I am wondering how can I set up VPN Tunnel monitoring via CheckMk for Palo Alto PA820?
I have a 2.0.3p RAW version of checkmk and it does not see VPN tunnel as a service.
Best regards.
Nenad.
Best regards.
Nenad.
As far as I know, there is no specific “VPN tunnel monitoring” within checkmk for PAN firewalls.
However, since Palo uses the concept of route-based VPN tunnels which require a tunnel interface per VPN tunnel, you can simply monitor those tunnels. In my case, I have one single site-to-site VPN which looks like this:
For sure, specific stats such as “3 out of 4 VPN tunnels are up” would be nicer.
Even more details such as phase 1 (IKE) and phase 2 (IPsec) counters would be great and probably feasible since Palo has them in their GUI. But I have had a look at the PAN MIBs for PAN-OS 10.0 right now, and I can’t find any VPN MIBs.
[Resource: Enterprise SNMP MIB Files] There are some MIBs for GlobalProtect, but not for site-to-site VPN tunnels.
I just was told that this is not sufficient.
Checkmk only shows the tunnel interfaces but not the associated peer tunnel IPs.
Any ideas ?
show vpn flow
total tunnels configured: 1
filter - type IPSec, state any
total IPSec tunnel configured: 1
total IPSec tunnel shown: 1
name id state local-ip peer-ip tunnel-i/f
vpn-to-siteB 5 active 100.1.1.1 200.1.1.1 tunnel.41 ype or paste code here
What exactly are you searching for? If you are monitoring the VPN tunnel interface with checkmk you can see the “up/down” state as well as traffic stats. To my mind, this is enough for a basic monitoring of a VPN tunnel. Do you have a use case for monitoring the peer IPs?
I am the monitoring guy, not the firewall expert, but I’ll try to explain.
These “objects” should be in active state but sometimes they are either in inactive or init state:
show vpn flow | match init
id name state monitor local-ip peer-ip tunnel-i/f
137 s2stu_547:partner_to_10.55.12 init off xxx.xxx.xxx.xxx yyy.yyy.yyy.yyy tunnel.547
In Checkmk the tunnel.547 shows as UP, but one of it’s associated “peer-tunnels” is not active.
That is what we need to monitor.
I was told that this is related to ipsec, which has got a phase1 and phase2
and sometimes the one or the other fails.
(I x-ed out the ips)
What you want is something like this for Cisco (CheckMK / Cisco / IPSec VPN tunnel · GitLab)
also for the PaloAlto.
Thanks for the hint.
Unfortunately this is not for Palo Altos but for Cisco only.
Hint: The domain hopto.org where this is hosted is found on several blocklists,
i first had to whitelist thl-cmk.hopto.org to access this.
