VMware vCenter 8.x – Checkmk 2.4.0p24 only shows VM Power State, but NO CPU/Memory/Disk metrics (VM inventory missing in SOAP Agent)
Environment
  • Checkmk Edition: Enterprise Edition (CEE)
  • Appliance Version: virt1 Mark I 1.7.2
  • Checkmk Version: 2.4.0p24 (latest available from official downloads)
  • vCenter Version: VMware vCenter Server 8.x
  • Monitoring Method: vSphere Web Services API (SOAP)
  • Monitoring User: checkmk@vsphere.local
  • Permissions: Read-Only, Global Permissions, Propagate enabled
Problem Summary
When Checkmk connects to vCenter 8.x using the built‑in VMware Special Agent (SOAP API):
:check_mark: ESXi hosts are discovered normally
:check_mark: Datastores are discovered normally
:check_mark: VM object appears, but only “Power State” is shown
:cross_mark: All VM performance metrics (CPU, memory, disk I/O, network I/O) are missing
:cross_mark: No piggyback data is generated for VMs
:cross_mark: VM inventory does not appear in special agent output
The Checkmk service output always contains:
[piggyback] Success (but no data found for this host)
This issue affects all VMs under the monitored vCenter.
Detailed Symptoms
For every VM (example: test-rhfs2) Checkmk shows ONLY:
  • Power State → OK
    power state: poweredOn
But these checks are missing for all VMs:
  • CPU usage
  • Memory usage
  • Balloon / swapping
  • Disk latency / IOPS
  • Network throughput
  • Guest Tools state
  • VM hardware
  • VM configuration
  • Snapshot age
  • etc.
This means:
Only the very top-level VM summary is detected; none of the actual VM performance counters are processed.
What We Confirmed (This is NOT a permissions problem)
:check_mark: 1. Permissions verified through vSphere GUI
The monitoring user has Global Read-Only, propagate to children, and can see all VMs.
:check_mark: 2. Verified using govc (VMware REST/WS client)
Using the same read‑only credentials:
govc vm.info /DC/vm/test-rhfs2
govc returns full VM information:
Guest name: RHEL8
CPU: 16 vCPU
Memory: 16384MB
Power state: poweredOn
Host: test-vmprod04.wrs.com
:right_arrow: So the vCenter API is working correctly, and the user has full VM visibility.
:check_mark: 3. Network connectivity from Checkmk server to vCenter: OK
:check_mark: 4. SOAP special agent output = NO VirtualMachine objects
Only HostSystem objects appear.
Community Evidence Suggesting SOAP Agent Bug in Checkmk 2.4.x
We found the following public report that matches our exact symptoms:
“Most vSphere ESX plugins do not handle the info on version 2.4.0p12 … piggyback has no data … VM data missing.”
Source: Checkmk Community Forum
:link: Most Vsphere ESX plugins do not handle the info on version 2.4.0p12
This report describes the same behaviors:
  • ESXi OK
  • Datastores OK
  • VM metrics missing
  • SOAP agent fails to parse VM counters
  • piggyback empty
Even though the report is for 2.4.0p12, our version 2.4.0p24 shows the exact same symptoms.
Expected Behavior
Checkmk should:
  • Retrieve VM list
  • Generate piggyback folders for each VM
  • Populate CPU, memory, disk, and network performance metrics
  • Display VMware guest checks (tools, snapshots, hardware, etc.)
Actual Behavior
  • VM list not returned by the Checkmk SOAP agent
  • Only PowerState appears
  • No performance data returned
  • No piggyback VM folders created
  • Agent output includes no <virtualmachine> sections
Conclusion
Based on:
  • Valid vSphere API responses (verified via govc)
  • Correct user permissions
  • Correct network connectivity
  • SOAP agent output missing VM objects
  • Matching community reports for Checkmk 2.4.x
This strongly suggests a SOAP compatibility issue / parsing bug in Checkmk 2.4.x VMware special agent when communicating with vCenter 8.x.
Request (for Checkmk Support / Developers)
  1. Please confirm if there is a known issue in 2.4.x with vCenter 8.x SOAP API.
  2. Is there a hotfix or workaround available?
  3. Is there an upcoming REST‑based VMware agent or new special agent planned?
  4. If available, can we join any preview/testing program for vSphere REST monitoring?
Thank you for your support.
Were you able to fix this issue?
