latest/host_checks/MYHOST12
4174275 MYSITE 20 0 64056 57080 13032 S 15.5 0.4 0:00.63 /omd/sites/MYSITE/bin/python3 /omd/sites/MYSITE/var/check_mk/core/helper_config/latest/host_checks/MYHOST13
4174286 MYSITE 20 0 64144 57192 13076 S 15.5 0.4 0:00.66 /omd/sites/MYSITE/bin/python3 /omd/sites/MYSITE/var/check_mk/core/helper_config/latest/host_checks/MYHOST14
4174293 MYSITE 20 0 64124 57180 13040 S 15.2 0.4 0:00.60 /omd/sites/MYSITE/bin/python3 /omd/sites/MYSITE/var/check_mk/core/helper_config/latest/host_checks/MYHOST15
4174288 MYSITE 20 0 64180 57744 13136 D 14.2 0.4 0:00.60 /omd/sites/MYSITE/bin/python3 /omd/sites/MYSITE/var/check_mk/core/helper_config/latest/host_checks/MYHOST16
4174822 MYSITE 20 0 46608 40748 12904 R 14.2 0.3 0:00.43 /omd/sites/MYSITE/bin/python3 /omd/sites/MYSITE/var/check_mk/core/helper_config/latest/host_checks/MYHOST17
4174854 MYSITE 20 0 53252 47824 12840 R 13.5 0.3 0:00.41 /omd/sites/MYSITE/bin/python3 /omd/sites/MYSITE/var/check_mk/core/helper_config/latest/host_checks/MYHOST18
4174874 MYSITE 20 0 48276 42640 12932 R 12.9 0.3 0:00.39 /omd/sites/MYSITE/bin/python3 /omd/sites/MYSITE/var/check_mk/core/helper_config/latest/host_checks/MYHOST19
4174846 MYSITE 20 0 48276 42820 12848 R 12.5 0.3 0:00.38 /omd/sites/MYSITE/bin/python3 /omd/sites/MYSITE/var/check_mk/core/helper_config/latest/host_checks/MYHOST20
4174859 MYSITE 20 0 48404 42840 12868 R 12.5 0.3 0:00.38 /omd/sites/MYSITE/bin/python3 /omd/sites/MYSITE/var/check_mk/core/helper_config/latest/host_checks/MYHOST21
4174272 MYSITE 20 0 64812 58368 13140 S 12.2 0.4 0:00.56 /omd/sites/MYSITE/bin/python3 /omd/sites/MYSITE/var/check_mk/core/helper_config/latest/host_checks/MYHOST22
4173780 MYSITE 20 0 26736 14132 8732 D 11.2 0.1 0:00.84 /usr/bin/perl /omd/sites/MYSITE/lib/pnp4nagios/process_perfdata.pl -n -c /omd/sites/MYSITE/etc/pnp4nagios/process_perfdata.cfg -b /omd/sites/MYSITE/var/pnp4nagios/spool//perfdata.1706682734
4174875 MYSITE 20 0 46812 41492 12848 R 11.2 0.3 0:00.34 /omd/sites/MYSITE/bin/python3 /omd/sites/MYSITE/var/check_mk/core/helper_config/latest/host_checks/MYHOST23
4174884 MYSITE 20 0 46548 40412 12820 R 10.9 0.3 0:00.33 /omd/sites/MYSITE/bin/python3 /omd/sites/MYSITE/var/check_mk/core/helper_config/latest/host_checks/MYHOST24
4174883 MYSITE 20 0 44084 38584 12840 R 10.6 0.2 0:00.32 /omd/sites/MYSITE/bin/python3 /omd/sites/MYSITE/var/check_mk/core/helper_config/latest/host_checks/MYHOST25
