I’ve running a multisite checkMK (1.6.0p11-cee) installation with 4.5k host and 150k checks.
Over all there are 20 sites up and running, which is needed because of network topology
for more and more queries in WATO we run in timeout:
Internal error: Your request timed out after 110 seconds. This issue may be related to a local configuration problem or a request which works with a too large number of objects. But if you think this issue is a bug, please send a crash report.
def request_timeout(self):
"""The system web servers configured request timeout. This is the time
before the request is terminated from the view of the client."""
# TODO: Found no way to get this information from WSGI environment. Hard code
# the timeout for the moment.
return 590
And finally in the system configuration of apache probably in /etc/apache or /etc/httpd depending on your OS, you also need to adjust. Default timeout is 300 sec.
