Web configuration not enabled
I have downloaded Ckeck_mk virt1 DEMO and configured the network and device password but I can’t seem to enable the web configuration. When i ping the host it is up and the index is up via the browser,
/webconf/index.py
however the html of the user log in screen has a red section that states
“Web configuration not enabled” which confirms that I am not able to Enable the web configuration.
Do you have any suggestions?
Thank you.
Maja
Just figured out that virtual box instance only works for subscription users. Switching to a linux installation.
On a linux installation you can enable and disable the web configuration as site user with
omd config