4173781 MYSITE 20 0 26752 14432 8932 D 9.6 0.1 0:00.84 /usr/bin/perl /omd/sites/MYSITE/lib/pnp4nagios/process_perfdata.pl -n -c /omd/sites/MYSITE/etc/pnp4nagios/process_perfdata.cfg -b /omd/sites/MYSITE/var/pnp4nagios/spool//perfdata.1706682749
117 root 0 -20 0 0 0 I 9.2 0.0 140:38.84 [kworker/0:1H-kblockd]
4793 MYSITE 20 0 844316 303044 3000 S 6.9 1.9 73:10.23 /omd/sites/MYSITE/bin/rrdcached -t 4 -w 3600 -z 1800 -f 7200 -s MYSITE -m 660 -l unix:/omd/sites/MYSITE/tmp/run/rrdcached.sock -p /omd/sites/MYSITE/tmp/rrdcached.pid -j /omd/sites/MYSITE/var/rrdcached -o /omd/sites/MYSITE/var/log/r+
4162665 MYSITE 20 0 67556 61592 13048 R 5.0 0.4 0:00.83 /omd/sites/MYSITE/bin/python3 /omd/sites/MYSITE/var/check_mk/core/helper_config/latest/host_checks/MYHOST26
8419 root 0 -20 1123392 6392 4796 S 4.0 0.0 101:17.15 /opt/eset/efs/lib/oaeventd
1196481 MYSITE 20 0 492176 239644 24364 S 4.0 1.5 1:53.97 /usr/sbin/httpd -f /omd/sites/MYSITE/etc/apache/apache.conf
1341813 MYSITE 20 0 498392 249092 24340 S 4.0 1.6 1:49.53 /usr/sbin/httpd -f /omd/sites/MYSITE/etc/apache/apache.conf
3710694 MYSITE 20 0 493284 245928 26560 S 4.0 1.5 1:15.82 /usr/sbin/httpd -f /omd/sites/MYSITE/etc/apache/apache.conf
4169898 MYSITE 20 0 69656 63248 13080 D 3.3 0.4 0:00.69 /omd/sites/MYSITE/bin/python3 /omd/sites/MYSITE/var/check_mk/core/helper_config/latest/host_checks/MYHOST27
3825922 MYSITE 20 0 457316 211320 27012 S 2.6 1.3 0:09.81 /usr/sbin/httpd -f /omd/sites/MYSITE/etc/apache/apache.conf
3392714 root 20 0 0 0 0 D 1.3 0.0 0:02.50 [kworker/u384:5+flush-253:0]
4174113 MYSITE 20 0 64380 57968 13076 D 1.3 0.4 0:00.62 /omd/sites/MYSITE/bin/python3 /omd/sites/MYSITE/var/check_mk/core/helper_config/latest/host_checks/MYHOST28
4174110 MYSITE 20 0 64136 57280 13144 S 1.0 0.4 0:00.60 /omd/sites/MYSITE/bin/python3 /omd/sites/MYSITE/var/check_mk/core/helper_config/latest/host_checks/MYHOST29
4174118 MYSITE 20 0 64136 57500 13092 S 1.0 0.4 0:00.63 /omd/sites/MYSITE/bin/python3 /omd/sites/MYSITE/var/check_mk/core/helper_config/latest/host_checks/MYHOST30
4038 MYSITE 20 0 277480 46964 9804 S 0.7 0.3 10:57.07 gunicorn: worker [agent_receiver.main:main_app()]
4157230 admin-c+ 20 0 226612 5020 3564 R 0.7 0.0 0:00.43 top -c
4174162 MYSITE 20 0 64112 57184 13076 S 0.7 0.4 0:00.58 /omd/sites/MYSITE/bin/python3 /omd/sites/MYSITE/var/check_mk/core/helper_config/latest/host_checks/MYHOST31
4174165 MYSITE 20 0 64396 57744 13076 S 0.7 0.4 0:00.59 /omd/sites/MYSITE/bin/python3 /omd/sites/MYSITE/var/check_mk/core/helper_config/latest/host_checks/MYHOST32
4174951 MYSITE 20 0 9096 6572 5684 S 0.7 0.0 0:00.02 snmpbulkwalk -Cr10 -v3 -l authPriv -a md5 -u USERNAME -A -x DES -X -m -M -t 2.00 -r 5 -Cc -OQ -OU -On -Ot IPADRESS .1.3.6.1.2.1.2.2.1.8
4174963 MYSITE 20 0 9096 6624 5732 S 0.7 0.0 0:00.02 snmpbulkwalk -Cr10 -v3 -l authPriv -a md5 -u USERNAME -A -x DES -X -m -M -t 2.00 -r 5 -Cc -OQ -OU -On -Ot IPADRESS .1.3.6.1.2.1.31.1.1.1.6
4174971 MYSITE 20 0 8976 6204 5416 S 0.7 0.0 0:00.02 snmpbulkwalk -Cr10 -v3 -l authPriv -a md5 -u USERNAME -A -x DES -X -m -M -t 2.00 -r 5 -Cc -OQ -OU -On -Ot IPADRESS .1.3.6.1.2.1.31.1.1.1.7
4174975 MYSITE 20 0 8976 6156 5364 S 0.7 0.0 0:00.02 snmpbulkwalk -Cr10 -v3 -l authPriv -a md5 -u USERNAME -A -x DES -X -m -M -t 2.00 -r 5 -Cc -OQ -OU -On -Ot IPADRESS .1.3.6.1.2.1.31.1.1.1.6
4174976 MYSITE 20 0 9096 6584 5692 S 0.7 0.0 0:00.02 snmpbulkwalk -Cr10 -v3 -l authPriv -a md5 -u USERNAME -A -x DES -X -m -M -t 2.00 -r 5 -Cc -OQ -OU -On -Ot IPADRESS .1.3.6.1.4.1.9.9.91.1.1.1.1.2
4174977 MYSITE 20 0 8976 6152 5360 S 0.7 0.0 0:00.02 snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u USERNAME -A -x AES -X -m -M -t 2.00 -r 5 -Cc -OQ -OU -On -Ot IPADRESS .1.3.6.1.2.1.31.1.1.1.12
4174978 MYSITE 20 0 9096 6596 5708 S 0.7 0.0 0:00.02 snmpbulkwalk -Cr10 -v3 -l authPriv -a md5 -u USERNAME -A -x DES -X -m -M -t 2.00 -r 5 -Cc -OQ -OU -On -Ot IPADRESS .1.3.6.1.4.1.9.9.91.1.2.1.1.4
4174979 MYSITE 20 0 8976 6152 5360 R 0.7 0.0 0:00.02 snmpbulkwalk -Cr10 -v3 -l authPriv -a md5 -u USERNAME -A -x DES -X -m -M -t 2.00 -r 5 -Cc -OQ -OU -On -Ot IPADRESS .1.3.6.1.4.1.9.9.91.1.1.1.1.3
4174981 MYSITE 20 0 8976 6156 5360 S 0.7 0.0 0:00.02 snmpbulkwalk -Cr10 -v3 -l authPriv -a md5 -u USERNAME -A -x DES -X -m -M -t 2.00 -r 5 -Cc -OQ -OU -On -Ot IPADRESS .1.3.6.1.2.1.31.1.1.1.15
4174982 MYSITE 20 0 8976 6180 5388 S 0.7 0.0 0:00.02 snmpbulkwalk -Cr10 -v3 -l authPriv -a md5 -u USERNAME -A -x DES -X -m -M -t 2.00 -r 5 -Cc -OQ -OU -On -Ot IPADRESS .1.3.6.1.4.1.9.9.91.1.2.1.1.3
4174983 MYSITE 20 0 8976 6156 5364 S 0.7 0.0 0:00.02 snmpbulkwalk -Cr10 -v3 -l authPriv -a md5 -u USERNAME -A -x DES -X -m -M -t 2.00 -r 5 -Cc -OQ -OU -On -Ot IPADRESS .1.3.6.1.4.1.9.9.91.1.1.1.1.3
4174986 MYSITE 20 0 9096 6136 5348 S 0.7 0.0 0:00.02 snmpbulkwalk -Cr10 -v3 -l authPriv -a md5 -u USERNAME -A -x DES -X -m -M -t 2.00 -r 5 -Cc -OQ -OU -On -Ot IPADRESS .1.3.6.1.2.1.31.1.1.1.7
461 root 0 -20 0 0 0 I 0.3 0.0 2:50.12 [kworker/2:1H-kblockd]
2211 wazuh 20 0 246012 7500 2240 S 0.3 0.0 18:25.86 /var/ossec/bin/wazuh-agentd
8438 eset-ef+ 20 0 1918416 23248 8820 S 0.3 0.1 8:27.91 /opt/eset/efs/lib/wapd
4144619 admin-c+ 20 0 222652 3764 3412 S 0.3 0.0 0:00.14 bash -c while true; do sleep 1;head -v -n 8 /proc/meminfo; head -v -n 2 /proc/stat /proc/version /proc/uptime /proc/loadavg /proc/sys/fs/file-nr /proc/sys/kernel/hostname; tail -v -n 16 /proc/net/dev;echo '==> /proc/df <==';df -l;e+
4169917 MYSITE 20 0 64688 57812 13120 S 0.3 0.4 0:00.59 /omd/sites/MYSITE/bin/python3 /omd/sites/MYSITE/var/check_mk/core/helper_config/latest/host_checks/MYHOST33
4169936 MYSITE 20 0 64064 57456 13060 D 0.3 0.4 0:00.66 /omd/sites/MYSITE/bin/python3 /omd/sites/MYSITE/var/check_mk/core/helper_config/latest/host_checks/MYHOST34
4174974 MYSITE 20 0 9096 6604 5720 S 0.3 0.0 0:00.01 snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u USERNAME -A -x AES -X -m -M -t 2.00 -r 5 -Cc -OQ -OU -On -Ot IPADRESS .1.3.6.1.2.1.2.2.1.1
4174984 MYSITE 20 0 8976 6148 5360 S 0.3 0.0 0:00.01 snmpbulkwalk -Cr10 -v3 -l authPriv -a md5 -u USERNAME -A -x DES -X -m -M -t 2.00 -r 5 -Cc -OQ -OU -On -Ot IPADRESS .1.3.6.1.4.1.9.9.91.1.2.1.1.4
4174987 MYSITE 20 0 8976 6136 5344 R 0.3 0.0 0:00.01 snmpbulkwalk -Cr10 -v3 -l authPriv -a md5 -u USERNAME -A -x DES -X -m -M -t 2.00 -r 5 -Cc -OQ -OU -On -Ot IPADRESS .1.3.6.1.2.1.31.1.1.1.18
4174988 MYSITE 20 0 8976 6132 5344 R 0.3 0.0 0:00.01 snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u USERNAME -A -x AES -X -m -M -t 2.00 -r 5 -Cc -OQ -OU -On -Ot IPADRESS .1.3.6.1.4.1.12356.101.12.2.3.1.6
4174989 MYSITE 20 0 8976 6180 5388 R 0.3 0.0 0:00.01 snmpbulkwalk -Cr10 -v3 -l authPriv -a sha -u USERNAME -A -x AES -X -m -M -t 2.00 -r 5 -Cc -OQ -OU -On -Ot IPADRESS .1.3.6.1.4.1.9.9.91.1.1.1.1.3
1 root 20 0 173420 15548 10756 S 0.0 0.1 30:16.16 /usr/lib/systemd/systemd rhgb --switched-root --system --deserialize 31
2 root 20 0 0 0 0 S 0.0 0.0 0:01.14 [kthreadd]
3 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 [rcu_gp]
4 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 [rcu_par_gp]
5 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 [slub_flushwq]
6 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 [netns]
10 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 [mm_percpu_wq]
12 root 20 0 0 0 0 I 0.0 0.0 0:00.00 [rcu_tasks_kthre]
13 root 20 0 0 0 0 I 0.0 0.0 0:00.00 [rcu_tasks_rude_]
14 root 20 0 0 0 0 I 0.0 0.0 0:00.00 [rcu_tasks_trace]
15 root 20 0 0 0 0 S 0.0 0.0 0:27.37 [ksoftirqd/0]
16 root 20 0 0 0 0 S 0.0 0.0 0:00.00 [pr/tty0]
It would be great to get this fixed.
If additional information are needed I’m happy to provide more.
Thanks in advance.
